Discussing Rear End Clunk in the 99-04 Forum. Hi guys, this is my first post after reading this site for a while. Anyways ...
Old November 23rd, 2006, 02:26 PM   #1
Rear End Clunk
Hi guys, this is my first post after reading this site for a while. Anyways im having a problem on my 2001 GT and im not really sure what it could be or how to fix it.
When i am driving and i let off of the gas pedal it seems to make a clunk sound. It feels like tension being released from something in the rear but im not really sure. The car is still stock and i dont think this is normal as everyone who gets in my car comments on it.
Old November 23rd, 2006, 02:28 PM   #2
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
U.joints
check for play in your drive shaft.
Old November 23rd, 2006, 02:32 PM   #3
u mean play in the joint itself or whether i can turn it before it catches in the transmission/differential?
Old November 23rd, 2006, 02:36 PM   #4
HMUSN's Avatar
19.83 @ 12mph
. and if your going to replace one you mght as well do the other
Old November 23rd, 2006, 07:37 PM   #5
yup. do them in pairs.
Old November 24th, 2006, 12:10 AM   #6
superbeef1000's Avatar
you can get the aluminum drive shaft with u joints all ready in it for like 250$ kill 2 birds with one stone pluss get a little more power to the wheels
best price and free shipping
http://www.americanmuscle.com/driveshaft.html
Old November 24th, 2006, 12:12 AM   #7
you might as well do the safety loop too while your at it ,,its cheep money
Old November 26th, 2006, 01:33 AM   #8
Look Ma! My First Post!
THE CLUNK YOU ARE HEARING IS THE WEAK FACTORY DIFFERETIAL BUSHINS WHEN YOU GET ON AND OFF THE GAS ITS CAUSING THE REAR TO PINCH YOU CAN TRY AND TIGHTIN THOSE BUSHING OR BUY THE MM URETHANE DIFFERENTIAL BUSHING KIT THIS WILL SOLVE THE PROBLEM YOU CAN GET THE KIT AT LETHAL PERFORMANCE FOR ABOUT 49$ BUT TRY TO TIGHTI N THEM FIRST
Old November 26th, 2006, 12:36 PM   #9
turn the caps off! He has a GT which isn't an IRS so it has no "differential bushings". Now with that being said, there is a strong possibility that the control arm bolts are loose. try tightening them and see if that helps.
88 Mustang Coupe
www.rickscarcare.net
http://img146.imageshack.us/img146/2158/ricksadql2.jpg
Old November 26th, 2006, 02:38 PM   #10
FOR POINT SIX's Avatar
would tightening the control arm bolts help a rubbing squeaking sound. I only here it at low speeds turning. IE. in parking lots. It my be doing it at higher speeds but I would not hear it over the loud pipes. I have put the car on three racks and see nothing rubbing no bushings torn or any thing. I was starting to think it was the rear end going out. I do lots of burn outs and donuts and the car is leaving more and more one wheel wonders
Old November 26th, 2006, 09:13 PM   #11
HMUSN's Avatar
19.83 @ 12mph
it might be your gears hating you.
i have the same problem right now..
for some reason my gears don't like 5k launches on drag radials...
Old November 27th, 2006, 12:37 AM   #12
I am just guessing here but my thought was the track lock ( limited slip what ever it is called) going out, but I do not want to tear any thank apart that does not have to be
Old November 27th, 2006, 09:55 AM   #13
today after i get home from class i will go ahead and check the control arm bolts, is there any special way of testing the tightness without actually trying to tighten them ? I ask because i don't want to shear the bolts if i start wrenching em down and they are already tight.
Old December 20th, 2006, 04:14 PM   #14
Well i just took my car into carmax to have the clunk looked at along with the brakes and guess what? carmax is clueless.
Their excuse for the clunk is the amount of torque from being a GT in the differential is causing this. Im not even sure how they arrived at this conclusion but to them everything is fine.
I have to look at my warranty info but if they dont fix this problem im going to take the car down to the local big ford dealership instead of the retards at carmax.
Old December 20th, 2006, 04:15 PM   #15
Old December 20th, 2006, 05:26 PM   #16
sonicblue's Avatar
1990 GT
if you are hearing a clunk when you are getting on and off the gas its prolly just slack in the drivetrain and thats perfectly normal. and the transmissions are clunky as well. you might want to take it somewhere else for a second opinion but they are prolly right with theres nothing wrong with it
getting all fixed up for next season
2004 mustang gt 520rwhp, 491 trq sold
Old December 20th, 2006, 11:09 PM   #17
idk I could not imagine being able to sell a brand new car with this. granted this car has 50k miles, I would still assume it shouldnt feel like the back differential is rocking fowards an inch every time I take my foot off the gas pedal.
Threads Similar to: Rear End Clunk
Great...clunk in the rear pass. side twok3gt 99-04 2 October 14th, 2007 04:53 PM
clunk noise Murderjetz V6 Mustangs 20 March 28th, 2007 11:59 PM
Clunk In My Rear militarygt Drivetrain 6 November 13th, 2006 08:53 AM
Clunk! MustangGTNY 5.0 Mustangs 1 October 26th, 2006 11:25 PM
Still Have A Clunk In My Rear End militarygt Suspension 7 October 9th, 2006 06:47 PM
