Discussing gas sensor problem in the 99-04 Forum. i think my fule sensor or watever it is that controls how much gas my ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
gas sensor problem
i think my fule sensor or watever it is that controls how much gas my guage reads is messed up
this easy/cheap to fix for instance last nite i went on low and wihtin 2 miles put 10 bucks in and 9.7 miles later my light came on but sometimes i get 200miles in a tank so i know im not getting to shitty mpg |
Y2K YellowJacket GT
~TBD~
Huh? Didnt follow that part about the MPG, but the "sensor" is actually the float attached to the pump. Mine got stuck down once on a long road trip and i went to the back of the car, sat on the ground with my legs under the tank, and kicked the shit out of it! It loosened up and worked after that. Give it a try. If you cant get it to dislodge (if it is stuck) you will have to drop the tank.....and possibly may have to rewire or fix the float, depending on the problem.
BLOWN Bumblebeast! 370 rwhp and 381 ft lbs ![]() Sneaker Crew #8 Professor C MILITARY CREW LT ![]() "Like the blind man says......We shall see...."
is the float/sensor expenisve?
and i was saying that i get decent mileage sometimes and others it seems really bad but i just think the sensor is fucked up there no way i only got 9 miles out of 10 bucks of gas |
#4 | |
Slow
Sounds about right ![]() Try this.... Run your car untill you run out of gas or are running on fumes. Go to a gas station fill up, then unplug your battery for 15 minutes. PLug it back up crank up the car and try it then. Also, Ive been told that when putting gas in your tank when the handle clicks, DO NOT put anymore gas in there. I was told that putting more gas in there after it clicks is how your fuck up that sensor... |
#5 | |
btw i have no problem with dropping my tank
i have a freind who does that kind of shit for people and he wont mind |
Threads Similar to: gas sensor problem
| IAT sensor problem | 5.0Madness | Modular Mustangs | 3 | February 13th, 2008 11:54 AM |
| IAT sensor problem | 5.0Madness | 5.0 Mustangs | 4 | February 11th, 2008 04:00 AM |
| 02 sensor problem | supercharged03gt | 99-04 | 16 | February 11th, 2008 12:37 AM |
| o2 sensor problem | winez31 | 96-98 | 2 | January 9th, 2007 12:49 PM |
| Front O2 Sensor Problem | mystang428 | 99-04 | 2 | November 27th, 2006 03:14 PM |
