sea foam ???????
hey guys i'm gonna change my oil 2morrow and i heard sea foam works just as good if you put it in through ur oil fill b4 you change it is this true and how much should i put in and how long should i run the car with it in there
MM MACH 1 CREW MILITARY CREW |
2000 GT
do 1/3 in vacuum line, 1/3 gas tank 1/3 valve covers. Run it till you suck the 1/3 of can up. Dont stall the motor sucking it up, do it slowly. Then turn car off wait like 10 mins then run it till smoke stops. Drive around for a little while then get your oil changed.
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
Just as he said, put a third in the gas tank, a third in the vaccum line, make sure you suck it in slowly, and then the other third in the oil.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
Genibus Nitito Canus
what exactly does sea foam do?
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete ![]() |
so me just puttung the whole bottle in the oil wont do anything
04 gt dsg
what vacuum line do you put it in?
04 Cobra
i usually put thru break booster line.
![]() 04 Redfire Cobra SVT - JLT RAI, Bassani Catted X,Borla Stingers, MGW STS, Tune 08 Mazdaspeed 3 - Too many boltons - SOLD 00 Mustang GT - Too many boltons - Traded |
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
you gotta find a vacuum line that feeds all cylinders otherwise your just cleaning a couple cylinders. lol but if they lead to the intake mani then you should have no problem feeding all! seafoam cleans EVERYTHING. the smoke will even clean your exhaust. SEAFOAM FTMFW!
so will just pouring the whole bottle into my oil filler work just as good
#10 | |
Cigar Assassin
nope. do the 1/3,1/3,1/3 thing to get the best results. then you don't want to drive it more than 100 miles after you put it in the oil. |
which vacuum like though and where is it located.....and will putting it in the gas make it smoke until that tank is gone
Cigar Assassin
putting it in the gas will clean the fuel system (lines, injectors)
on the GT we put it in the vacuum line that runs from the passenger side PCV valve to the plenum. not sure if it is the same on the mach 1 |
does anyone know where the pcv valve is on the mach 1
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
check the other thread you asked the same question in.
Threads Similar to: sea foam ???????
| What do you guys think about sea foam? | 50fanatic | 5.0 Mustangs | 19 | June 10th, 2008 03:04 PM |
| Sea foam | flattusmaximus78 | 94-95 | 3 | May 15th, 2008 08:22 AM |
| Sea Foam | Corey | 5.0 Mustangs | 5 | April 17th, 2008 03:32 AM |
| how to sea foam ?? | 96gtponyred | 96-98 | 5 | July 22nd, 2007 01:53 PM |
| Help after using sea foam... | 04GTAMPA | 99-04 | 4 | June 7th, 2007 11:16 PM |
