removing fuel lines on top of the intake manifold!?!?!?
Old August 13th, 2008, 09:26 PM   #1
94pacecarSVT's Avatar
11.2@122.36
94pacecarSVT is on a distinguished road
Send a message via AIM to 94pacecarSVT
isnt there a special tool required for removing the fuel lines from the fuel rails. im tryin to get my intake off. thanks guys. and if any one knows of any easier way of getting the headers off...thats be helpful. thanks.
black 96 gt w/ non pi motor, cai, built t45, built rear end w/ 3.73's, completely modded suspension, race radiator.....startin over.
www.rk-collection.com
Old August 13th, 2008, 09:32 PM   #2
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
you just use a fuel line disconnect tool like on the fuel filter. is there a specific reason why you are taking the headers off as well?
Old August 13th, 2008, 10:54 PM   #3
mineralgraygt is on a distinguished road
you need the white fuel line tools that you can get at like autozone or pep boys
Old August 13th, 2008, 11:07 PM   #4
11.2@122.36
im takin the heads off. so far i've got everything except the timing cover, headers, and timing chains off. i think it may take me another two hours or so tomorrow night and then ill be done. so far everythings goin good. i havent had any problems and its my first time doing it, im labeling everything and all the bolts/nuts/studs are in bags labeled to what they go to. the only thing i might have trouble with is labeling the timing cover bolts. anyone done this before and know a good way of remembering which go where?? thanks again guys.
Old August 13th, 2008, 11:09 PM   #5
Trick Tuners's Avatar
KB'd GT
I use blue painters tape to tape all the bolts to the piece they come off of, or into the hole they came from, and if i'm following directions i label the step number too.
Old August 13th, 2008, 11:19 PM   #6
mm's nitrous mod
2000 mustang gt
iTrader: 8 reviews
remember the cam bolts and head bolts are tty and need to be replaced.
Old August 14th, 2008, 12:29 AM   #7
11.2@122.36
i knew the head bolts were but i didnt know the cam bolts were. i think the head bolts have been taken off and re used though because they have white lines across em like someone put on them to tell how far they were turning them.
Old August 14th, 2008, 05:03 AM   #8
homeboy2kfun is on a distinguished road
This one worked perfect for me. The smallest size should do.
Lisle AC/Fuel Line Disconnect Tool Set
Warning the KD Tools Ford A/C and Fuel Line Spring Lock Coupling Tool did not work for me.
Old August 14th, 2008, 06:58 AM   #9
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
I didnt bother pulling the fuel rails...i just wrapped up the rails in a towel and draped it off the side of the car.
Threads Similar to: removing fuel lines on top of the intake manifold!?!?!?
Removing ad at top of page. Dansby The Clubhouse 17 July 14th, 2008 01:21 AM
Removing fuel lines? Tony_90fox 5.0 Mustangs 3 July 7th, 2007 11:39 PM
Fuel Lines terribleonexx88 5.0 Mustangs 3 February 28th, 2007 10:58 PM
what should i do for my fuel system? and intake manifold? sonicblue 99-04 8 December 16th, 2006 08:59 PM
