LinkBack (1) | Thread Tools |
2003 GT
Fueling n2o question
I was wondering if a 150-175 shot would be okay with a set of 24lb injectors and a 280lph ford gt pump. I blew up my plastic manifold on a 125 shot so I bought a new aluminum manifold and thought maybe I would have it tuned better and run a larger shot. Thoughts?
From a Dig or Nothing You'll Like My Taillights. |
do you have a window and wot switch
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
2001 Mustang GT
12.4@111 (N/A)
![]() iTrader: 1 reviews
do you have a wet or dry kit?
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod ![]() N2O times coming soon my junk at the track
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the 24lb injectors will only safely support around 375. it will will hold a little more than that, but you should base your injector around 80% duty cycle. this is all assuming you are on a dry shot. if you are running a wet shot, injectors will have nothing to do with it.
a metal intake doesnt make it any safer... if its gonna blow its gonna blow.. look on here it will have pics of sum blown.. and i would stay with a 150 shot on the stock gt motor... seen 1 take a 200 shot about 5 passes though b4 it throug damn near the entire motor from under it haha.. and if you open a ford gt pump its nuttin but a walbro 255
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
mm's nitrous mod
2000 mustang gt
aluminum intakes are designed to take a nitrous backfire.the gt pump is no walboro. the walboro is a 255, the gt is a 310.
MM's nicest mod, :)
designed for a backfire and actually taking a backfire is two different things, i have seen countless pics, including on here of aluminum intakes exploding. the plastic one should do if you have the right safety equipment. I just wouldn't put a 1000 dollar intake on a car and then not have the right safety stuff and then have 1000 dollars scrap metal sitting in the car.
06 Dodge MegaCab Diesel 455rwhp/815rwtq REAL TRUCKS DON'T USE SPARK PLUGS |
mm's nitrous mod
2000 mustang gt
thats why i said "design"
#9 | |
Proud American
6.82@100mph 1.45 60'
sweet and white... this is for you guys.. runnin a 100shot right now.. would it be safe to run a 150 with a good tune? on a msd digital window switch and nx wot switch
mm's nitrous mod
2000 mustang gt
yup
could i do it on a mail tune? or need to take it to the dyno
mm's nitrous mod
2000 mustang gt
either.
hmmm.. what size shot you shootin sweet?
Proud American
I am going to run 150 the way the car is set up now iwth 104 in the tank... Ill let you know how it oges....
mustangmatt what does your et change over to at sea level? helacious 60' for the et. ha
mm's nitrous mod
2000 mustang gt
lol.. yeah.. im on the 100 now... lookin to move up soon once i fix trans and get a few other things on....
Proud American
wow... i swear im not being a dick or tryin to call bs and i know you said the calculations didnt concern you but i think they off a little bit... but thats still awesome for a npi on a 100 to even run a low 12.... i want your wheels!!!
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/86050-fueling-n2o-question.html
| Fueling n2o question - Page 2 | This thread | Refback | August 25th, 2008 05:57 PM | |
Threads Similar to: Fueling n2o question
| GM To Build Hydrogen Fueling Station In Los Angeles | mdvaldosta | All Other Vehicles | 1 | July 13th, 2008 09:05 PM |
| n2o and n/a tune help. | 03 R Code | 99-04 | 8 | June 17th, 2007 08:46 PM |
| tried the N2O out last night | 03 R Code | Drag | 22 | April 3rd, 2007 05:40 PM |
| just bought some n2o | Drgnracin72 | The Clubhouse | 4 | August 24th, 2006 02:29 PM |
