LinkBack (1) | Thread Tools |
#1
Transmission pan leak!!!
Hey guys well I recently did a trans filter and fluid change on my car. I bought the kit for auto zone, came with the filter and thin gasket. Well the pan gasket leaked.... but only from the passenger side... so i went to the stealership and bought a new factory gasket and pan just for shits and giggles. Well it still leaks... and only from the passenger side!!!! Any suggestions.... Please..... i'm so frustrated right now!!! Thanks!!!
MM's nicest mod, :)
did you overtorque the bolts, how are you actually tighting each bolt down in sequence, criss cross or what
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
ok yes everything is clean and i believe the gasket is seated right!!!
i tightened everything finger tight then like a 1/4 turn snug... i dont have a torgue wrench.... Should i get one and start over???..... |
1988 Mustang GT
N/A
When you took it off, did the pan twist or bend?
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"! |
2002 True Blue GT
^ Would the way you screw it on really make the difference?
no not that i could see, but i bought a brand new pan anyways!!! That way i figured it would solve any pan problems....
#8 | |
1988 Mustang GT
N/A
All the ones I've done had no problemsIt might not be coming from there. I would've picked up some transmission/oil dye, drive it around for say... 30 minutes to 1 hr and have a shop inspect to see if they can find where its coming from. No other place on the transmission is wet?
"I know that son-of-a-bitch is cheatin! Cause, I'm cheatin and he beat me"! Last edited by Modified88Dreamer; August 4th, 2008 at 04:25 PM. |
nope!!! i checked the cooling lines-dry, the dipstick tube-dry!!! I'm lost on what it could be, should i add silicone to the gasket when i reinstall it??...
1988 Mustang GT
N/A
99 PM sent
bump....
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/83149-transmission-pan-leak.html
| Transmission pan leak!!! | This thread | Refback | November 7th, 2010 01:06 PM | |
Threads Similar to: Transmission pan leak!!!
| Transmission leak! | chris1 | 4V / SVT | 11 | July 25th, 2008 06:56 PM |
| HELP Transmission Pan Gasket Leaking! | MWWarlord | V6 Mustangs | 17 | July 10th, 2008 01:22 AM |
| Transmission leak | 99spaded | 99-04 | 2 | May 31st, 2008 02:56 AM |
| Transmission Leak | Katen | Classic Mustangs | 15 | January 29th, 2008 01:50 PM |
| Transmission Leak? | 05MUSTANG4.0 | V6 Mustangs | 6 | September 3rd, 2007 07:10 PM |
