Discussing Hood weight in the 99-04 Forum. I have an '03 GT, can someone inform me on how much the stock hood ...
Old August 20th, 2008, 12:23 PM   #1
Kid Stang's Avatar
'03 GT Conv, '95 V6 Conv
Stock, baby
Hood weight
I have an '03 GT, can someone inform me on how much the stock hood actually weighs?
I just spent an hour searching hood/weight reduction forums and have been unable to find this; I probably just suck at searching.
Appreciate the patience.
2003 GT Vert.
1995 V6 Vert.
RIP 1971 Galaxie 500
Can't wait to come home.
Old August 20th, 2008, 01:01 PM   #2
stanginit's Avatar
I would say it weighs 40-50lbs
TQ gets you there, HP keeps you there
'99 GT, BBK Long Tubes, BBK Catted H-Pipe, Flowmaster Delta 40's Catback, 3.73's, Eibach Pro-Kit, Tokico Ilumina 5-way Ajustables, Granetelli Upper and Lower Control Arms, 18" Chrome Bullets
Old August 20th, 2008, 01:04 PM   #3
Blown 03 GT
I think its more like 60. I was talkin to a guy wit a carbon cowl and he said its about 15lbs and he lost around 40 wit it.
Accufab 75mm TB and plenum, Mac Prochamber and Cat-back, Novi 2000 intercoolered MGW shifter and 18x10 w 285 Nitto 555s for some grip. Was 400+
Old August 20th, 2008, 01:34 PM   #4
stanginit's Avatar
This is the hood i bought 2 years ago. This is the info off of there page.
This is a 1999-2004 Mustang Fiberglass 3” Cowl Induction hood. The hood has a smooth gel coat finish. The hood is equipped with a front and rear metal latch plates. The steel plates are powdercoated to minimize rust and corrosion. Simply transfer your oem hardware over for an original feel. These are some the features that separates CarbonWare hoods from its competitors. The hoods are composed of several layers of high grade quality fiberglass and resin.
Direct Bolt On
Great weight reduction (28lbs, oem weight is 37 lbs!)
Rise height (clearance) 3"
Front & Rear metal latch plates
Smooth gel coat finish
High quality fiberglass and resin
Old August 20th, 2008, 01:58 PM   #5
Kid Stang's Avatar
Stock, baby
Thumbs down
Wow
Thanks for the timely response, guys.
2003 GT Vert.
1995 V6 Vert.
Old August 21st, 2008, 03:26 AM   #6
cliffyk's Avatar
The numbers I have seen have all been around 40 lbs...
-cliff knight-
My Mustang GT
2003 GT, UPR X, Magnaflow, 180° stat,
PP 70mm TB & plenum, Sniper Commando tuned
3.73s, 252 rwHP/296 ft.lb.
Multi-fuel: burns gas and rubber...
Old August 21st, 2008, 03:35 AM   #7
03FstStngKB's Avatar
2003 Ford Mustang GT
After Stall'd>>13.50??
I'll be finding out real soon what the stock hood weighs? I just purchased a HO Fibertrends 2.5 cowl. It only ways 22 lbs and seems to be about half the weight of the stock hood. It is a noticeable difference in lifting up both hoods. I will be taking off the stock hood in a day or two and I will weigh and post the results.
^^^^^^^^^My other BaBy!!!^^^^^^^^^
<---Mods List--->
4.30 Gears Installed
Mac H-Pipe Installed
40 Series Flowmasters Installed
Diablo Predator Tuned
Coming soon>>>SCT Tuned
J-mod and 3700 Stall >> ET of completion 'Spring or Summer of 09'
Old August 21st, 2008, 10:08 AM   #8
JMack's Avatar
2000 V-6
It weighs around 40 lbs...
I've taken mine off ti replace with another.
The hoods on the 99-04's (all) are fiberglass. They are not high grade fiberglass, but lighter than steel. If you don't have any performance mods done, or are not planning on drag racing, the only real reason for a lighter hood would be for appearence (ie carbon fibre). As I see that both of your cars are convertibles, I wouldn't recommend the drag racing...
Old August 21st, 2008, 10:57 AM   #9
Kid Stang's Avatar
Stock, baby
Haha
Good advice.
