Discussing supercharger idler pulley squeal video in the 99-04 Forum. I think the chirping noise is coming from the idler pulley that I just replaced ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
1999 Mustang GT
I think the chirping noise is coming from the idler pulley that I just replaced but you can't hear it over the supercharger whine in the video. You can see the pulley kind of wobble though and every time it does that I hear a chirp. Does anyone know what I can do to fix it? It sucks because it's a cheap plastic pulley and it's brand new.
Vortech V2-SQ
2004 F-250 PSD
1/8th 9.256 77mph
FAIL video not found
![]() NOBAMA 08 MM Truck Crew (Founder) MM Mach 1 Crew (Founder) |
1999 Mustang GT
Okay I don't know why it's not working, but it works for me if you click the link at the top of the video. Someone let me know if the link doesn't work.
Vortech V2-SQ
2004 F-250 PSD
1/8th 9.256 77mph
o ok sry yeah i just watched it and i cant hear anything over the s/c but i can see the pulley moving and i might have heard the chirp your talkin about but idk
2003 GT
how loud is the chirp from outside the car or from inside it? is it really bothering you that bad?
![]() SCT chip, 4.30's, Flowmaster w/ Turndowns, Trick Flow Plenum, BBK 70mm Throttle Body, Pypes X-pipe, BBK CAI, 100 shot and nitto radials (obtained).
1999 Mustang GT
Yeah it annoys me especially with the windows down. It does it worse at higher rpms.
Vortech V2-SQ
2003 GT
wd40? bearings? new pulley?
1999 Mustang GT
I already tried wd40 and a new pulley so maybe it's not that pulley it just looks/sounds like it.
Vortech V2-SQ
I dunno man I highly doubt that the pulley should be moving like that. You posititve its installed correct.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
1999 Mustang GT
Its just a bolt with a little plate under it, I don't see how it could be wrong. I put the old one back on and it does the same wobble.
Vortech V2-SQ
Oh ok thats simple enough just never seen a pully move like that
1999 Mustang GT
Yeah I know it's like a plastic composite piece of crap. On the old pulley the belt started to wear through it a little bit.
Vortech V2-SQ
that wobble doesn't look right at all. have you attempted to put any additional spacers on it to limit its movement? Is the plate you are talking about the correct thickness for the application? I would imagine that movement will just wreck havoc on the belt over time.
#14 | |
1999 Mustang GT
Here is a pic from the instructions. It looks like it has a metal pulley that's different from the one I have put I have the same part number as the instructions say so I don't know.
Vortech V2-SQ
1999 Mustang GT
Here's a pic of the one I have on
Vortech V2-SQ
Can you manipulate the pully by hand with the engine off? A simple washer could solve the wobble if you find one that leaves enough clearance. It almost seems as if the pulley width is not exact or the bolt is not correct or installed all the way. I assume the bolt is threaded only at the tip.
It may not be a problem with the pulley, but with another pulley not running true(inline). a belt chirp is more than likely out of line or "twisted pulley's. squirt the belt with water and see if it goes away
99 limited edition conv. KB 2.1 9 psi intercooled.vt stage 3 blower cams,gt40 fp/bap,vt covers,frpp 3:73's,demolet cai,accufab 75mm tb,Sct Ba 2400,tri-ax,bfg kdw's,magnaflowsTuned by Joe at http://www.tricktuners.com |
Did you check the tensioner?
www.schradersspeedandstyle.com |
One time I had a squeal and it was the altenator.
Spending money I don't have, on parts I don't need. to impress people I don't know.... 2k MUSTANG GT 598/531 RWHP/RWTQ Just a little S-trim.... |
Could it be that the pulley was installed icorrectly? I just checked mine and there is a dust protector on the back of the pulley. The deepest part of the dust protector should be facing the rear of the car.
![]() 2004 mustang vert. Vortech V2-sq, 2 core procharger intercooler, 90mm LMAF, NGK TR6 (.034) Maxflow BPV, 42lbs ford racing injectors, SVT focus fuel pump, 3.60 pulley, Xcal3, O/R X pipe. Dyno numbers coming soon!! |
Threads Similar to: supercharger idler pulley squeal video
| question about idler pulley | greenstanggt99 | 4V / SVT | 4 | June 29th, 2008 08:40 PM |
| Video of the modded tensioner pulley | obdnanr | V6 Mustangs | 40 | February 19th, 2008 10:31 AM |
| belt/pulley squeal | sasafrass12 | 5.0 Mustangs | 3 | February 13th, 2008 12:03 AM |
| Thermostat and Idler pulley | 97GT4.6 | 96-98 | 2 | December 27th, 2007 02:30 AM |
| Broke Idler Pulley - Twice!!! | gw604z2jnpps | 2005+ | 5 | October 8th, 2007 06:10 PM |
