those who deleted egr - Page 2
Old October 31st, 2008, 01:36 PM   #21
cbrown's Avatar
cbrown is on a distinguished road
Send a message via AIM to cbrown Send a message via Yahoo to cbrown
Thats funny you guys brought this up, because when I was putting in my headers my egr tube got bent and then I cut it off, because I was told I would be better off getting a new one, but when I cut my car on I expected a check engine light or something, I got nothing except for a lil rough idling.
CAI, o/r x-pipe, Flowmaster mufflers, 75mm TB,Predator tune,and bbk shorty headers, and Hurst short shifter...still waiting on my upper plenum.
Old October 31st, 2008, 01:36 PM   #22
cbrown's Avatar
Originally Posted by RyanGT View Post
Not much, like stated. most tuners turn it off anyways just so it doesnt recycle hot air back to the intake. At WOT it shuts off im pretty sure.
Is this also with the diablo tuner?
Old October 31st, 2008, 04:45 PM   #23
Trick Tuners's Avatar
KB'd GT
EGR is not used at idle or WOT, only part throttle. It does slightly lower the combustion temps. Sometimes its necessary to pull a few degrees of timing at part throttle because the stock (and most custom tunes) will add timing to make up for the less dense air fuel mixture.
Old October 31st, 2008, 06:06 PM   #24
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
AggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really niceAggieStang is just really nice
Does anyone know where I could get some step by step instructions on how to remove everything?
Buy my:
Nitrous Accessories
Diablosport Programmer
In The Classifieds
Old October 31st, 2008, 06:20 PM   #25
adrenaline=lifeline's Avatar
13.86@100.3
adrenaline=lifeline is on a distinguished road
haynes manual
2004 40th Anniversary GT
Pro 5.0 Shifter
Lowered(H&R Springs)
Summit Hpipe w Dynomax weldin mufflers
Minor odds and ends
Old October 31st, 2008, 06:26 PM   #26
WHOOP!
AggieStang's Avatar
7.44@95 (1/8)
I have to pay to read that...
Buy my:
Nitrous Accessories
In The Classifieds
Old October 31st, 2008, 06:38 PM   #27
KB'd GT
You can just turn it off in a tune, and i'm pretty sure it will be off if you just unplug the wire.
Old October 31st, 2008, 07:12 PM   #28
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Originally Posted by casper gt View Post
obviously you've never taken an egr valve off or even where it is. all you have to do is cap off the tube fitting on drivers side exhaust manifold, block off the actual valve on the intake elbow, unbolt the switch from intake manifold & unplug, & cap off vaccum line. very simple 30 min. tops
Obviously I have taken it off while i was putting headers in there, tiger. Obviously it's apparent you haven't done headers, or you would of known what was involved. I see no point of taking the egr out so that's the only time it happened. I was referring to taking the whole tube out, not just capping it.
Like somebody else said i bent the shit out of it (had to get it welded to fill crease holes). Wouldn't even of responded if this post wasn't bumped.
And it has to be turned off with a tune (to the person that asked if a diablo could turn it off). A hand held by itself wont turn it off.
Or as Joe said, try unplugging the wire. (unless your wanting the unit out)
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old October 31st, 2008, 07:13 PM   #29
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
next year
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
i thought about doing it for my quest for more mpg but now ive decided to just not mess with it
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, muffler delete
Old October 31st, 2008, 07:41 PM   #30
PapaSmurf's Avatar
2003 Mustang GT
12.28 @ 116
PapaSmurf has a spectacular aura aboutPapaSmurf has a spectacular aura about
iTrader: 11 reviews
Im removing mine just to clean the engine bay up a little.
2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's
Old October 31st, 2008, 08:06 PM   #31
KB'd GT
If anything you will loose mpg, but usually not enough to notice. I usually increase the egr flow rates on my mpg tunes (but they are still in development).
Old November 2nd, 2008, 12:08 AM   #32
HBK_2007's Avatar
next year
thats good to know. btw any more thoughts on my fuel issue? i cant find my fuel pressure gauge to tell u what the pressure is so im gonna have to buy a new one
Threads Similar to: those who deleted egr
Grill deleted..b4 and after 6ER THEN I 8ER! V6 Mustangs 4 August 15th, 2008 01:00 AM
deleted Drick The Clubhouse 23 January 5th, 2008 11:11 PM
my deleted post itschristorres8 The Clubhouse 353 September 11th, 2007 06:26 PM
deleted post JASonic V6 Mustangs 4 June 29th, 2007 04:38 PM
