Discussing procharger power pipe in the 99-04 Forum. if i got the power pipe for my procharger kit does/could i mount the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2002 gt supercharged
if i got the power pipe for my procharger kit does/could i mount the maf in the fender(draw thru)? if so does anyone know what it would take? or what size maf i would need? would a 90mm lmaf work?
sorry if i should have put this under power adder...
2002 mustang gt 5speed, procharged...Fun ![]() PRO-M Blowthru Maf for 42lb with iat sensor! must go trade for LMAF!! 1999-2004 supercharger kit for sale. plus extras! check out my garage for details |
no it doesnt procharger where set up for blow thru. you would have to conver the system to draw thru. i seen a thread on another site the but i think bought a coupler and moved the maf to the fender well. i think you also need the metal adapter to bolt a filter too and if your are already tuned for a blow thru you would need a retune.
I run a 90mm Lighting MAF in the fender with my Procharger
Its not how fast you drive, but how you drive fast. 2002 Mustang GT... Just The Usual Bolt-Ons
Blown 03 GT
Im not sure what you guys are referin to wit draw thru, blow thru, but I know its best to have the maf as close to the intake as possible.
Accufab 75mm TB and plenum, Mac Prochamber and Cat-back, Novi 2000 intercoolered MGW shifter and 18x10 w 285 Nitto 555s for some grip. Was 400+
#5 | |
1999 gt
stock
blow thru is maf after the s/c |
i know i would have to buy the adapter from jegs or somethin but is there room and what size is the anderson pipe...blow thru FTMFL! atleast for my setup...
Look into a Lighting maf. Works great with my setup
thats what i am getting... how did you make yours work?
Blown 03 GT
Why do you say that about the blow thru? The air properties change after they go through the s/c and if you have an intercooler its even worse. The closer you cant get the MAF to the intake the more accurate the reading will be.
Mine is in the fender, just be sure you got a decent amount of straight pipe before and after the sensor, if its by the the curves in the pipes it can mess up its reading.
because there is almost no strait areas on a procharger set up. like matt stated..
matt do you have any pics? or paets you used
Yea theres not much to work with. The lower pipe goes into the coupler further than it looks, and theres a decent straight pipe after the sensor.
Mine's in the fender too. They used a Diablosport MAFia instead of a Lightning MAF to get my A/F right.
latest tune: 370 rwhp/377 rwtq Garage: http://www.moddedmustangs.com/forums...-member-11329/ Previously Owned: 1966 Coronet 500, 426 ci est. 290-300 rwhp 1969 Camaro RS/SS, 350 ci est. 210-220 rwhp Today is the real muscle car era. |
Yea the Mafia is an ok tool, its more like a band aid for the maf. Ive seen stock mafs peg out with the Mafia.
Blown 03 GT
Theres plenty of straight pipe goin to the t/b thats another reason im goin with the blow thru setup
Yea either way can. I might switch to a blow-thru later down the road with more boost. But this setup has got me over 420rwhp so i cant complain.
what? that's what your set up is that right now or am i missing something?
The lightning maf is still a draw through not a blow through
#19 | ||
what that doesnt really make sense to me...
also what size maf can i use?
#20 | ||
Blown 03 GT
Threads Similar to: procharger power pipe
| What power pipe to get?? | 03_StangGuy | 99-04 | 2 | July 28th, 2008 02:12 PM |
| New Goods (Power With Procharger) | jrock | 99-04 | 9 | December 10th, 2007 12:44 PM |
| Power Pipe | MATT02GT | 99-04 | 20 | July 16th, 2007 11:14 AM |
| Power pipe | Pony_with_an_attitude | 5.0 Mustangs | 4 | March 24th, 2007 02:58 AM |
| Vortech or Procharger which adds more power? | The6ftTallAZN | V6 Mustangs | 1 | August 17th, 2006 07:21 PM |
