Boost gets you laid
my car misses at low rpms/boost
ok, i took my car back to the tuner because it "trailer hitches" at constant speeds when i'm cruising with no load on the engine. we determined that its likely the injectors misfiring when there isn't very much fuel pressure. it runs fine when i step on the gas but when just cruising normally it misses every second or so and its annoying. so my question is, is there any way to increase the fuel pressure? it goes down to about 30psi when i'm not on the throttle hard, and whenever it dips below 30 is when it misses a little bit. if i could raise my mininum fuel pressure up to about 40 i think it would run fine. anyone know what i can do? it has 42lb injectors by the way with a procharger. will different injectors like ford lightning injectors run at lower fuel pressures? my tuner said that if all else fails just sell my injectors and buy a set of green top 42's. but i'd rather not tear it apart and waste the money
![]() '01 GT. Just a couple Bolt-ons. 0rwhp 0rwtq. Epic Turbo build in progress 2003 Rubicon (wheelin rig) 2008 Silverado 4x4 (towin rig/road queen) 2009 KTM 450 XC-W (Brap Brap!) |
2000 GT
He can change the fuel pressure. At rpms he can change fuel pressure to different rates. At least he should.
Trick tuners used a complete different fuel pressure function. And the tune i got from MPH had the fuel pressure edited also to higher. Someone else could chime in. Also i heard draw through mafs with the centri blower sometimes causes drivability issues.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
yes he can change fuel pressure at different rpms, loads, and boost levels
and if he cant fix it, put 42s in it and go to a different tuner
#6 | |
KB'd GT
Threads Similar to: my car misses at low rpms/boost
| car is hesitating while in low rpms | 20gtvert03 | 99-04 | 3 | June 25th, 2008 02:08 AM |
| Low Compression High Boost? | e3sean | 5.0 Mustangs | 19 | November 19th, 2007 02:13 PM |
| Vibration at low RPMS..... hmm | Ole Yeller | V6 Mustangs | 8 | June 15th, 2007 06:53 PM |
| Car is messing up at higher rpms, every so often | GStam66 | 99-04 | 33 | May 16th, 2007 04:18 AM |
| 1998 Mustang GT - Car Misses | cranberry | 96-98 | 19 | September 18th, 2006 10:47 PM |
