Front O2 Sensor Problem
Old November 27th, 2006, 01:24 AM   #1
mystang428 is on a distinguished road
Recently added longtubes to my 01 GT, then did the sensor simulators for the rear O2 sensors now my car is throwing a check eng. light for the front O2 sensors and a ck that is causing it to run lean. What should I do, replace the front sensors?[/img]
Old November 27th, 2006, 05:01 AM   #2
ShapeShifter's Avatar
ShapeShifter will become famous soon enoughShapeShifter will become famous soon enough
do you have a handheld tuner, Predator or SCT? if you do, turn off your Rear o2 sensors and swap out one of your rear o2 sensors with the front one thats fugged up....if not just buy a new o2 sensor!
N/A Auto 2-Valve
1.74' 60ft
12.79 @ 105.5
Old November 27th, 2006, 03:14 PM   #3
yknot is on a distinguished road
There is a differance between the front and rear O2 sensors, so I would not mix them up. If you turn off the rear O2 sensors and the light is still on, then replace that sensor with a new front O2 sensor.
Threads Similar to: Front O2 Sensor Problem
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
Changing front brakes, 95 Mustang, problem! cgyarring General Tech 1 February 21st, 2007 09:10 PM
o2 sensor problem winez31 96-98 2 January 9th, 2007 12:49 PM
Front brake problem 99 mustang Justin07 V6 Mustangs 10 November 22nd, 2006 08:08 PM
Cobra front? ROUSH Front? or Mach1 Chin? Chris02 99-04 11 November 19th, 2006 01:10 AM
