car wont stay on, oil in water, blown head gasket??
i havent checked my compression yet, but im getting a lot of oil in the water. is this most likely a head gasket or intake gasket? when i start the car it kinda lopes reeeaaalll heavy for a few seconds and then just cuts off, wont hold volts, oil pressure...nothin. any help is greatly appreciated guys.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.www.rk-collection.com |
04 Cobra
check the oil if its milky then id say head gasket
![]() 04 Redfire Cobra SVT - JLT RAI, Bassani Catted X,Borla Stingers, MGW STS, Tune 08 Mazdaspeed 3 - Too many boltons - SOLD 00 Mustang GT - Too many boltons - Traded |
1988 Mustang GT
N/A
I 2nd the head gasket.
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"! |
well the oil is still new, so will it still turn milky/white? i havent got to run a compression test on it yet so ill have to wait and see that tomorrow when i go up there.
04 Cobra
if its blown bad enough it should. do you have to keep adding coolant? any overheating problems?
i havent drove the car yet. it was sittin at the radiator shop while they were fabricating my radiator setup and they said when they turned it on it was running fine and everything but the radiator was filling with oil/water. it doesnt leak externally at all. but i find it weird how it ran fine when they started it but when i went to look at it it wont even stay on...idk. but they said its either at blown head gasket, intake gasket, cracked block, or warped head. i doubt its a block or head. what do you guys think?
04 Cobra
i dnt think its something you can guess, you have to do test to narrow down what it might be. it the head or block were cracked, and everyone feel free to correct me, but im sure youd lose compression on the cylinder that is cracked, so it would miss and wouldnt idle correctly. check the oil, if you can get it to stay running see if it overheates. also smoke from exhaust should be major if its head gasket problem
ok i checked the compression today on the #5 cylinder and its between 90-120 (i checked it 3 times). its its cracked im puttin a whole new motor in it.
Funny you should mention a new motor. I got a call from a guy yesterday who has over 50 brand new 4.6L from 04 cars, with transmissions. Zero miles. He is asking $4500.00 per assembly + shipping.
N/A 4v Guru
2003 Mach 1
Probably just the head gasket. head change kit for 120 plus labor is cheaper than a whole new motor. No need to freak out about the motor being wasted til you pull the head off.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
Threads Similar to: car wont stay on, oil in water, blown head gasket??
| =( blown head gasket | itschristorres8 | V6 Mustangs | 17 | October 23rd, 2007 11:14 AM |
| blown head gasket | 5.0pwr | 96-98 | 2 | September 17th, 2007 11:57 PM |
| blown head gasket.......new heads? | sniperrider | 5.0 Mustangs | 18 | April 25th, 2007 11:10 PM |
| Blown Head Gasket | Lax89 | 5.0 Mustangs | 10 | February 17th, 2007 08:01 AM |
| White Smoke / Blown Head Gasket? | terribleonexx88 | 5.0 Mustangs | 20 | November 2nd, 2006 12:28 PM |
