Intercooler & Methanol Cooling OVERKILL??
Old November 26th, 2006, 03:49 PM   #1
NewEdgeGT's Avatar
NewEdgeGT is on a distinguished road
Send a message via MSN to NewEdgeGT
I'm Looking At Buying A Procharger P-1SC w/3 Core Intercooler And Am Wondering If Its Possible To Add On Additional A Methanol Cooling System Like Snows Boost Cooler Stage-2? Would This Be Overkill With The Intercooler? Any Ideas?
Old November 26th, 2006, 04:02 PM   #2
03 Mustang GT Twin Turbo
10.43 @ 139mph
WAVEBYE is on a distinguished road
Send a message via AIM to WAVEBYE
nah thats what i'm putting on mine. what kinda boost you runnin?
Nobody gonna take my car
Im gonna race it to the ground
Nobody gonna beat my car
Its gonna break the speed of sound
Oooh its a killing machine
Its got everything
Like a driving power big fat tires
And everything - Deep Purple
Old November 26th, 2006, 04:03 PM   #3
NewEdgeGT's Avatar
I'm going To Be Running 9-10 psi, for the start till I Build The Motor For More
Old November 26th, 2006, 04:22 PM   #4
10.43 @ 139mph
yeah that should be fine then. i almost went with the mr. freeze kit from anderson until i heard they sucked
Its got everything
Old November 26th, 2006, 07:55 PM   #5
NewEdgeGT's Avatar
I've Heard Good Things About Snow's Products. There Is A 11sec Duramax In Town Here, With Snow Products, Says The Kits Are Almost Fool-Proof
Old November 27th, 2006, 07:45 AM   #6
Drgnracin72's Avatar
def go with snow products, but there is no advantage or reason to run the intercooler and the boost cooler. they are doing the same thing. both cooling the air. your not gonna get the power from the meth unless your just running from the blower to the tb. waste of money in my opinion. you might make a couple hp but tis not gonna be near what that advertise. nowhere even close
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old November 27th, 2006, 01:23 PM   #7
yknot is on a distinguished road
I don't think so....They are not the same thing. The inter-cools job is to cool the intake air charge. This is necessary on a blown motor because the higher you squeeze the air to make more boost, the hotter the air gets. And the curve is not at all linear, it's experiential meaning the amount of heat produced at 2psi is not double at 4psi, it is 4 times the amount!
The Snow kit (which I had one for my Dodge diesel), works on a different principle. The alcohol in the water spray vaporises very fast and that vaporisation helps cool the intake air charge, but they rely on the kits ability to suppress detonation for HP gains. Meaning you can get by running more advanced ignition timing while at the track. But the kit isn't practical for everyday street driving, because you will go thru the small container of water/alcohol very fast, and if you don't back the timing down then you will have a big problem.
I would invest in a good inter-cooler system, and then latter if you feel the need, invest in a water spray system. Trust me, they sound much better then they really are, I know.
Old November 27th, 2006, 11:02 PM   #8
NewEdgeGT's Avatar
Thanks For The Info YKNOT, I Had Actually Been Wondering About Daily Driving, This Car Sees Both Street & Strip Action. I Know The Intercooler Will Work Just Fine, And Definately Does Its Job, Just Always Looking For That Extra Little Assurance I Guess
Old November 28th, 2006, 09:41 AM   #9
i wouldnt do it. its not worth the cost of the retune and the snow kit.
RIP
ΜΟΛΩΝ ΛΑΒΕ
SHEEPDOGS
Threads Similar to: Intercooler & Methanol Cooling OVERKILL??
Water Methanol Injection 95StangMX 5.0 Mustangs 8 November 13th, 2007 11:12 AM
water / methanol injection slowmotion00 Modular Mustangs 2 October 30th, 2007 04:14 AM
methanol injection jasperstang308 5.0 Mustangs 8 June 16th, 2007 07:06 AM
Methanol Injection Haggis13 5.0 Mustangs 4 September 18th, 2006 10:04 AM
Methanol Injection 173speed General Tech 10 June 30th, 2006 12:55 PM
