Discussing Weird intermittent problem? in the 99-04 Forum. On 2 different occasions my car completely dies under hard acceleration. The first time I ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
On 2 different occasions my car completely dies under hard acceleration. The first time I thought I blew off a intercooler pipe after the MAF. After pulling over and examining the pipes all looked fine. I got back into the car and it fired right up. Now fast forward 2 weeks and it happen to me again. I tried firing it back up but it didn't start as I was drifting. I pulled off the road and then it fired right up, and all seems fine.
I have had thrown a code recently for a missing cop. But I have yet to replace it. I think maybe my chip is lose on the ECU?
Spending money I don't have, on parts I don't need. to impress people I don't know.... 2k MUSTANG GT 598/531 RWHP/RWTQ Just a little S-trim.... |
02' GT
is it like the traction control kicks in when its not supposed to? or does the car completely die?
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences '02 GT~dd '89 LX~still in swap mode FOR SALE: Canfeild cylinder heads 302ci 2.02-1.60 valves 54cc combustion chambers-dual vavle springs $1200 |
MM's nicest mod, :)
Mine did the same thing when i had a blower, don't know why it did it but as soon as i ran down the track and let off the gas the car died, restarted right back up but died all the time. Has even done it a couple of times when i was n/a
Have a Nice Day, Especially MSO ![]() 99 Mustang GT VT 302 Stroker 11.13@123 f.s. 9k 06 Dodge MegaCab Diesel 455rwhp/815rwtq |
2003 GT
Is there a fuel cut off built into the ECU's? I know my friend's EVO has this shit where if his boost peaks too high, instead of going lean the car just dies. It'll crank right back up afterwards and no lights are thrown. I don't have a boosted Mustang, I'm just throwing that idea out there.
![]() SCT chip, 4.30's, Flowmaster w/ Turndowns, Trick Flow Plenum, BBK 70mm Throttle Body, Pypes X-pipe, BBK CAI, 100 shot and nitto radials (obtained).
#5 | |||
Today it died shortly after starting it right in the garage, and the mileage on the odometer was replaced with all dashes ---------------- and it wouldn't start. I cycled the key a few times and the numbers came back up and it started. I took the ECU out and the chip seemed to be firmly taped in? I'm starting to think maybe the chip or ECU is giving me fits?
my guess would be a wiring problem. You might be losing voltage or a ground which would kill the spark and quite possibly throw the code for the cop. I can see it happening between shifts as load is transferred perhaps just enough to "wiggle" the loose connection. If you have a mechanism to datalog the voltage you may be able to pinpoint if that is indeed the problem.
Of course this can be drawn out to the other basic electrical checks...i.e. battery, alt, etc... |
02' GT
the dashes on your gauge cluster would make me think somthing funny is going on with the bcm
I also start leaking fuel at the injector on number 8 and a tiny tad on number 2.
I started smelling gas on the way home when I was flogging on it a little bit. Pulled into the garage and found the leaks
SLOW
I would say start at the battery terminals and grounds to see if they are loose.
Threads Similar to: Weird intermittent problem?
| Weird Problem | dothedew1654 | 5.0 Mustangs | 3 | July 25th, 2008 06:09 AM |
| Weird LED problem? | SUHLeen | 2005+ | 0 | June 4th, 2008 11:19 AM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| weird problem | Reggedon | 99-04 | 6 | January 9th, 2008 10:40 PM |
| Weird Acceleration Problem | TheLocalGypsy | 5.0 Mustangs | 4 | August 20th, 2007 01:27 PM |
