steeda tri ax
i just did my steeda tri ax installation today and i have to tell u that it rocks the shifter is awesome great shifter i am very happy with it ,the only thing is that sometimes i miss 2 gear it went to 4th but i love it . The install was easy the hardest part was to remove the stock shifter i have some questions tho the when i set the shift stops i did it using 3rd and 4th gear is this ok also which position u think is the most comfortable the lower or high to set the shifter handle .
RLY SRS
I use the high position myself...
You will get used to shifter and everything will be good... |
Resident Bubblehead
i used all the positions when i set the stops on my tri-ax, starting with 3-4 then chacking with all the others. and i use the lower position to set the handle, its more comfortable for me
I use the lower position, also I have heard ( I think in this forum ) that with the T-3650 you are not to use the bump stops.
I went through 3 tri-ax shifter before I got fed up with them. I ended up getting a UPR blue-thunder shifter. better product, better customer service... better price.
only shifter I like more than the UPR shifter is the MGW shifter, but those aren't cheap. |
Threads Similar to: steeda tri ax
| steeda tri ax | tjames | V6 Mustangs | 10 | August 28th, 2007 03:03 PM |
| steeda cai | steedafied05 | 2005 - 2010 | 5 | August 26th, 2007 11:21 PM |
| Steeda CAI | west92 | 2005 - 2010 | 21 | January 25th, 2007 08:14 PM |
| steeda tri ax | o3gtdgs | 99-04 | 10 | November 30th, 2006 10:45 PM |
