Discussing Question regarding catted "X" pipes? in the 99-04 Forum. I have a "01" Mustang GT and I have a question regarding mid ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I have a "01" Mustang GT and I have a question regarding mid pipes. I notice that the stock "H" pipe has four catalytic converters, if I installed a 2 1/2 inch X pipe with welded in magnaflow catalytics on each side would I still have to use MIL eliminators ?Since Im going from four "cats" to only two "cats"? I was told that you only use MIL eliminators when you're running no "cats" at all. Any input would be greatly appreciated.
1999 Ford Mustang GT
Well actually there are 6 catalytic converters on a stock GT. Just the other day i swapped out the stock H for an o/r H pipe and did not need MIL eliminators. I'm guessing it depends on the brand and where they place the rear o2 sensors. MAC makes them closer to the manifold which helps prevent from throwing a check engine light. Since you are going to stick with cats you should be fine, but every car and brand can be different.
You will need mil's or you will get a cel. They are not needed at all though it will not hurt your car, will only have the light.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's Mineral Gray Club Member #1
How long has it been installed?
Question regarding "X" pipe
Regarding 347STROKER, so your saying that even if get a pair of quality catalytic converters welded in on each side of my o/r UPR 'X' pipe that I will probably still get a check in engine light. I guess it depends on the quality of the 'cats' because I've been getting alot of feed back saying that I won't need the MILs if I get 'cats' welded in.
There are 4 O2 sensors in a midpipe I believe. Therefore if you only have 2 cats yes the other two will throw codes. Thats the point of having sensors.
2004 Mach 1
I had a Bassani catted x-pipe and every couple of months it'd throw the CEL. But I work for Ford so I just had it cleared out. But it was usually a month between times it would trip the light.
![]() http://www.dirtydirtyracing.com For ALL your tuning needs! NO, I will NOT shut my hole! (In my hood)
So what about when running an off-road X or H, your four sensors are still connected. The MILs are connected to the rear sensors to fool the computer like if they are there to not throw a code, what about the front two sensors that are closer to the manifolds. MILs are not needed there when you run an off road X or H. I think the front two sensor measure the air/fuel ratio.
#10 | |
2004 Mach 1
347Stroker, your four sensor theory does'nt make any since because the front two sensor measure the A/F ratio and there in front of the catalytic on a stock "H" and make no difference on off road pipes. So the sensors that will throw a code if there no catalytic in front of them is the rear sensor. Sorry to correct you.
If Im wrong Im wrong but I think youll get a cel.
13.422@103
I have an O/R X and I'm not throwing any lights at all. I must be lucky
![]() Mineral Gray Club Member #3 Winter Plans= FRPP 31 spline trac lok, Moser 31 spline axles, FRPP 3.73 gears. 256RWHP, 299RWTQ All Mods In My Garage |
My o/r h threw a code till I shut them off with a tuner.
13.422@103
Like I said I must be lucky, the only time I got a CEL was this past sunday when I got a dead porcupine stuck under my car on the X pipe. It shorted out and blew the fuse. Replaced the fuse and everything has been fine a dandy
Lol nice
13.422@103
You should see my dog trying to get under my car. I was going to go lower but now I think I'll stay where I am
i am runing the pypes catted x pipe for 3 months now no cel no mils along as you cats u are fine.
1/8 7.95@82.43
I just installed my o/r prochamber last wensday and I made my own mil's everything works fine, no codes or anything, and I might add that it sounds awsome.
![]() If you're not 1st you're last -Ricky Bobby Topless Mustang Club Founder |
#20 | |||
Slow
If you get a 2 cat midpipe youre gonna need a tune or MILs more than likely because your going from 4 regular cats to 2 high flow cats. |
Threads Similar to: Question regarding catted "X" pipes?
| NEED HELP ON "PIPES" X PIPE plz | Jeff99gt | 99-04 | 11 | September 5th, 2008 10:07 AM |
| WTF is up with "test pipes" | DeMello | The Clubhouse | 14 | July 2nd, 2008 12:52 AM |
| the "TV" cable on my 88 popped off, how to adjust? (trans question) | 78mach1 | 5.0 Mustangs | 14 | June 17th, 2008 03:44 PM |
| ""ON EBAY 1 DAY LEFT 88 MUSTANG GT"" | NYHigH | For Sale | 5 | November 29th, 2007 08:38 PM |
| QUESTION....Pro Chamber and the dreaded "drone" | Bossman | 2005+ | 9 | February 26th, 2007 10:14 PM |
