Discussing Springs, need a raise! in the 99-04 Forum. I need to raise it a little bit. Im scraping going sideways on speed bumps (...
Old August 29th, 2008, 05:06 PM   #1
2000 GT
I need to raise it a little bit. Im scraping going sideways on speed bumps (some of them) and i put headers on. I would like to avoid a header leak if possible! So i wanted to raise it. I have Steeda springs on it right now (just by looking at the spring), they are also blue. Not sure which one it is. Im guessing the lowest drop they have? Steeda Sport Springs at AmericanMuscle.com - Free Shipping! Thats for v6 and gt models so maybe because of weight it is lower than a 1-1.25?
Measured from the ground to the front, and bottom of the door. Thats 6 inches from ground. Back is 6 and half.
K member is about 3 3-1/2 inches from the ground...
I want just a little higher, maybe because of the kb and being a vert the front sits lower than it should.
Any ideas on what i have so i can buy a little higher springs? Or spring recommendations.
2000 Black convertible GT: KB 14psi, and other goodies...
Old August 29th, 2008, 05:31 PM   #2
i have the steeda superlight sport springs they are great and have the same drop as the ford C springs which is up to 1.5 but i think mine are around 1.25 with the isolators still there. They can be purchased from jegs.
Old August 29th, 2008, 05:36 PM   #3
nevermind after reading closer it sounds like you have the sport spring the only thing i can think of is to go back to stock or the ford C spring but the for C spring drops just like steeda sport.
Old August 29th, 2008, 05:43 PM   #4
2000 GT
I dont know tho, i know it has to be lower than a 1.5 drop. I mean 3 inches from ground to k member is ridiculous. Its just the springs i saw in there were blue, and said steeda. Had bottom isolators on them too.
Old August 29th, 2008, 05:44 PM   #5
after looking a can't find the drop on the ebiach drag launch pack but i have heard good things and i think its pretty close to the stock ride height. But don't hold me to it
Old August 29th, 2008, 05:45 PM   #6
maybe someone cut the springs to lower it more like they do on the C springs i not sure if the steeda have a dead coil that you can cut.
Old August 29th, 2008, 05:49 PM   #7
2000 GT
I dont want stock height but i do want like a 1/2 more clearance i think it would help. Or at least not bottom out on everything... What are drop rates. Is it rated at tire to fender? Or from the door trim to ground?
Old August 29th, 2008, 05:57 PM   #8
this explains how the drop is measured Vogtland Sport Springs - PRODUCT REVIEW
Old August 29th, 2008, 06:03 PM   #9
2000 GT
Ok good deal, are you lowered? whats your drop rate? And could you measure yours with that method? bottom lip of rim to top of fender? Would be awesome help then we can tell how much it really is dropped
Old August 29th, 2008, 06:14 PM   #10
i am lowered with steeda superlight springs and upper and lower lakewood control arms and strange shocks and struts. i just measured i have about 4 inches in the rear from the top of the tire to the top of the fenderwell. I have about 2 inches clearence in the front top of tire to top of fender well.
Old August 29th, 2008, 06:21 PM   #11
2000 GT
Can you measure from the top of the lip on rim? We probably have different wall sizes on the tire. Would be awesome! Front is what im concerned with most.
Old August 29th, 2008, 06:24 PM   #12
2000 GT
From top of of the tim to fender i have 5 in front 6 in back.
Would stiffer shocks make the spring not as low? I have adjustable shocks... i think thats just with weight transfer though? not ride height?
Old August 29th, 2008, 07:51 PM   #13
no they don't really have anything to do with lowering a car unless they are designed for lowered cars. but i have the 10 way with strange i also was measuring from the tire to the top of the fender like the outside brim. i don't have a measuring device that will fit in the well to get the actual hight so we are probably bout the same height. if i had to estimate i say we are pretty dam close to the same.
Old August 29th, 2008, 08:12 PM   #14
2000 GT
I didnt do it from top of tire, i did it from top of the rim. And i used a tape measure
Old August 29th, 2008, 08:33 PM   #15
i did mine from the tire i am at school so it was a ruler haha but i have to guess we be about the same maybe u are a little lower
Old August 29th, 2008, 10:00 PM   #16
2000 GT
Thats not much of a drop though sadly yours was what 1.5?
Old August 29th, 2008, 10:01 PM   #17
2000 GT
and im having scrapping problems lol
Old August 29th, 2008, 10:02 PM   #18
SteviGX's Avatar
13.538@101.72
3 inches from ground to k memeber is pretty low...i know mustangmanic has sportlines and we cant get a floor jack under the k without raising it but i dont know that it's that low..
With mine it's about a 1/4 inch from sliding. and i have the kobalt 3 ton low profile floor jack
Tuned by Rick@Amazon Tuning Solutions
Mineral Gray Club Member #2
spendin money that I don't have to buy parts that I don't need to impress people that I don't know
Old August 29th, 2008, 11:10 PM   #19
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83
the c springs can get really low as well. i have them on mine, doc's got them, the front is dropped pretty hard. and now with the k on my car, its on the ground. i was having issues trying to get over the tiny speed bumps at work before i installed the k.
stock long block, bolt ons, slicks, and a little squeeze
N/A-12.81@103.7
N2O-11.79@115.8
Only two defining forces have ever offered to die for you:
1. Jesus Christ
2. The American G. I.
One died for your soul, the other for your freedom.
Old August 30th, 2008, 12:07 AM   #20
2000 GT
Yeah i think they either compressed or is lower than advertised. Cause i shouldnt even be close to scrapping with 1.25 drop.
Anybody else have some specs for me to judge on? from the top of the rim lip to the fender edge. And what springs you put in (or stock).
Just going to see how much it is actually lowered and go from there..
Threads Similar to: Springs, need a raise!
woohoo got a raise supermachone The Clubhouse 21 June 13th, 2008 12:34 PM
Best Size Hood Raise KIKa55GT 96-98 24 January 29th, 2008 12:25 AM
w00t Got a raise Juggalo_X The Clubhouse 41 September 1st, 2007 08:17 PM
raise rear on a 67 coupe cjcurtis65 Classic Mustangs 6 March 16th, 2007 08:48 AM
