Discussing Widest tire accepted in our year? in the 99-04 Forum. Originally Posted by Trick Tuners Something is wrong. I had 295/35/18 BFG DRs ...
Old August 18th, 2008, 03:20 PM   #41
mustangmanic's Avatar
13.334 @ 106.27
Originally Posted by Trick Tuners View Post
Something is wrong. I had 295/35/18 BFG DRs that would hold 400 hp on a 2nd gear roll on. Even first would hook hard. I'm pretty sure you are not supposed to run anything over a 305 on 10" wheels. You technically need 10.5" for 315s.
i have the street tires man. not the dr's
thats why shes spinning
Accufab 75mm TB and Pleunm, JLT cai, Steeda Caster Chamber Plates, Eibach Sportline Springs, Tokico Shocks/Struts, Steeda Tri-Ax, FRPP Aluminum Driveshaft, FRPP 3.73's, Hooker LT's, Hooker O/R X, Pypes Violator Catback, SCT Xcal 2. 280rwhp 302.1rwtq
Old August 18th, 2008, 03:44 PM   #42
Authorized Vendor
Trick Tuners's Avatar
KB'd GT
problem solved, get the DRs and call it a day. I would guess that a 195/35/18dr will hold better than a 315/35/18 street tire. Its like someone poured super glue all over your tires!
SCT Custom Tuning, JLT intakes, Aeroforce Interceptor OBDII gauges and PLX wideband products @ Trick Tuners
email joe@tricktuners.com
PM for super MM member deals!
Super Cheap Motorsports Camera to record the Action!
Old August 18th, 2008, 03:45 PM   #43
I have 295/35/18 bfg kdw's and 4.10's and I get traction.
Old August 18th, 2008, 03:57 PM   #44
jlaw98gt's Avatar
^^^^rocks acoustic when drunk
Good freakin god. All you freakin haters and disbelievers GTFO of my thread now. i've had so much bullshit over you kind of people.
w/o my alum ds, i only made 271rwhp, so that helped alot.
But honostly, GTFO cuz you ppl are ignorant.
wow, relax tiger...
Old August 18th, 2008, 04:00 PM   #45
Blown 03 GT
You Really Have To Research This To Get The Most Rubber On The Ground. 305 18s Have A Larger Footprint Than 315 17s. It Has To Do With The Side Wall Height That Affects The Way The Tire Rests Under Load. I Believe It Also Varies By Brand So You Really Need To Look Into Your Options.
Accufab 75mm TB and plenum, Mac Prochamber and Cat-back, Novi 2000 intercoolered MGW shifter and 18x10 w 285 Nitto 555s for some grip. Was 400+
Old August 18th, 2008, 05:08 PM   #46
Authorized Vendor
KB'd GT
But having more sidewall on a 17" wheel (same final tire diameter) will get better traction because the sidewall can give.
Old August 18th, 2008, 05:16 PM   #47
Blown 03 GT
Tru, however and im using Nittos size for this comparison, the 17 when compared to the 305 18 option with the smallest side only has .18" more sidewall. you could get a higher profile and eaisly beat that. If you go to the next profile size, 40 up from 35, you gain almost a half inch in side wall and have the same size foot print. So it depends on a lot.
Old August 18th, 2008, 06:12 PM   #48
13.334 @ 106.27
Originally Posted by jlaw98gt View Post
wow, relax tiger...
you would be pissed too if you spend every dime of your $ on your car in means of making power.
I get so much disrespect from ppl like you and its very annoying
and thanks for the sarcasm
Old August 18th, 2008, 06:41 PM   #49
MineralGreyGT's Avatar
^ first off I think we all have the same disease thats why we're all members on this thread, second of all I just personally thought your numbers were a little high but I gave you the benefit of the doubt, thats why I never said anything. And take a chill pill no need to get all riled up over something silly. However I still think CA will make a world of difference in your traction issue.
http://img294.imageshack.us/img294/5601/sig2copybg7.jpg
Studies show that 92% of kids listen to rap. If you are one of the 8% who still listens to real music put this in your signature.
Old August 18th, 2008, 06:47 PM   #50
HMUSN's Avatar
91 Sonic Blue Goodness
19.83 @ 12mph
I think I know your problem.
try not fully flooring it in first.
roll into WOT instead of popping the clutch ( if you have a 5 spd) and hammering it.
try that and see if it helps you any.
Old August 18th, 2008, 10:20 PM   #51
00gtCoolGuy's Avatar
14.211 @ 93.0...4800-5000 FT D.A.
get some Drag Radials
the nitto's are good if you want to run them everyday, but in the grand scheme of things they aren't shit compared to the m/t, m&h, and hoosier dr's
if you want something for track use, then go with one of those
4.10's, Hoosier DR's (stock intake, stock exhaust)...nitrous kit awaiting install
Old August 21st, 2008, 10:17 AM   #52
jlaw98gt's Avatar
and my numbers are still better than yours
Old August 21st, 2008, 10:32 AM   #53
HMUSN's Avatar
19.83 @ 12mph
^ I could say the same about yours but I won't
opps.
Old August 21st, 2008, 09:28 PM   #54
jlaw98gt's Avatar
Threads Similar to: Widest tire accepted in our year?
Widest tire that'll fit... homebrewed The Clubhouse 8 May 11th, 2008 12:22 AM
What is the WIDEST Tire I can run on a mustang TASSY5 2005+ 21 February 27th, 2008 09:20 PM
Whats The Widest Tire You Can Fit On An 88 Mustang? random hero 5.0 Mustangs 29 December 3rd, 2007 10:38 AM
widest tire for the 2005 17" wheel? catchtheroadrunner 2005+ 22 March 9th, 2007 05:41 PM
Widest Rear Tire 02 GT With Sportline Springs Quarterhorse 99-04 4 October 3rd, 2006 06:39 AM
