Discussing Ticking noise in the 99-04 Forum. So heres the deal. I am hoping someone can give me some direction or know ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Ticking noise
So heres the deal. I am hoping someone can give me some direction or know what is going on.
Okay I have a 2000 mustang with a 4.6 liter motor that is completly stock. Now when I start the car it runs normally no sounds until I accelarate. The only time I hear the ticking is when the rpms are around 2,500 to 3,000 this happens during decelaration as well. Other than that it hasnt got worst and it has been a couple thousand miles. My performance has not been affected either. TIA |
Resident Bubblehead
exhaust leak?
'91 GT
A little more info on where the ticking sound seems to be coming from?
![]() Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. |
1/8 7.95@82.43
Could be the DPFE switch. Is your car throwin a code?
![]() If you're not 1st you're last -Ricky Bobby Topless Mustang Club Founder |
I dont think its an exhaust leak and its not throwing any codes. It does sound like is coming from the engine bay though. Thanks for the prompt replies
Whats the DPFE switch |
Resident Bubblehead
Differential Pressure Feedback, Exhaust. it has to do with the EGR valve...
1/8 7.95@82.43
The DPFEwicth is the Differential Pressure Feedback EGR switch. My car is doin somthin similar. It is throwin the code P0401. That switch goin bad is what is causing it. I have also heard of fuel injectors making a tick sound. Can you tell where in the engine bay it is coming from?
it sounds like its coming from one of the heads but i dont want to say that for sure. Should i have a check engine light if it is coming from the valve
'91 GT
Does it happen only when you're driving or can you duplicate the noise in neutral revving?
I can duplicate the noise in neutral. Again i would like to thank everyone for the help
1/8 7.95@82.43
I tell you what take a rubber hose (preferablly a radiator type) and place it around where you think you hear the sound and tell us what you hear. Also try different areas around the engin to see if you can tell where its commin from.
1/8 7.95@82.43
Could also be your valves, try changin your oil.
I juat changed my oil and it didnt help. I will give the rubber house a shot
does the rate of ticking increase with rpm in the range indicated? or is it steady within the range? Is it metalic or plastic sounding?
perhaps a valve isn't happy and in that rpm range it just happens to be the right harmonic to let it tick. |
1/8 7.95@82.43
Did you change it or did someone else change it? How did the hose thing come out?
2001 Sexystang
14.8@94.3MPH
my car is completely stock as well and when i floor it from 2k it makes a ticking noise for like not even a second so i put 91 octane nomore noise lol but only happens when i floor it so i just keep mu foot out of the throttle
Dynamax side exhaust,K&N FilterOMG, Eibach Prokit, BBK UDP |
2003 GT
mine kinda makes a ticking noise too under acceleration, but it got less when I fixed my big ass exhaust leak.
![]() SCT chip, 4.30's, Flowmaster w/ Turndowns, Trick Flow Plenum, BBK 70mm Throttle Body, Pypes X-pipe, BBK CAI, 100 shot and nitto radials (obtained).
well i brought it somewhere and had them use synthetic oil. I think the noise is coming from the right sid valve cover. This may seem like a stupid question but if infact it is coming from the valve or valves and i decide to get some new heads this should fix the problem?
2001 mustang gt
It maybe the timing chain. Ford had problems with the tensioners going bad, causing the chain to wear through the guides faster than normal. I had that problem.
13.86@100.3
run some fuel cleaner. thats wat mine was
13.96 at 97.49 STOCK AUTO 13.84 at 100.3 (spinning) ![]() W/3.73s Next Mod: Motor/Tranny swap |
Threads Similar to: Ticking noise
| Strange Ticking Noise | DiZzyBonne | 99-04 | 10 | July 9th, 2008 08:32 PM |
| ticking noise | tweeters97 | 96-98 | 2 | March 16th, 2008 10:31 PM |
| ticking noise | 1 SNAKE 3 | V6 Mustangs | 19 | February 14th, 2008 07:03 PM |
| Ticking Noise | nathom05 | 99-04 | 0 | December 17th, 2007 08:57 AM |
| ticking noise | kreil45 | 5.0 Mustangs | 2 | April 23rd, 2007 03:11 PM |
