eibach sportline springs
hey guys i just bought some sportline springs for my 04 gt i was just curious, are the factory camber/caster adjustments enough or is it necessary to prchase aftermarket camber plates cuz i have the ford racing springs now and the factory adjustments were enough so im not sure it looks like there is still room for adjustment but i dont know if its enough. thanks for the help
!FACEPLATED!
you have to get c/c plates
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
You will need to buy some CC plates for the sport lines. I recommend americanmuscle maximum motorsports they are $199. You will also need to get an alignment when done.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
1989 LX
12.60 at 109mph
well i just picked some eibach prokits today and i have the back on right know it was cake? make sure you have a 19mm 15mm and 18mm handy for the rear springs easiest way take off both upper control arms and quad shocks and normal shocks and the axle should fall down enough to pullout the springs.
but tomorrow im doing the front spring and i have an alignment machine at work so im gonna see if i can adjust my tie rod ends far enough not to fuck up my tires lol so i will let you now
1989 LX mustang, 5speed, 108,xxx miles, Mac Longtubes, BBK midpipe, Paxton Novi 1000 6psi, Crappy FMU with 19lb injectors, 373 gears soon to come 30lb injectors, Blow through MAF, intercooler and tune |
#5 | |
!FACEPLATED!
sweet thanks guys ill order them right now
!FACEPLATED!
anything up to 1.5 you should be able to align without c/c plates. anything over that you will need them.
1989 LX
12.60 at 109mph
i tried at my work i had the quad shocks off and normal shocks off it fell a lil bit but not far enough so i took the bolts out that connected to the axle and they slipped right out lol
!FACEPLATED!
yeah you have to push down a little on the axle but they will come out. beats the hassle of trying to get the upper control arms back on. its only a couple hour deal to do all four if you take your time.
1989 LX
12.60 at 109mph
yeah i had it up on my car lift at work with an air tranny jack pushing back up on teh axle it was cake lol no problems putting it back in with that lol
You NEED c/c plates.
1998 GT FRPP: 4.10s, Alluminum d/s STEEDA:upper/lowers, springs, cc plates, tri-ax TOKICO: Adjustable shocks SPEC: alluminum flywheel K&N: Intake Screamin Demon ignition ram: clutch ----------------------- BUCK OFAMA |
2001 Mustang GT
13.15@101
This chart will help you on most spring decisions...
You only need c/c plates for shorter springs... Coil Spring Tech |
Threads Similar to: eibach sportline springs
| eibach sportline kit | shadow5403 | V6 Mustangs | 7 | February 7th, 2009 10:22 AM |
| Is anyone running Eibach Sportline springs? | F8L GT | 99-04 | 23 | August 1st, 2008 12:28 AM |
| eibach sportline lowering springs | 99blkcobra | 4V / SVT | 7 | March 4th, 2008 09:31 PM |
