air bag
Old August 28th, 2008, 02:01 AM   #1
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
air bag
So i installed headers and had the steering shaft disconnected and all. Well im thinking it was not alligned right. steering had a little resistance and then it was gone. Air bag light is flashing now. Did i unplug the wire cause it was twisted up? Hard to put back in? will it blow up on my face if i do? lol.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old August 28th, 2008, 02:05 AM   #2
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
just plug it in with the battery disconnected
Old August 28th, 2008, 02:06 AM   #3
Pig Romancer
thewayshemoves's Avatar
2003 GT
300.32@5.02mph
thewayshemoves will become famous soon enough
Send a message via AIM to thewayshemoves
so wait, you can't just unplug the airbag?
http://i41.tinypic.com/2qjc2mh.jpg
Thank's your a grate guy and person who is good also
Originally Posted by GTsetGO View Post
it ain't no thang ma fraind. i jus be lukin after yo best intrest
Originally Posted by 93hatch View Post
wow open header crx, that things gota sound like hammered dick
Old August 28th, 2008, 02:10 AM   #4
2000 GT
It got unplugged lol. felt it, and then the air bag light flashed. Whats involved in tearing that out?
Old August 28th, 2008, 07:23 PM   #5
cliffyk's Avatar
cliffyk is just really nicecliffyk is just really nicecliffyk is just really nicecliffyk is just really nice
You need to place a 2.3 Ohm resistor across the gray/orange and gray/white wires that power the air bag.
The air bag controller sends a very small current (in the uA range) through the air bag squib (detonator) to make sure it's there and not open or shorted. The squib has a 2.3 Ohm internal resistance and that's what the controller is looking for. 2.3 Ohms is a non-standard resistor value. You can special order it as a precision part, or use two 4.7 Ohm resistors in parallel creating a 2.35 Ohm "close enough" value.
I used two 1/4W 4.7s (I got a lot of 50 on eBay for $3 or so) when I installed an aftermarket wheel back in the spring, the sensing current is so low that 1/8W parts would be fine.
Be aware that if the air bag ever fires those resistors will immediately burn out, however when that happens a little crack/pop from under the dash will likely be be very least of your problems...
-cliff knight-
My Mustang
2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch
3.73s, 262 rwHP/305 ft.lb.
Flex-fuel: burns gas and rubber...
Threads Similar to: air bag
air bag ZoomZoomMFer The Clubhouse 5 August 15th, 2008 09:25 AM
air bag sensor zombie_pony 2.3 Mustangs 0 August 6th, 2008 01:27 PM
Air bag light 97GSTANG 96-98 10 March 26th, 2008 03:21 PM
A/C and AIr Bag gotboost562 5.0 Mustangs 4 September 11th, 2007 02:43 AM
air bag? patwrecked 5.0 Mustangs 3 August 11th, 2007 10:45 AM
