LinkBack (1) | Thread Tools |
#41
hah man like 155,000... i bet there the original plugs too
#42 |
if it keeps leaking oil im guessing valve cover gasket? or valve stems?
#43 |
2000 GT
Remember you will need nipple fittings with the catch can also (so it can hook up to the hoses), and to not cause a vacuum leak. Its pretty easy to figure out. Just gotta make sure arrows point to the manifold (otherwise you will block the air flow).
2000 Black convertible GT: KB 15psi, and other goodies... ![]() 1971 Datsun 240 z: Header and rebuilt motor. (The DD) |
#44 |
2000 GT
Yeah its a lot of miles probably trashed plugs.
If it keeps oil fouling (after you put in catch can) i would do a compression tests. Alright bed time, ill check on the thread tomorrow after work and night to see how your car is doing!
#45 |
2002 MUSTANG GT
14.2@100
![]() iTrader: 1 reviews
maybe the gasket for the vavle cover is leaking on that side. its a stretch but could happen. id have to examine the car to really tell. good luck.
#46 |
ok so changed the plugs... no more bucking so i guess that was the problem...
still have yet to find a catch can tho... |
#47 |
2000 GT
Told ya
![]() You can buy an actual kit for a catch can. Or you can just do what i described above. I have also heard of people using an upsidedown fuel filter. Not sure what size or brand though. I think what i told ya is much better (water/air filter for an air compressor).
#48 |
yeah well i kinda rigged somethin up with a tractor fuel filter... but took the filter out... so its just air.. and the oil drops down in the bottom of the can... and oil is already kinda building up in it...
thanks bro... prolly saved me some $$$ |
#49 |
2000 GT
Kits are like 300 some bucks so yeah
Its crazy after you put one in to see how much oil was actually getting consumed.
#50 |
yeah... ive only taken it out twice since i put it on... and oil is already sittin in the bottom of it..
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/85116-help-bucking-low-rpms-please.html
| Help Bucking at low Rpms.. please? - Page 3 | This thread | Refback | August 19th, 2008 04:47 PM | |
Threads Similar to: Help Bucking at low Rpms.. please?
| my car misses at low rpms/boost | B0B | 99-04 | 5 | August 14th, 2008 10:45 AM |
| car is hesitating while in low rpms | 20gtvert03 | 99-04 | 3 | June 25th, 2008 01:08 AM |
| car is bucking | 40thmustanggt | 99-04 | 33 | March 17th, 2008 10:09 PM |
| Low Profile Tire Series, How Low Is Too Low? | Steam | V6 Mustangs | 11 | November 11th, 2007 12:48 AM |
| Vibration at low RPMS..... hmm | Ole Yeller | V6 Mustangs | 8 | June 15th, 2007 05:53 PM |
