Discussing O/R X pipe and Catback in the 99-04 Forum. Im buying an O/R X pipe and Catback and im not sure if i ...
Old August 21st, 2008, 04:23 PM   #1
carlos's Avatar
Im buying an O/R X pipe and Catback and im not sure if i need to re-do my dyno tune. Can i just install it and leave it alone? I just dont want to spend more money on the dyno since i have paid $500 already.
2004 mustang vert. Vortech V2-sq, 2 core procharger intercooler, 90mm LMAF, NGK TR6 (.034) Maxflow BPV, 42lbs ford racing injectors, SVT focus fuel pump, 3.60 pulley, Xcal3, O/R X pipe.
Dyno numbers coming soon!!
Old August 21st, 2008, 04:29 PM   #2
proto89's Avatar
14.2@100.12
No, you'll be fine. Just turn off the rear sensors
Professor Proto
Old August 21st, 2008, 04:39 PM   #3
carlos's Avatar
Yeah I already have them off!!
Old August 21st, 2008, 06:02 PM   #4
carlos's Avatar
i have been looking at a UPR O/R X pipe. They have 2 for my car, except one has the 02 sensor extension. Do i need this or should i just get the one with no 02 extension?
Old August 21st, 2008, 06:28 PM   #5
Reloaded's Avatar
2004 Mach 1
Hmm. Afraid I only know Machs well. But I know that '03 Machs do not require 02 extensions and '04s do. The stock h-pipes are different on the two models.
I assume that you aren't running a wideband?
http://www.dirtydirtyracing.com For ALL your tuning needs!
NO, I will NOT shut my hole! (In my hood)
Old August 21st, 2008, 06:29 PM   #6
2002 mustang gt
i have no idea
nah you dont need any..
2002 MUSTANG GT
4:10 GEARS
PI3500 STALL
BORLA CATBACK
O/R H-PIPE
JLT COLD AIR
HEADS AND CAMS(sold)..JUST A LIL 20SHOT OF JUICE NOW
www.myspace.com/playamade
Old August 21st, 2008, 06:36 PM   #7
carlos's Avatar
Im kind of new to the FI world so im not sure about the wide band. on a different note, I have heard of people re-tunning their car after installing an o/r x pipe because it leans out.
Old August 21st, 2008, 06:45 PM   #8
Reloaded's Avatar
2004 Mach 1
Every car is a little different and you'll hear both responses; tune it, don't tune it. The only way to be sure is, if you don't have a wide-band, to take it to the dyno and have them run it and check the a/f ratio. Wideband is the gauge that reads your a/f accurately. It uses more wires than a regular 02 sensor and is welded into your exhaust pipe near your upstream 02 in front of the cats (if you have them).
This is my wideband. It's an AEM unit:
Old August 21st, 2008, 06:52 PM   #9
carlos's Avatar
Thanks for the explanation. I guess i learned something today.
Old August 21st, 2008, 06:56 PM   #10
Reloaded's Avatar
2004 Mach 1
No problem. Just another gauge to help make sure that you keep track of what's going on with your engine and necessary to properly tune a car. But most people do dyno tuning so you can just use their W/B setup.
Old August 21st, 2008, 08:01 PM   #11
zinc02GT's Avatar
Slow
Im pretty sure that the 04 GTs as well need the O2 extensions.
I know for a fact that 02 and below dont need them....
The only way to learn about a car is to break something and fix it yourself...
Originally Posted by graystang01 View Post
cams demello'd a viper
nuff said
Threads Similar to: O/R X pipe and Catback
what x pipe goes good w/ magnaflow catback? 006leenstang00 99-04 22 January 29th, 2008 04:30 AM
BBK X Pipe with Mac Catback? TheTechnical99 V6 Mustangs 3 January 17th, 2008 02:56 PM
which catback for 4.6l GT with mac h pipe SilverGT04 99-04 11 December 24th, 2007 01:27 PM
X-Pipe and Catback motorhead6776 V6 Mustangs 3 November 23rd, 2007 02:12 AM
Y PIPE MAC CATBACK knightster420 V6 Mustangs 7 August 27th, 2007 09:48 PM
