Car sounds like it wants to stall on start up sometimes? - Page 2 - Forums at Modded Mustangs
post #21 of 32 Old August 13th, 2008, 08:34 AM
03gtfirered's Avatar
our cars are EFI so pushing pedal before turning the key does nothing. I had a similar problem in my specv and it ended up being like dizzybonne explained. i ended up changing sparkplugs, coils, and a shit ton of other things. i have learned a lot since then and throwing money at the problem doesn't always fix it! sometimes you get lucky! i just bought my 02 gt and i havent had that problem yet so well see im sure i will! goodluck with that!
______________________________
summit racing catback, bassani o/r x pipe, RAM HDX,jlt intake, mach grill delete, tinted headlights and tail lights!!
Originally Posted by TwirtleNutZ270 View Post
Dude not having a tuner is kinda like having a cake without a fork.
03gtfirered is offline
post #22 of 32 Old August 13th, 2008, 10:05 AM Thread Starter
iTrader: 13 reviews
Originally Posted by DiZzyBonne View Post
It's just called vapor lock, sometimes the car won't start after it's been warmed up and you turn it off for a few minutes. Man is that embarrassing!
Originally Posted by OneqwkStang View Post
Mustangs are notorious for this problem. I had an older fox body that did the samething. In my 03 though I have found that applying some throttle before turning the ignition over helps. Cold starts are just fine...but yeah as the ^^^^other poster said it is kinda of embarrassing when you crank over your stang, at the gas station especially when you have others who stare at your nice ride wanting to hear more of your exhaust as you pulled into the station and then exiting it. Not only to hear it putter and die and then taking another 10 seconds to crank over. When mine dies, it takes a lot longer to crank than normal, so yeah kinda sucks sometimes when it happens but trying the method I described above has worked really well for me.
I know its so embarrassing thats for sure. Mine never die but it sounds like it wants to just stall on me.
OK so what you are saying is just give it a little gas while i turn the ignition and it will start up fine?
Im hoping to change my plugs this week.
http://jmbphoto.zenfolio.com/
2011 GT - Tune by Alternative Auto
PowerShiftz02GT is offline
post #23 of 32 Old August 13th, 2008, 12:38 PM
Lightbulb
my 02' gt does the same thing sometimes....waiting on my tune, and i'll let you know.
fallingaway2 is offline
post #24 of 32 Old August 14th, 2008, 03:40 AM
03FstStngKB's Avatar
Yep, just give it a little gas on all your warm starts and it should never die. It may stumble but it should regain enough rpms to become stable enough to idle.
What you are referring to is that you don't need to push the pedal before you start...you are correct in saying that but what I am talking about and let me just clarify incase I did not make sense in my other post is that pushing the pedal down some will help the car fire over in a warm start stumble idle condition because it allows more revs to be present while cranking over. It is perfectly safe to do this and you won't damage your engine because ford will not allow the car to start at WOT...try it...it won't fire...it will only crank...this condition ONLY happens when the computer conceives the car at being at WOT.
Since I have this warm start problem I just basically give the car a push of about a quarter throttle in all my warm starts and the times that the car wants to die...it will only stumble and then regain a perfect idle state. Not every time when I start the car from a warm start will it attempt to stumble or die but I never know when it's going to do it. My cold starts are fine like I mentioned before so this method does work for me and most likely will work for anyone else with this kind of issue.
I have heard some people say that if you replace certain parts it will help but in my case it has not. If it has for you then that's great! So even though it is annoying it is not enough to make me not want to drive the car...and if it dies...well yeah it sucks but I have personally heard much worse in all my years of driving and SEFI cars are much more reliable in their starting duties then any carb. car of the past. I think once you learn how much gas you had to give those old carbs they weren't too bad but still you had to worry about flooding issues but that is whole another subject.
^^^^^^^^^My other BaBy!!!^^^^^^^^^
<---Mods List--->
4.30 Gears Installed
Mac H-Pipe Installed
40 Series Flowmasters Installed
Diablo Predator Tuned
Coming soon>>>SCT Tuned
J-mod and 3700 Stall >> ET of completion 'Spring or Summer of 09'
03FstStngKB is offline
post #25 of 32 Old August 14th, 2008, 10:49 AM
Trick Tuners's Avatar
Yeah cracking the TB plate open to allow some more air into the motor can help. All of this can be customized in the tune. If you have a tune you should talk to your tuner and have them work it out. Normally it only takes a couple trys to dial in the warm or cold starts if they are having trouble. Either add some fuel, or add some air.
Trick Tuners is offline
post #26 of 32 Old August 14th, 2008, 11:12 AM Thread Starter
iTrader: 13 reviews
Mine sounds like this but a tad worse though. Mine sounds like its going to stall more then his does. But yeah i tried giving it gas before and that always has worked in the past. its just you shouldn't have to do that to start a car. I mean its not big deal to me. if thats what i have to do then thats what i have to do. But, if i can cheaply fix the problem by changing plugs etc then that would be great.
yea Trick i dont have a tuner yet. im not sure when i'll get a tuner
Just so we are all on the same page this is kinda what mine sounds like, only a little worse^^ Mine might even take 2 seconds longer at the most sometimes.
post #27 of 32 Old January 25th, 2011, 02:03 PM
Guest
I have a Nissan 350z '05' and mines doing the same thing!! Except I got a tune up and it still does it?! Only when it's warm though. Not only embarrassing but it shouldn't do this. Anyone figure it out yet?
43181 is offline
post #28 of 32 Old January 25th, 2011, 02:46 PM
cedsks's Avatar
That same problem happened to me right after i installed my magnapac cat back, I have just learned to live with it....
2004 2v GT--3.90's, t3650, H&R SS, 78mm TB, K&N CAI, steeda bump stop kit, HP Blues shocks and struts, soon to have a rear seat delete, light weight driveshaft.
cedsks is offline
post #29 of 32 Old March 21st, 2011, 10:53 PM
redriderjf87's Avatar
Send a message via AIM to redriderjf87
Same thing happens to me, cold starts are perfect but if I start it after driving within about a half hour you gotta give it some gas to keep the idle up for a couple seconds (I stalled it a few times before realizing it). Otherwise the starter has to crank it an extra second or so, I'd like to fix this issue before I hurt my starter motor. I'm going to try looking/cleaning the IAC and look at the MAF too, does it matter if you clean the IAC with tb cleaner or wd-40 or something else? (I've heard both, just curious).
Justin
redriderjf87 is offline
post #30 of 32 Old March 21st, 2011, 11:55 PM
Chapman's Avatar
Mine has done the same thing... I saw this video (About 5 Seconds in) and looked at the first comment underneath. Basically says the engine is temporarily flooded. Is that the same type of start as in the video above? It said it was a private video so I couldn't watch it.
Chapman is offline
post #31 of 32 Old March 22nd, 2011, 12:04 AM
T-Lee. 30's Avatar
Send a message via Yahoo to T-Lee. 30
This thread was started back in 2008.
-03 GT(a) V1S trim 5psi, 3xxhp/3xxtq
-06 TBSS(DD) 4xxhp/4xxtq
-02 RC-51 (SOLD)
Iraq and Afghanistan War Vet . Convoys and convoy security. My Wife is also a Army and Afghanistan war vet.
T-Lee. 30 is offline
post #32 of 32 Old March 22nd, 2011, 12:12 AM
Chapman's Avatar
Damnit HeatherSeychelle...
Your first post in turn made me look like a dumbass......
Ban.
Chapman is offline
Human Verification
