LinkBack (4) | Thread Tools |
#1
02 Saleen Speedster #681
tach install..... tach adapter
anyone install a tach and use that tach adapter from autometer? Its pretty fucking confusing and i don't understand their directions since they are oh so detailed
hahaAny help is much appreciated
![]() 2002 Saleen #681 -Kenne Bell 2.1 intercooled 10psi w/BAP -Kenne bell inlet components -Kenne bell switch chip -75mm throttle body -90mm mass air meter -Nitto 555R's 285/45/18 |
2002 GT
13.835@100.26
I would like to put a tach in also, is it hard?? Someone help us!!!
I drink for today, I drink for tommorow, I need another drink!....do you have any money I can borrow!?
bump..... anyone out there? Is there another post out there that someone could point me to?
48.47@ 12.58
which auto meter tach?
they have install instructions for each one on their site..
the tach itself is easy, its that stupid tach adapter that makes no sense....
MM's nicest mod, :)
its pretty damn easy, if i can remember the color to all the wires i would have you set, what color are the wires coming out of the tach adapter
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
MM's nicest mod, :)
and if you don't know what the tach adapter is actually doing i will explain it real quick. Its just sampling the 12v sine wave pulse that is going to your coils and converting it to a 12v square wave pulse and sending that square wave pulse out the one wire that connects to the tach signal on the tachometer. Then its sending the 12v sine wave pulse after it sampled it back down to the wire and then continued on to the cop's.
yeah i don't know the colors off the top of my head sorry. I will check when i get home from work. I thought it was pretty simple but the instructions pretty much suck.
Did you mount the adapter inside the car or on the firewall somewhere?
First, disconnect the battery!!! You need to cut the red wire at pin 34 of connector C133, and then connect the red wire from the adapter to the red wire coming from the connector. The red/green wire from the adapter connects to the red wire that enters the harness. ![]() ![]() C133 has a bolt clamping it together that needs to be removed before you can remove the plastic cover. The red wire is the constant +12V feed to the COPs primary windings. The COPS are fired by the PCM's switching them to ground to allow the coil to saturate, and then breaking the ground connection when it's time to fire the plug. The rapidly collapsing magnetic field generates a high voltage in the COP's secondary winding. All of this high frequency/high voltage activity creates EMI/RFI switching "noise", at a frequency relative to the COP's firing, in the +12V supply to the coils. The tach adapter senses this switching noise and uses it to generate a clean trigger signal for the tachometer. My Cobra radar detector uses this "noise" found in the cigar lighter power supply to switch itself to standby when the engine is idling, and off when the engine is stopped...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/85185-tach-install-tach-adapter.html
| tach install problems 2000 gt | This thread | Refback | October 12th, 2011 08:47 PM | |
| tach install problems 2000 gt - CMC Forums | This thread | Refback | December 23rd, 2010 10:43 AM | |
| tach install problems 2000 gt - CMC Forums | This thread | Refback | December 23rd, 2010 07:47 AM | |
| tach install problems 2000 gt - CMC Forums | This thread | Refback | December 23rd, 2010 06:47 AM | |
Threads Similar to: tach install..... tach adapter
| How To install an Aftermarket Tach in a 96-98 | MustangMatt96GT | 96-98 | 30 | May 5th, 2008 09:22 AM |
| Autometer Tach/Tach Light and Ford racing Tach Driver install help | 94stang | 99-04 | 10 | April 18th, 2008 11:35 PM |
| Tach Adapter... Which Wire? | 2006greyGT | 2005 - 2010 | 5 | April 8th, 2008 10:32 AM |
| tach adapter??????? | mustangrebuilder | 2005 - 2010 | 6 | January 31st, 2008 01:51 PM |
| anyone ever install a tach on a 99-04 v6? PLEASE HELP! | ricerraper33 | Audio/Video | 8 | September 20th, 2007 09:35 PM |
