engine build or not? (kind of a long story)
Old August 10th, 2008, 12:43 AM   #1
the1968jeepthing is on a distinguished road
Send a message via AIM to the1968jeepthing
hey everyone! i have never owned a Mustang before and i know nothing about them. I recently aquired a really nice 2002 Roush stage 2 with only 6k miles on it for $8,500. The engine had an aftermarket supercharger on it when the oil pump failed and toasted the crank. Everything else seems to be ok. the guy who had it brought it to a shop who did a complete tear down of the engine and was about to put it back together with a new oil pump and cobra crank when they went out of business. The car sat for awhile in the shop all in peices during which point the super charger, H-pipe, and manifolds were stolen. He finally got his car back and bought a new x-pipe and headers. He was just going to use the stock intake manifold instead of the super charger. My question is this: i basically got this car to sell and make money on. could i make more money by building the engine up while it is apart and sell it for more? or should i just put it back together basically stock? would it be cost effective to buy a new supercharger? (since the car is already set up for one with the intercooler and such) If it would be cost effective to modify what parts should i change? I will be doing all this work myself but i really dont know much about these cars and any info/ input would be greatly appreciated! Thanks!
-Brian
Old August 10th, 2008, 12:46 AM   #2
347stroker's Avatar
347stroker is on a distinguished road
Mod motors are a complete pain in the ass to work on. Unless you have experience with them prob wouldnt recommend it. Just part it out or if you have the money have the shop do the work for you.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's
Mineral Gray Club Member #1
Old August 10th, 2008, 12:51 AM   #3
NMR-2vGT's Avatar
1996 GT
Too Slow....
NMR-2vGT will become famous soon enough
Send a message via AIM to NMR-2vGT Send a message via MSN to NMR-2vGT
Just go back to stock rather than build it up and sell it for more. You will put more into it than you will get out of it if you do that
1996 Mustang GT, Full PI Swap, MGW Shifter, Magnaflow Cat-back, K&N Filter
MM Unite For Bubba
Old August 10th, 2008, 12:52 AM   #4
347stroker's Avatar
would something like that show up on a carfax if he tried to sell it.
Old August 10th, 2008, 12:55 AM   #5
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
Buy a stock complete motor used. Install that and be done if you only plan on selling it for a profit.
2000 GT 665/540rwhp/rwtq
Best 1/4:
AT 431HP 12.29 @ 124
AT 515HP 11.24 @ 129
AT 638HP 11.01 @ 135
AT 665HP ??.?? @ ???
80*+day, 1400' track, 10.5" DD Cobra R's & 315/35/17DR'S
Trap speed = true measurement of HP.
Old August 10th, 2008, 01:22 AM   #6
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
my 2v was easy to work on... once i got it out of the car.. if you pull the motor, i found it easier to pull the heads prior to pulling the motor. with the heads off it is a lot easier to pull the motor, or you could drop the k-member, but like stated above, if you have never cracked a motor, make sure you do you research, putting a thrust washer in backwards, or over/under torquing a bolt, or not doing the torque sequence right on the mains/rod bolts is bad juju.
Originally Posted by Dennis View Post
i fail to see the humor here. the farve thing ok its funny. but that shit there is just fucked up.
Wow Chris. You are the square root of stupid.
Eh, I personally think 4" is too big.
Old August 11th, 2008, 10:27 PM   #7
ok, thanks, that's pretty much what i wantd to know. The engine is already out of the car, and is in peices (literally... whoever took it apart took EVERY single nut and bolt off) but all the new parts are there, ready to go back together. I have some engine experience, and i got a nice factory manual that i will use. I'll just put it back together stock. (kind of a shame, but whatever makes money i guess)
Thanks!
-Brian
P.S. the reason the engine died in the first place is because the oil pump died. the car only has 6k miles on it. Is this common? is there a reason the oil pump may have went bad?
Old August 11th, 2008, 10:29 PM   #8
mpboy's Avatar
2002 GT
99.99@999.9
Thanks!
-Brian
they can.. if they sit for a long time the can lose their prime.. but they dont really go out to often
there inst really many moving parts in the oil pump
Threads Similar to: engine build or not? (kind of a long story)
Engine Build Up or Engine Replacement... OcOnnor220 99-04 8 July 27th, 2008 04:54 PM
Time to build/buy a new long block...help! txbkr 5.0 Mustangs 6 July 18th, 2008 04:26 PM
Long story but any help would be appreciated horsewithnoname 4V / SVT 13 May 19th, 2008 02:56 AM
whats it cost to build a 347 long block 347_mustang 5.0 Mustangs 11 August 8th, 2007 05:05 AM
Funny story... kind of... topflitecop21 96-98 1 November 13th, 2006 02:59 AM
