Discussing wierd squeak in the 99-04 Forum. My car has developed an odd squeak coming from the pulleys. I looked at it ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Mustang GT 5spd.
wierd squeak
My car has developed an odd squeak coming from the pulleys. I looked at it and I think it's the tensioner. A mechanic told me it could be a little spring inside the tensioner or could I just need a whole new tensioner pulley?
Accufab tb/plenum,BBK cai,Steeda ud pullies,Pro 5.0 shifter,Bassani catted x-pipe,Bassani catback,Tokico front and rear shocks,lowering springs,Strange SS Street brakes,17x10.5 Nitto 555r's,black FR500's,Mach 1 grill delete/chin spoiler
1999 GT
I think I have the same problem, mine squeals at start up but goes away after the car reaches NOT.
![]() Vortech V2 SQ @ 11LBS -Ray Wrong: Their is no one here. Wrong: Shelley wants to know if there busy. Wrong: The dogs are happily chewing on they're bones. RIGHT: I can't believe they're leaving their children there alone! |
Mine does it from idle all the way to 3500 or so. It squeaks faster as rpm's increase.
13.8@104
Put a small glob of Dielectric Grease on the rib side of the belt with your finger. You will be surprised the noise will disapear.
Whats that?
dielectric grease is a NON-conducting grease that seals out moisture and therefore prevents corrosion on electrical componants. I used to use the stuff on my waverunner on the battery terminals to keep them from corroding.
Now as to why someone would put ANY kind of grease on the belts is a question I would like answered. The squeking is typically a sign that you need to inspect your belts. If they are worn they may squeak and it is time to replace. If they are new and recently installed they may have stretched a bit and just need adjustment. Tho I am a newb with the fords myself and the serpentine belt. My old rig had seperate belts for all the accessories. |
The belt's in good shape. So your saying to check the tension? Belt could be slipping?
My understanding is just that. squeaking is the belt slipping cause by the friction which if left alone can cause premature failure. This is all void if the squeak isn't comeing from the belt but the bearing behind one of the pullies
![]() I think you can buy "belt dressing" at an autoparts store. not sure if it is a "grease" or not or if it is even recomended to use. maybe one of the gurus around here can help out a bit more. |
i believe the belt dressing they sell isnt made of grease but instead its made of wax.
2000 V-6
Belt dressing is a siloconized wax like stuff that is supposed to make the belt more pliable (like new).
The idler pulley prolly does squeak, that's why there are a couple of companies that sell new ones. Check Summit or whatever your personal poison is... IMO it may be worth it to just change the pulley... Another thought may be that it is a throw out bearing (mine squeaks like crazy at idle with the clutch pedal out). |
#11 | |
1999 GT
^^ for you its very easy to pull apart.
lol. Supercharger in the way?
Threads Similar to: wierd squeak
| Belt Squeak | gw604z2jnpps | 2005+ | 6 | November 14th, 2007 02:04 PM |
| Windows Squeak? | Reset | 99-04 | 11 | August 6th, 2007 11:02 PM |
| squeak | mustang1072 | V6 Mustangs | 5 | February 21st, 2007 11:34 PM |
| squeak | stang638 | V6 Mustangs | 31 | February 11th, 2007 04:33 AM |
| Squeak Squeak! | DC97Cobra | Suspension | 4 | November 26th, 2005 12:13 PM |
