Should i flip the switch????
Old August 12th, 2008, 10:03 AM   #1
oh2swapped's Avatar
02 Mustang GT
17.8@52
oh2swapped is on a distinguished road
Well i installed my dry kit and drilled pre maf for it so the computer can adjust the fuel ratio. Im getting an itch to flip the switch. I only have the 75 jet in there right now. Im going to be getting it tuned for a 125 shot, but my money tree in the back yard is doing to well so you think it would be alright to spray the 75 shot a couple times until the tune comes?
NEXT TO SEX, MY MUSTANG IS BEST
Old August 12th, 2008, 10:44 AM   #2
AndrewA.'s Avatar
2001 Mustang GT
8.9@78
AndrewA. will become famous soon enough
Well if that money tree isnt doing that good..i would just play it safe and wait for the tune!
Fire it up, burn it down.
Old August 12th, 2008, 10:46 AM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
do you have injectors and a tune? if not then I wouldn't touch it.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old August 12th, 2008, 10:51 AM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
The MAF doesn't know if nitrous flows thru it. The MAF only measures airflow and whether you have the nozzle before or after the MAF doesn't change the airflow requirements of the engine. Dry kits are designed to use pressure against the fuel regulator for fuel enrichment. No need for a tune or larger injectors with a small amount of nitrous. Make sure you have 91 or higher octane in the tank to be safe.
Old August 12th, 2008, 11:47 AM   #5
Trick Tuners's Avatar
KB'd GT
Spraying N2O on the Maf is never a good idea. If you have the WOT and window switches setup with a wideband to monitor the AF its probably safe to give it a shot on the stock tune, but i would add a can of octane booster with 91+ in the tank, and maybe try just a 50 shot.
Old August 12th, 2008, 12:43 PM   #6
LAWNDART02's Avatar
02 GT
LAWNDART02 is on a distinguished road
I would just wait till you're totally ready with the 125 & tune. As soon as you squeeze the 75 shot your gonna start "guessing" about what it is/aint actually doing. You might think it's not as hard a hit as you expected, then think something is wrong, than loose sleep, etc..
If you know your gonna get a tune, just wait for it and milk the excitment till payday.
The difference will be much more memorable.
Old August 12th, 2008, 12:45 PM   #7
Proud American
MustangMatt96GT's Avatar
I put 104 in my tank when i go and play with my nitrous kit, but then again i am also planning on large shots 150 or so untuned for a while.
RIP Travis Billings
Special Thanks to:
Andrews Racing Transmissions
Baseline Suspensions
Never Lift Racecars
Old August 13th, 2008, 01:57 PM   #8
04' Cobra
fast
fallingaway2 is on a distinguished road
Talking
N2O
im not sure what set up or system you have but i have a zex digital setup on my 02' gt. I run a 100 shot with out a tune right now, my gt was dyno'd and air/ fuel was measured and safe without tune. had to wait on fuel pump and diablo sport tuner before tune. but ive used mine and its safe. just make sure the vehicle is at normal operating temp and dont miss a gear....
Nitrous is the shit if its done right. I left a turbo'ed gt on my non--tuned 100 shot.
Threads Similar to: Should i flip the switch????
Flip up screen 04mustang232 Audio/Video 12 June 17th, 2008 02:04 PM
how do i get the headlight switch, high beam switch, emergency switch etc out? 91cobra5.0 5.0 Mustangs 0 March 19th, 2008 10:39 PM
Belt Flip Phoenixx The Clubhouse 28 November 27th, 2007 03:06 AM