I'm just trying to educate myself before I come home and start on the car and it seems that there's a lot to be gained from weight reduction. Save twenty pounds with a $500+ hood though? I don't know.
The lack of performance mods, yeah sadly enough, I've had my GT since August 2006, I believe and I haven't driven it since, except for 32 days of leave.
Just like everyone else with my post count though, 'I PLAN to modify blah blah blah . . .'.
2003 GT Vert.
1995 V6 Vert.
Old August 21st, 2008, 12:03 PM   #10
Blown 03 GT
You can get similar weight saving with performance seats and you get the added benefit of it holdin you in much better. I had a fixed back sparco in my old vw i autocrossed for fun and damn did they hold you in. They are alot more comforatable as well. Im debatin on whether to go for seats or a hood for xmas. And dont forget if you get a fiberglass hood its gonna cost you around $500 to get it painted as on top of the hood itself.
Old August 21st, 2008, 01:22 PM   #11
Kid Stang's Avatar
Stock, baby
Yeah I didn't even think about the painting, and carbon fiber is so expensive.
Thanks man.
2003 GT Vert.
1995 V6 Vert.
Old August 21st, 2008, 01:25 PM   #12
Blown 03 GT
Carbon fiber can be run unpainted and not look as tacky as a primed hood if you wanted to wait a lil, but yeah the seats seem like a better deal. Just looking brackets the tend to be a lil pricey.
Old August 21st, 2008, 02:14 PM   #13
stanginit's Avatar
I was lucky and picked mine up from a guy in Cali for $250. I have left it white so far until I figure out what bumper I am going to buy. Then I will just get the front end painted.
Old August 21st, 2008, 03:07 PM   #14
JMack's Avatar
2000 V-6
The CF is good, but if you're gonna run it unpainted, make sure you gel coat it so it doesn't get brittle and fade.
Fiberglass is just about as strong, and not much heaver, plus a lot cheaper.
But the seats are a REALLY good idea. I hate the seats in mine, but I have a lowly unmoddified 3.8L, and I really can't see spending a lot on it...
Thanks for Serving BTW! What branch and unit are you in? I work for Defence Logistics Agency, so some parts I manage may go on the vehicles / weapons / expendables you use!
Old August 21st, 2008, 03:52 PM   #15
Blown 03 GT
[quote=JMack;1373314]The CF is good, but if you're gonna run it unpainted, make sure you gel coat it so it doesn't get brittle and fade.
Most quality carbon fiber pieces are gel coated and i would make sure mine was.
You loses the cost savings after paint.
[quote]
Old August 21st, 2008, 04:40 PM   #16
Kid Stang's Avatar
Stock, baby
Yeah, I think the seats are a good idea too, once again, thanks a lot guys.
I appreciate it.
I'm the armorer for HHC, 3rd Sqdn, 2nd Stryker Cav.
2003 GT Vert.
1995 V6 Vert.
Old August 22nd, 2008, 03:25 AM   #17
M0T0PSYC0's Avatar
1999 Mustang GT
13.8
I dont think they weigh very much, I had no prob swapping hoods from my 99 and 01 by myself at all, I dont think they were no 40 pounds either felt more like 25 maybe, I am rather skinny and dont have much arm strenght but didnt seem like much weight at all though.
99 forrest green vert:
-Diablosport Predator & Tune (removed for cheap gas use)
-Motive 3.90 gears
-MRT Catted H
-Flowmaster American Thunder catback
-Eibach Sportlines
-Tokico D-Spec shocks & struts
My Garage
Threads Similar to: Hood weight
stock 06 gt hood with rouch hood scoop Ataylor Exterior 0 July 18th, 2008 07:09 PM
light weight hood 1BADSTANG 5.0 Mustangs 10 June 30th, 2008 10:30 AM
Weight Iownastang 5.0 Mustangs 60 January 16th, 2008 05:18 PM
Hood Scoop for 99-04 Gt Factory Hood Black if possible Bigb2000GT Want to Buy 0 June 9th, 2007 12:07 PM
Cobra R Hood or Mach 1 or 2 Hood? Pick 1 of 4 hoods. Chris02 99-04 16 November 1st, 2006 09:46 AM
