BAP wiring upgrade needed??
LinkBack (1) Thread Tools
Old August 13th, 2008, 11:25 PM   1 links from elsewhere to this Post. Click to view. #1
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
i dont know too much about the boost a pump so i got a couple ?'s. 20 amp vs. 40 amp????? which one. wiring upgrade???? needed or not? I have a supercharged 00 gt with a procharger at 350hp. my tuner said it started running lean on him. i dont know how it ran lean. i thought that the gt supercar pump was good for at least 400 hp. its never ran lean on me at WOT. anyway my goal is to be around or a lil over 400hp. im getting the rest of the mods to get me there but needed to know which way to go on the BAP. if any1 has one they may be willing to sell ... let me know.
Old August 13th, 2008, 11:38 PM   #2
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
20 amp is for a single fuel pump, 40 is for dual pumps (cobra setup). You dont need a wiring upgrade... the bap should put you where you want to be, a little extra out of your pump. Did you change fuel filter recently? And what size injectors?
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old August 13th, 2008, 11:42 PM   #3
BakerFX4's Avatar
iTrader: 14 reviews
42lb inj. never have changed filter
Old August 13th, 2008, 11:46 PM   #4
2000 GT
Really? could be problem there lol. Dirty filter will restrict the flow. I would replace the filter and get a bap so you have room to grow, and piece of mind you wont go lean.
If filter is bad you might not even need the bap, but would suck having to go back to the tuners again.
Old August 13th, 2008, 11:46 PM   #5
BakerFX4's Avatar
iTrader: 14 reviews
ive only had the car since january or so. should i change it? who knows when it was changed prior
Old August 13th, 2008, 11:48 PM   #6
BakerFX4's Avatar
iTrader: 14 reviews
yeah the bap is a must.... why not. haha. aight good deal... thanks bro for the quick response. these things pretty simple to hook up... i did my procharger and ic install and pump install, etc. so should the bap be pretty simple?
Old August 13th, 2008, 11:57 PM   #7
2000 GT
Baps easy. Only thing that will take awhile is hiding the wire to reach the engine bay for the hobbs sensor (if you use it). Other stuff is simple splicing to the fpdm and a ground.
I would replace the filter, might as well. Cheap and worth it. Who knows when it was changed last...
Old August 14th, 2008, 12:58 AM   #8
supercharged03gt's Avatar
2003, Mustang, GT
supercharged03gt is on a distinguished road
you might want to call kenne bell and talk to them. i have a focus pump with 425 rwhp i went lean and got the bap. kenne bell told me to get the 40 amp. if i were you I would just go with that. its only a few bucks more anyways.
Mods: Vortech V-1 supercharger, BBK LT headers, BBK o/r X pipe, Flomaster cat back, 4:10 gears, Centerforce clutch, Fidneza aluminum flywheel, K-member, Eibach pro kit, MM caster camber plates, Eagle F1 tires 275 & 315.
Old August 14th, 2008, 11:52 AM   #9
Trick Tuners's Avatar
KB'd GT
If you have plans for more power in the future, go with the 40A, wire upgrade, and wire it pre-fpdm with no hobbs switch so the tune can adjust the fuel volts.
Old August 14th, 2008, 03:23 PM   #10
BakerFX4's Avatar
iTrader: 14 reviews
aight cool good info. I just thought the 40 amp could not be used on a single pump.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/84452-bap-wiring-upgrade-needed.html
Recent Faves Tagged With This thread Refback February 25th, 2009 10:20 AM
Threads Similar to: BAP wiring upgrade needed??
KB BAP wiring 00silvergt 99-04 1 June 6th, 2008 02:15 AM
79 Mustang Cobra Wiring Diagram needed! xsystemx 5.0 Mustangs 5 May 15th, 2008 06:53 PM
Mustang Stock needed upgrade DeSMustang 5.0 Mustangs 14 May 14th, 2007 09:36 PM
Advice on body upgrade to 99 needed Buddydank 99-04 7 March 14th, 2007 12:04 AM
