More Bad News - Page 2
Old August 9th, 2008, 04:50 PM   #21
KhaosGT's Avatar
KhaosGT is on a distinguished road
yea dude steer clear of speedtek they are a chevy shop i have been in there a couple of times and they are like what do you drive...and then i get the look from them
2004 Black Mustang Gt
When I see a 5.0...I respect my elders.
Old August 9th, 2008, 05:10 PM   #22
94pacecarSVT's Avatar
11.2@122.36
94pacecarSVT is on a distinguished road
Send a message via AIM to 94pacecarSVT
yea you shouldnt have to pull the motor to take the heads off you will just have two head bolts on each head that wont come all of the way out because of the strut tower you just gotta tape them up so they wont fall back in.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.
www.rk-collection.com
Old August 9th, 2008, 06:42 PM   #23
2003 Mustang GT
DarkDoug is on a distinguished road
Send a message via AIM to DarkDoug
Quick question about the 2valve to 4 valve motor swap you mentioned... Wouldn't he need a new PCM as well or can his old one be reflashed?
Doug
Old August 9th, 2008, 09:05 PM   #24
Mustang_GTX's Avatar
13.515@102
Mustang_GTX is on a distinguished road
Send a message via AIM to Mustang_GTX
iiiii dont know lol never done it, but would like to
Old August 9th, 2008, 09:12 PM   #25
347stroker's Avatar
347stroker is on a distinguished road
No the head bolts are too long to leave the motor in. They will have to pull the motor. You cant go wrong doing a total rebuild if you can afford it lol, like doc said its extremely extensive and expensive.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's
Mineral Gray Club Member #1
Old August 9th, 2008, 09:15 PM   #26
347stroker's Avatar
As far as a good replacement head you cant go wrong with fox lake, if thats too expensive you may just consider a p&p job, will be much cheaper. I would go with either comp cams or cms, I was told that you dont have to degree the cms cams. You may just think about stoking it while its out, would be a bit cheaper than a total rebuild I would think.
Old August 29th, 2008, 11:51 AM   #27
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
AggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really nice
Update: We pulled everything off and we have a bent valve and cracked piston. Where do we go from here? Is there any way to replace the bent valve so I don't have to get new heads? Is getting a stroker kit worth it on our enigines or should I just stay with a stock stroke forged kit? HELP!!!
Buy my:
Nitrous Accessories
Diablosport Programmer
In The Classifieds
Old August 29th, 2008, 12:21 PM   #28
Proud American
MustangMatt96GT's Avatar
yes it canbe done... Ivepulled heads in car, and even done head studs in car...
Personally, I would put in a built short block. I personally would build it my self and save a little. But no warranty. I would go with a stock crank, manley h beam forged, and pistions of 2618 alloy. Not the crappy 4032 alloy. Get some built heads or have yours portrd, and some custom ground cams. You will be set for 600-650. And ifyou want more use a different crank, although that crank is not known for failure. Intact I have never seen a motor fail from a stock crank, always something else making it fail...
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
25.3 SFI Chassis Build
Never Lift Racecars
Old August 29th, 2008, 02:03 PM   #29
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
what's the limit for the stock block?
Buy my:
Nitrous Accessories
In The Classifieds
Old August 29th, 2008, 02:06 PM   #30
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
The block can handle more then we can throw at it...The block is plenty strong...
Facebook
Google+
Old August 29th, 2008, 02:32 PM   #31
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
K so i'm thinking about just replacing the rods and pistons and porting my heads. Sound like a good idea?
Buy my:
Nitrous Accessories
In The Classifieds
Old August 29th, 2008, 02:37 PM   #32
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
If I was you then I would just go ahead and do a stroker setup while you have it all out...Now is the time to decide if you are going to stay nitrous or go forced induction later on...
Facebook
Google+
Old August 30th, 2008, 04:48 PM   #33
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
If I build up this engine i'm going to stay with nitrous BUT I found an 03 cobra engine that I might be able to drop in. So the question is: Build up the GT or drop in a cobra?
Buy my:
Nitrous Accessories
In The Classifieds
Old August 30th, 2008, 05:39 PM   #34
silver99gt's Avatar
1998 Camaro SS
silver99gt is on a distinguished road
thats an easy one. get that cobra motor. the 4v respond a lot better to mods and its already built. if the price is relatively the same you'd be a fool not to go with the cobra motor.
Old August 30th, 2008, 07:06 PM   #35
luis's Avatar
2001 GT
luis is on a distinguished road
+1
2001 Mustang GT
*Starigth 3" piping exhaust
*Steeda Lowering springs
*Mach 1 Chin spoiler
*Ram Air kit
*Functional Scoop
Old August 31st, 2008, 01:15 PM   #36
ajm
For the bolts that wont come out all you have to do is pull them out as far as you can (the ends will clear the block and come up into the head) wrap some tape around them so they don't fall back in and the head lifts right off. Same process to put them back in/put the heads back on.
Old August 31st, 2008, 01:25 PM   #37
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
it's already out
Buy my:
Nitrous Accessories
In The Classifieds
Threads Similar to: More Bad News
bad news and good news for me.. 40thmustanggt Modular Mustangs 6 August 14th, 2007 09:47 PM
Good news bad news & I can’t believe this is working Badasstang281 99-04 7 April 11th, 2007 08:34 AM
Good news, bad news, and somehelp would be nice GreenFaleen V6 Mustangs 40 April 7th, 2007 10:59 PM
bad news for him, good news for me! coreysr5 V6 Mustangs 18 February 15th, 2007 10:21 PM
Good News and Bad News scrapdaddy jr. V6 Mustangs 18 September 7th, 2006 09:34 PM
