Discussing Im thinkin about getting a turbocharger in the 99-04 Forum. I have an '02 mustang GT and im wanting to do a quick boost in ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
200 Mustang GT
Im thinkin about getting a turbochargerBut ive read a few places that it could tear up your engine if it isnt built for it... could a stock 4.6l v8 (stock for my car) handle it? Im sure it could. but im here for advice
I'm sportin a 2002 Mustang GT. Mostly stock, but soon to change once my business takes off ![]() I got an additional 8 mpg while traveling across the country. |
2000 mustang GT
11.79@125
it can handle some very mild boost, but eehy spend the cash for the turbo setup when you cant take advantage of it. juts throw in a supercharger. cheaper and will make just as much power on your motor as you will with the turbo. the stock internals seem to die around 400-425 hp. you can put a supercharger on it and get 400 rwhp easily. so why spend the cash, if ya cant take advantage of the reasons for using tubo
Truthfully I'm not sure if a turbo charger is any cheaper or more expensive then a super charger . But I do know they are both expensive up-grades. Your stock 4.6L will benefit from such an up-grade, but you will not be able to extract the full potential from either kit with a stock 4.6L engine. That does not mean the up-grade would not be a good choice, just you would have to limit the power to keep the engine from hurting itself. Later on, when time and funds prove handy, you could up-grade your engine internals to better and more robust parts and then expel the true potential from your turbo or blower. I would say most that run a blower or turbo are others in your same position, where they detune the kit to fit there needs and later do the up-grades necessary for full bore performance. just remember that running your engine at full tilt without any internal up-grades is a temporary improvement at best, for it's just a matter of time till something breaks.
2000 mustang GT
11.79@125
i wish i could find the thread with the pics of my blown motor because of too much power and too much boost!!!
200 Mustang GT
^ Yeah i see... well, first off ima get some gears and maybe an intake (as they are quite cheap)... i want my stang to last a long time but i also want to enjoy it (i love racing)... if i were to get the turbo kit without getting new enging parts (for the time being) and race with it, how much would it hurt? never changing your oil is very harmful... is a turbo kit along the lines of not changing oil? (in terms of wear and tear?)
also, im more familiar with turbo kits... so im picking that instead of a supercharger... what im asking is... with is better, safer, and cheaper in the long run (part replacements etc) thanks
2000 mustang gt
12.01@114.69
the kits that are made specificly for the mustangs are made for a stock bottom end unless otherwise posted and wont harm the motor. there are a couple of mustangs around here with blowers puttin down 390-430at the wheels and drive them everyday and have close to 100k on them without a problem. you just have to watch the amount of boost that you put into them and make sure you have a good tune for the boost.
stock long block, bolt ons, slicks, and a little squeeze 1/4 E.T. 12.06@114.69 ![]() Only two defining forces have ever offered to die for you: 1. Jesus Christ 2. The American G. I. One died for your soul, the other for your freedom. |
200 Mustang GT
^ sweet deal... a new mustang shop opened a couple miles from my house ill check it out
should i get it super or turbo charged? pros and cons
2003 GT
so what is a safe amount of boost on a stock 4.6? and what internals would need to be changed to up that boost safely?
![]() SCT chip, 4.30's, Flowmaster w/ Turndowns, Trick Flow Plenum, BBK 70mm Throttle Body, Pypes X-pipe, BBK CAI, 100 shot and nitto radials on the way.
400rwhp is a good number on a stock block. but its all in the tune. need to go with forged crank, rods and pistons
http://img.photobucket.com/albums/v2.../matrixsig.jpg |
#10 | |
The Cable Guy...
SLOW
Click Here For Carnage |
200 Mustang GT
Some of the things that id need to change would be
- Pistons - Crank - Rocker Arms? - Rods could someone give me a list? doesnt have to be right on, just a list of the parts that usually screw up..
#12 | |
200 Mustang GT
^ loudon county... bout 15 miles south of knoxville
id got with a SC if i was u
Threads Similar to: Im thinkin about getting a turbocharger
| Thinkin about this CAI for my V6 | zdrainxx | V6 Mustangs | 20 | September 13th, 2007 12:02 AM |
| clevor thinkin | ih8chevy | 5.0 Mustangs | 5 | May 19th, 2007 10:47 PM |
| thinkin about buyin a 07 | maverick | 2005+ | 14 | January 4th, 2007 01:49 PM |
| Steve What Were You Thinkin'? | WAVEBYE | The Clubhouse | 15 | December 5th, 2006 06:26 PM |
| Thinkin Bout That X2cal | zdrainxx | VMP Tuning | 0 | October 24th, 2006 11:48 PM |
