Discussing procharger power pipe in the 99-04 Forum. Draw thru ones are designed to have air pulled thru the sensor (stock/Lmaf) blow ...
Old August 15th, 2008, 10:36 AM   #21
MATT02GT's Avatar
Draw thru ones are designed to have air pulled thru the sensor (stock/Lmaf) blow thru are designed to have air forced thru (boost). And you want your maf after your s/c and intercooler to get an accurate reading. You would most likley lean the engine out because its reading the air in the inlet rather than the actual compressed air entering the motor.
Old August 21st, 2008, 02:38 PM   #22
94stang's Avatar
2002 gt supercharged
doesnt vortech run a draw through... don they also sell a kit with a aftercooler... i think you could tune around it..
2002 mustang gt 5speed, procharged...Fun
PRO-M Blowthru Maf for 42lb with iat sensor! must go trade for LMAF!!
1999-2004 supercharger kit for sale. plus extras! check out my garage for details
Old August 21st, 2008, 03:31 PM   #23
Eagle2000GT's Avatar
OK I'm confused. I just looked up Anderson Power Pipe for Procharger to make sure I remembered correctly. It's an inlet pipe and doesn't go anywhere near the MAF (at least on my set up it doesn't).
latest tune: 370 rwhp/377 rwtq
Garage: http://www.moddedmustangs.com/forums...-member-11329/
Previously Owned:
1966 Coronet 500, 426 ci est. 290-300 rwhp
1969 Camaro RS/SS, 350 ci est. 210-220 rwhp
Today is the real muscle car era.
Old August 21st, 2008, 03:45 PM   #24
Blown 03 GT
You can connect the MAF to the inlet of the power pipe, I dont think AFM pipes are designed for that. Once you interecool and start makin more power the blow thru design is better.
Accufab 75mm TB and plenum, Mac Prochamber and Cat-back, Novi 2000 intercoolered MGW shifter and 18x10 w 285 Nitto 555s for some grip. Was 400+
Old August 21st, 2008, 06:39 PM   #25
MATT02GT's Avatar
Correct, far from the MAF
Old August 21st, 2008, 09:42 PM   #26
Originally Posted by 94stang View Post
if i got the power pipe for my procharger kit does/could i mount the maf in the fender(draw thru)? if so does anyone know what it would take? or what size maf i would need? would a 90mm lmaf work?
sorry if i should have put this under power adder...
I think we much have really confused the OP talking about Paxton and Vortech draw throughs, that the LMAF was designed to be a draw through, and that someone converted a ProCharger to a draw through. At least it confused me.
The ProCharger system is a designed to be a blow through system. The MAF is mounted in the fender well (that's were the ProCharger kit puts it). The Lightning MAF is one of the two that ProCharger recommends for 10 psi or more (even though it may have been designed as a draw through its used in the blow through location). And, the power pipe will fit just fine on the inlet side of the ProCharger without any changes to the MAF which is on the outlet side of the intercooler between it and the throttle body.
Previously Owned:
Old August 22nd, 2008, 11:33 AM   #27
MATT02GT's Avatar
Threads Similar to: procharger power pipe
What power pipe to get?? 03_StangGuy 99-04 2 July 28th, 2008 02:12 PM
New Goods (Power With Procharger) jrock 99-04 9 December 10th, 2007 12:44 PM
Power Pipe MATT02GT 99-04 20 July 16th, 2007 11:14 AM
Power pipe Pony_with_an_attitude 5.0 Mustangs 4 March 24th, 2007 02:58 AM
Vortech or Procharger which adds more power? The6ftTallAZN V6 Mustangs 1 August 17th, 2006 07:21 PM
