Discussing 4:30 Gears in the 99-04 Forum. Originally Posted by EThompson6 I think 4.30's are way too much gear for ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
2003 Ford Mustang GT
After Stall'd>>13.50??
4.30's are a must for an auto IMPO. It is a great street gear and you can still cruise under 3000 rpms if your not a manic on the highway. Drag racing is a different story though. Manuals can get away with 4.10's and still trap pretty high in the 110+ mph range before running out of rpm's. If your going to trap higher than 105+ mph with a 4.30 geared auto then you need to either choose or downgrade to a taller gear or increase the overall diameter of your tire...these two things will get your revs back down so that you may increase your top end speed.
![]() ^^^^^^^^^My other BaBy!!!^^^^^^^^^ <---Mods List---> 4.30 Gears Installed Mac H-Pipe Installed 40 Series Flowmasters Installed Diablo Predator Tuned Coming soon>>>SCT Tuned J-mod and 3700 Stall >> ET of completion 'Spring or Summer of 09' |
#22 |
2003 Mustang GT Con.
well i have 315's in the rear for tires with a manual so i should be able to get my revs back down for higher speeds
SLOW!! Magnaflow Cat Back, BBK Shorty Headers, BBK UD Pulleys, JLT CAI, MSD Coil Packs, Bullitt Deep Dish **Soon to Have** 3:73 Gears, Eibach Springs, Tokico D Specs, MGW Shifter, Mac Prochamber, Zex Wet Kit WHAT I REALLY WANT: BOOST! |
#23 |
13.422@103
the reves between a stock 245/45r17 tire and a 315/35r17 tire will be about the same. they are the close to being the same diameter.
![]() Mineral Gray Club Member #3 Winter Plans= FRPP 31 spline trac lok, Moser 31 spline axles, FRPP 3.73 gears. 256RWHP, 299RWTQ All Mods In My Garage |
#24 |
False. Good gear for a N/A car, especially an automatic.
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
#25 |
yea not plannin on gettin a blower...maybe some nitrous but still deciding
#26 | |
![]() Mods: Fidanza Al Flywheel, Steeda UDP, EMP/Stewart Components WP, PP Plenum, K&N FIPK, Mac Prochamber, Pypes Violator Catback WhtPny's Videos
#27 |
13.422@103
i beleive a 245/74R17 is 25.71" in dia. and a 315/35R17 is 25.79" in diameter so that little bit wont effect the rpms at all.
#28 |
yeah i checked it on the calculator and it was identical, good info man
#29 |
13.422@103
i found that out researching tires trying to find a larger diameter tire for the back of my car. it looks like i still have the stock springs in the back after putting my roush lower control arms in.
Threads Similar to: 4:30 Gears
| used 3.55 frpp gears (gears only) | notchabovechevy | Drivetrain | 7 | June 28th, 2008 11:02 AM |
| GEARS GEARS GEARS!!! 3.55s to 4.10s wanted | GeNos86GT | Want to Buy | 1 | February 15th, 2008 10:53 AM |
| gears | sk8flip67 | 99-04 | 3 | February 12th, 2008 12:19 AM |
| 3.73 gears or 4.10 gears? I need to get away from the 3.31's | 07torchgt | 2005+ | 91 | November 11th, 2007 01:25 AM |
| Gears | RandoGT | Drivetrain | 7 | July 18th, 2007 07:36 PM |
