Gas Mileage With Comp 270's?
Old August 11th, 2008, 03:23 PM   #1
Schraders is on a distinguished road
Anybody running Comp 270 cams (or similar grind from another company), what's your gas mileage like?
www.schradersspeedandstyle.com
Old August 11th, 2008, 03:33 PM   #2
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
gas mileage is all in the driver man, same goes with gears, and superchargers, and any other thing you put on. But again we didn't buy a mustang for gas mileage. So if you drive like grandma than mid 20's easy, but why buy a mustang and put cams in it and then drive like a grandma
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old August 11th, 2008, 03:55 PM   #3
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
i can get 24 with mine... or 14.. depends on what kinda week im having
Old August 11th, 2008, 06:10 PM   #4
347stroker's Avatar
347stroker is on a distinguished road
Yes sir, gas mileage is for toyota camerys and the prius. Put some cams in it and romp on it like your supposed to.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's
Mineral Gray Club Member #1
Old August 12th, 2008, 07:26 AM   #5
andres0286's Avatar
andres0286 is an unknown quantity at this point
Send a message via MSN to andres0286
I really didi not see much diference with mine, in gas mileage that is
2002 GT SOLD
2003 Mustang GT Cobra Clone SOLD
Procharged @ 8psi
458 rwhp
Mods in Garage
Old August 12th, 2008, 11:09 AM   #6
Trick Tuners's Avatar
KB'd GT
The more overlap you run, the worse mpg you will get. (worst being around 3mpg, less for mild cams). Go for it!
Old August 12th, 2008, 11:16 AM   #7
amateur adult film star
sgrcltpunk's Avatar
1999 gt
to infinity and beyond
sgrcltpunk will become famous soon enough
Send a message via AIM to sgrcltpunk
why worry about it you have a mustang if you are worried about gas go buy a Honda sorry
performance headlight fluid, 6 ball muffler bearings, and dual flux capacitors
Old August 12th, 2008, 02:07 PM   #8
Because I drive my Mustang every single day, 12,000 miles a year. If I wasn't worried about gas mileage I'd build a carbureted big block with 12.5:1 compression and a solid lifter cam with 86 degrees of overlap.
And I'm not going to buy a Honda because I'm not gay.
Old August 12th, 2008, 02:15 PM   #9
ModMustang97GT's Avatar
1997 Mustang GT
Faster than an s4
ModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura aboutModMustang97GT has a spectacular aura about
I think the gas mileage is a legitimate question. There are lots of things you can do to these cars that will get you alot of power and not sacrifice very much gas mileage. The general rule is, the more efficient your car is, the better fuel mileage you will get. However, when you start increasing cubes and adding boost, your mileage will decrease. That is why turbo's are such a popular and efficient option. They create vacume at low rpm's lowering the power and fuel consumption at low rpms. This is why they are soo good on diesel engines. But, they also bring alot of power in the high rpm's.
I have several friends with upgraded turbo's on their cars, that make better mileage because of it. Of course, they can also burn it alot faster now if they choose to. Alot is how you drive, and alot is how you plan for all of your shit to work together. The more efficient your air pump is, the more power you will make from what your putting in to it.
Aztec Gold 97GT.
MM CC Plates, Panhard Bar, SFC's & Tower Brace
Eibach Sway Bars
H&R Race Springs/Bilstein Shocks
MAC CAI, LT's, Catted H and Pro-Dumps
KB Boost-a-Spark
04' PI Motor
Author of The Official Suspension Guide
Old August 12th, 2008, 03:35 PM   #10
epconey is on a distinguished road
well i just put stage II heads and cams in mine, still running stock gears and get 15.5 mpg. And i could not have babied it any more.
Old August 12th, 2008, 03:50 PM   #11
1997 Mustang GT
Faster than an s4
You need to get your car tuned then, you are running way too rich. Its likely that your engine is not able to adjust correctly to the new set up. I have a friend with stage 2 heads and cams with LT's and CAI making 300+ whp and making 30mpg on the highway.
Aztec Gold 97GT.
Eibach Sway Bars
KB Boost-a-Spark
04' PI Motor
Old August 12th, 2008, 03:53 PM   #12
KB'd GT
Driving about 45mph?
Threads Similar to: Gas Mileage With Comp 270's?
gas mileage 1BADSTANG V6 Mustangs 6 March 26th, 2008 11:08 AM
gas mileage dgt_mustang V6 Mustangs 85 March 4th, 2008 04:07 PM
gas mileage MyBloodRunsBlue 99-04 17 January 29th, 2007 02:46 AM
