Discussing How do I tap the oil pan? in the 99-04 Forum. I need to run the oil return line to my oil pan and Im planin ...
Old August 7th, 2008, 11:24 AM   #1
Blown 03 GT
I need to run the oil return line to my oil pan and Im planin on not removin the pan. How did you guys thread your pan to get the fitting to stay?
Accufab 75mm TB and plenum, Mac Prochamber and Cat-back, Novi 2000 intercoolered MGW shifter and 18x10 w 285 Nitto 555s for some grip. Was 400+
Old August 7th, 2008, 05:09 PM   #2
Blown 03 GT
anyone?
Old August 7th, 2008, 06:18 PM   #3
help em out.... bump
00' GT Few boltons and full uxhaust including shortys
NoBAMA08 I STRONGLY DISAGREE WITH BARACKS MORAL VALUES TO OUR COUNTRY.. AND ESPECIALLY GOD...
Old August 7th, 2008, 10:47 PM   #4
2kGT's Avatar
We used a punch then used a tap to make the threads.
Accufab 75mm tb & plenum
MRT h-pipe
Flowmaster catback
FRPP king cobra clutch
FRPP aluminum driveshaft
FRPP 4.10 gear
TA Perfromance girdle
Steeda tri-ax shifter
Moser 31 spline axles
FRPP C Springs
Old August 7th, 2008, 11:15 PM   #5
FoxHoss's Avatar
02' GT
jack up your car. support it with jackstands. crawl underneath. then extend your dominant hand, then extend your index finger. now, rapidly hit your oil pan with your index finger! now you have successfully tapped your oil pan!
haha sorry couldnt resist, im not possitive, but i know this has been asked before... search?
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences
'02 GT~dd
'89 LX~still in swap mode
FOR SALE: Canfeild cylinder heads 302ci 2.02-1.60 valves 54cc combustion chambers-dual vavle springs $1200
Old August 7th, 2008, 11:22 PM   #6
FoxHoss's Avatar
02' GT
does this help?
How hard is it to remove the oil pan??
'02 GT~dd
Old August 8th, 2008, 12:44 AM   #7
Blown 03 GT
So theres enough material to make threads in? thats what i was worried about.
Old August 8th, 2008, 01:02 AM   #8
BlckBullitt01's Avatar
TT Bullitt
Just like they said. You also might wanna change the oil in case any shavings get in it.
Old August 9th, 2008, 08:22 AM   #9
2001 GT
yes use a punch that rolls the metal in so you have something to tap. its not hard just take your time and dont make it to big. put grease on the tap to hold any metal shavings.
2001 Gt,auto,J mod, 4:10s, B&M cooler, Hitech stage 2's, NX plate 100 shot, 75 mm tb, C&L upper plenum,BBK X with magnaflow's,Black FR 500,S,SCT tune from Bama chips.
Old August 9th, 2008, 12:10 PM   #10
MM's LS1 Nutswinger
rk_2000_Z/28's Avatar
+1. Do a quick mock up to find the spot you want to tap into, scratch a small 'X', and than I recomend removing your pan. That way you can properly clean out any metal shavings. It is just a little extra step that can save you a lot of problems later on.
03 Cobra-475/441 to the wheels
02 SS-Sold
00 Z/28-Totaled
Old August 9th, 2008, 05:43 PM   #11
KhaosGT's Avatar
a center punch might help you get through it a lil easier because it is pointed or at least it might get you a good hole started then you can increse the size of the punch if need be
2004 Black Mustang Gt
"I'm a agent of chaos" -Joker,Dark Knight
Old August 9th, 2008, 08:55 PM   #12
jivepepper's Avatar
On vortechs site in the support section is directions for tapping the oil pan in section for installing the s-trim on the 96-04 mustangs. It's a PDF file. It's not hard and good luck.
Spending money I don't have, on parts I don't need. to impress people I don't know....
2k MUSTANG GT 598/531 RWHP/RWTQ Just a little S-trim....
Old August 9th, 2008, 09:00 PM   #13
From the land of the wolverines
8t6gt's Avatar
1986 Mustang GT
Members Against Mods
Crew member #1
Originally Posted by White Fang
i got over 10 pm's of u talking carp and starting crap about me damn stop! get over it! stop following me around.
Originally Posted by Cricket
whats wrong with a guy who likes to fish?
Old August 12th, 2008, 10:19 AM   #14
Blown 03 GT
I drilled it out and tapped it sucessfully. Used a standard drill bit which didnt work so well, I ended up wit an oval hole. So i bought one of the cone shaped hole saws and it worked great. Then tapped it ever so carefully, Got the AN fitting set in and its all good. Get a nice tight fit too. Thanx for the help guys
Old August 12th, 2008, 12:00 PM   #15
jivepepper's Avatar
so you had the oil pan off?
Old August 12th, 2008, 12:12 PM   #16
Blown 03 GT
nope tapped it on the car, used alot of oil and cleaned the bits and tap often. Then stuck a magnet in side only picked up a few small pieces of metal. I drained the oil and then ran a spare quart through the hole to catch anythin left. Havent run the car yet, got a issues with the intercooler piping. As far as i can tell though its all good.
Old August 12th, 2008, 04:08 PM   #17
jivepepper's Avatar
Tapping isn't as scary as the drilling. Good luck with your project.
Threads Similar to: How do I tap the oil pan?
oil pan rog50stang 99-04 5 April 28th, 2008 10:30 PM
Oil Pan 91 gt 5.0 5.0 Mustangs 3 March 25th, 2008 12:06 AM
Oil Pan 95kystang V6 Mustangs 12 October 9th, 2007 12:37 AM
kickout 7qt oil pan w/low oil sensor hole Iownastang 5.0 Mustangs 2 July 19th, 2007 02:17 AM
Oil Pan Pony_with_an_attitude 5.0 Mustangs 3 March 5th, 2007 08:40 PM
