Discussing questions on procharger pulleys. in the 99-04 Forum. white.... good deal bro... that is one in the middle. i dont have a forged ...
Old August 19th, 2008, 01:23 PM   #21
white.... good deal bro... that is one in the middle. i dont have a forged bottom end so you think that much boost may be a lil hard on it or will it be ok?
Old August 19th, 2008, 01:29 PM   #22
~C~
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
Originally Posted by White99stang View Post
try to find a 3.12 pulley, thats what i had on mine and it was seeing between 12lbs and 15lbs.
I thought I was going to have speak for you from what you taught me! Thanks for chiming in.
And to answer your question, I have a 3.0 pulley which I wouldnt put on with out forging.
BLOWN Bumblebeast!
370 rwhp and 381 ft lbs
Sneaker Crew #8
Professor C
MILITARY CREW
LT
"Like the blind man says......We shall see...."
Old August 19th, 2008, 01:35 PM   #23
i might need to go to like a 3.20 size then. 13 or 14#s would be a lil much for the stock bottom end.
Old August 19th, 2008, 01:48 PM   #24
94pacecarSVT's Avatar
11.2@122.36
baker i sent you a pm bout a 3.20 pulley if you are interested. check it out and tell me what you think.
black 96 gt w/ 00 gt motor, procharger p1sc 11lbs intercooled. comp cams xe274h .500 lift, full bolt ons, full tubular/alum. susp. w/ coil overs. 4 pt. roll cage. more pic and full list of mods in garage.
www.rk-collection.com
Old August 19th, 2008, 02:06 PM   #25
k cool... i wrote you back.
Old August 19th, 2008, 02:20 PM   #26
Blown 03 GT
I just ordered a 3.2" for my novi 2000. After all my diggin it seems that will give me around 10-12#s and should get my just over 400rwhp. I got a 03 GT btw wit mid and cat back, t.b and plenum and upgraded MAF.
Accufab 75mm TB and plenum, Mac Prochamber and Cat-back, Novi 2000 intercoolered MGW shifter and 18x10 w 285 Nitto 555s for some grip. Was 400+
Old August 19th, 2008, 02:24 PM   #27
i heard that. good deal. yeah ive been reading some peeps saying that the 3.90 pulley is for 10#'s and then read someone say the 2.90 pulley is for 10#'s. Its going to vary from application to application but damn.... thats some serious varying.
Old August 19th, 2008, 03:04 PM   #28
Blown 03 GT
I called paxton, since i have a novi and told em im shooting for 10psi wut size pulley should i get and i think he said 3.25" Anyway richards racing makes 3.2 and 3.3 so i went with a 3.2 Id rather be higher than lower on the boost. You best bet is to talk to the manufacturer. Its goin to vary with application but you should be able to get a good idea.
Old September 18th, 2008, 12:04 AM   #29
Shibby50's Avatar
bumping this thread cuz i have most of the same mods and a p1-sc procharger, i have th stock 3.85 and want to go to a smaller pulley. im running 8psi on the stock pulley and i want to get a 3.2 how much boost do you think that will up me and where can i get a quality 3.2 6-rib pulley, any help appreciated and i leared alot from this threat thanks
2000 GT Convertible
Lowered 1.8in. Procharger P1SC 8lbs, Bassani X-Pipe, Flowmaster Mufflers, 42lb injectors, full sub-frame connectors and x-brace
Winter mod list: Gears, stall, 3.2 pulley, 75mm tb & plenum, wideband, headers & ory
Old September 18th, 2008, 01:24 AM   #30
B0B
B0B's Avatar
2001 Mustang GT
the speed of smell
the 3.2 should put you around 11-13 psi. i haven't checked places where you can get them but i would look on superchargersonline.com or google it and you should see quite a few options and prices..
on a side note - i was messing around with my car today just rippin around on some back roads and i noticed that by the time i was hitting 6k rpms my car would make somewhere between 10-11 psi. anyone know why its that high? i'm running the 3.85 pulley and its only supposed to be @ 8. i even checked before i installed it. its definitely a 3.85 pulley. my car made more power than most other people on here with the same pulley too. i don't know why??
'01 GT
P-1SC 383rwhp, 380rwtq
2003 Rubicon (DD)
05 Suzuki SV650S 55mpg
moddedmustang's drunk story teller
www.myspace.com/jeepwheelerbob
Old September 18th, 2008, 09:39 AM   #31
Shibby50's Avatar
where you live, i know altitude makes a big difference on psi numbers, you could have alot higher psi with the same hp
2000 GT Convertible
Old September 18th, 2008, 10:00 AM   #32
Shibby50's Avatar
I looked at superchargersonline.com but they dont have procharger specific pulleys, are procharger pulleys the same as another certain brand pulley like vortec?
2000 GT Convertible
Old September 18th, 2008, 10:05 AM   #33
Eagle2000GT's Avatar
I'm running the stock pulley (3.85?) for 8 lbs of boost. It actually dynoed at 8.9 psi.
When the Procharger kit was first installed (with 42 lb injectors and a 255 lph fuel pump) it made 385 rwph/370 rwtq with just a 75mm TB/Plenum and a electric water pump. But the A/F mix was off. It was tuned rich mid-range to keep from going too lean at 6000 rpm.
I then put on LTs, catted x-pipe, and a MAFia with everything else the same. The first pull was almost exactly the same as before 385/370. After the A/F mixture was fixed, it made 370 rwhp/377 rwtq but I picked up 15-20 hp mid-range. But I was told that I'm running fairly conservative timing. Funny thing though, headers didn't seem to make any difference at all.
latest tune: 370 rwhp/377 rwtq
Garage: http://www.moddedmustangs.com/forums...-member-11329/
Previously Owned:
1966 Coronet 500, 426 ci est. 290-300 rwhp
1969 Camaro RS/SS, 350 ci est. 210-220 rwhp
Today is the real muscle car era.
Old September 18th, 2008, 12:04 PM   #34
Blown 03 GT
I made 13psi wit a 3.2 inch pulley and AFM power pipe. Went of the recommendation of reichards racing. He was pretty much dead on.
Threads Similar to: questions on procharger pulleys.
installing my procharger!!! few questions though. B0B 99-04 13 July 24th, 2008 09:29 AM
Underdrive pulleys and a Procharger mustangjl 99-04 2 May 21st, 2008 04:55 PM
Procharger Questions MATT02GT 99-04 12 September 27th, 2007 11:36 PM
pulleys worth it? FEW questions joojoo84 99-04 15 April 5th, 2007 08:33 PM
Procharger Questions hawks05 99-04 5 March 7th, 2007 12:26 AM
