18x9" & 18x10" Bullitts
LinkBack (1) Thread Tools
Old September 3rd, 2008, 02:24 PM   1 links from elsewhere to this Post. Click to view. #1
bbk03gt24's Avatar
2003 Cobra
bbk03gt24 is on a distinguished road
Send a message via AIM to bbk03gt24
Ok, I almost feel like an idiot for asking this, but I'm getting ready to put some black 18x9" (in the front) and 18x10" (in the rear) bullitt wheels on my 03 blue gt, and I ultimately just wanted to make sure that I wasn't going to have any problems with them. For instance, will I simply be able to buy them, get them put on, and then get on the road? or will I have to purchase some type of kit or something to adjust them to work on my car; etc.?
Thanks guys....
Old September 3rd, 2008, 02:36 PM   #2
I Hate Convertibles...
2000 GT Vert
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
what size tire you gonna run?
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
Old September 3rd, 2008, 03:12 PM   #3
bbk03gt24's Avatar
2003 Cobra
245's in front and 265's in rear
Old September 3rd, 2008, 03:15 PM   #4
2000 GT Vert
you shouldnt have any problems. i would run a bigger tire in the rear like a 275 or 285 but they can be pricy.
mods/pics
Old September 3rd, 2008, 03:18 PM   #5
99mustanggtman's Avatar
1999 GT
99mustanggtman will become famous soon enough
iTrader: 7 reviews
Send a message via AIM to 99mustanggtman
No problems at all. I run 295s out back and 275s up front.
Single 67mm turbo, ported pi heads, edelbrock vic jr. manifold w/HPP plenum, terminator shortblock, return fuel system... Goal 600+ rwhp.
Old September 3rd, 2008, 03:22 PM   #6
2000 GT Vert
the only thing with 275s in the front is they rub your sway bar when you turn all the way. but you wouldnt even notice it. i run 275s on my car.
mods/pics
Old September 3rd, 2008, 03:36 PM   #7
bbk03gt24's Avatar
2003 Cobra
do you all mind if i ask why you would recommend going with a 275 over a 265? (the 275s are a bit pricey)
i really appreciate the feedback...
Old September 3rd, 2008, 03:38 PM   #8
2000 GT Vert
its more tire and it will fit the wheel better.
mods/pics
Old September 3rd, 2008, 03:40 PM   #9
1999 GT
iTrader: 7 reviews
Yup what he said, only rub issues are only from lock to lock, like coming out of a parallel parking spot, no biggie tho.
Old September 3rd, 2008, 04:04 PM   #10
347stroker's Avatar
347stroker is on a distinguished road
+1 265's will look stretched a bit IMO. And you will be fine I run 275 and 315 and they fit like a glove.
Foxlake stage 2 heads, CMS stage 2 cams, Custom Diablo tune, BBK LT's, BBK O/R H, Bassani Race Mufflers, MGW STS, 75MM TB, K&N CAI, Eibach Sportlines, 4.10's
Mineral Gray Club Member #1
Old September 3rd, 2008, 07:23 PM   #11
energiesource's Avatar
energiesource is on a distinguished road
315? maybe on 17's
not 18's
Old September 3rd, 2008, 07:54 PM   #12
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
i ran 315 dr's on my 98 and had no problems
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old September 3rd, 2008, 08:05 PM   #13
njstang's Avatar
13.58 @ 102.31
njstang has a spectacular aura aboutnjstang has a spectacular aura about
iTrader: 5 reviews
My buddy just put on black 18" saleens on his 03 mach. He's running 275 up front and 285 in the rear. IMO the 285s fit tight looks like a 305 would fit nicer
Originally Posted by Jazzer The Cat View Post
Jazzer says heat your meat so it sticks to the street
NEW JERSEY STANG OWNERS :
http://njnewedge.forums-free.com/
Old September 3rd, 2008, 10:29 PM   #14
TyCouey2000GT is an unknown quantity at this point
your 265 tire will be stretched a tad on a 10" rim.. and plus, itll look weird with a small tire on a fat rim, i say save up and get 285 or 295.. youll absolutely love the look... and up front i wouldnt go over 265..
sorry for the typos
Your Average GT
Old September 3rd, 2008, 10:51 PM   #15
347stroker's Avatar
Originally Posted by energiesource View Post
315? maybe on 17's
not 18's
Yes 17's, just saw he said 18s my bad
Old September 4th, 2008, 02:40 AM   #16
FOR POINT SIX's Avatar
FOR POINT SIX is on a distinguished road
I run 18x9 & 18x10 Bullitts on my 02 GT. My fronts are 265/35ZR18, and the rears are 285/35ZR18. I do not have a problem with rubbing (or its just not enough to notice). My fronts look great, but I do wish the rears where wider. They have a stretched out look to them.
Old September 4th, 2008, 10:35 AM   #17
02sonicGT's Avatar
02sonicGT will become famous soon enough02sonicGT will become famous soon enough
the first number in the tire size is the tread width in mm then the second is the percentage multiplier to use of the width that gives you the sidewall height. Unless you want to look like a low rider with rims wider then your tires you should get enough tire to look flush with your rim.
1mm = 0.0393700787 inches
so
245 series is 9.64 inches wide
265 series is 10.43 inches wide
275 series is 10.82 inches wide
315 series is 12.40 inches wide
A 255/45x17 is a 10.039 inche wide tire with sidewall height of 4.52inches
to plus size without changing your speedo you increase the rim and decrease the ratio on the sidewall to keep the overall diameter the same.
255/40x18 is 10.039inches wide with a 4.02inch sidewall. Overall size doesn't change(lost 1/2 inch on each side of tire for total of 1 inch)!
Stock is a 10" tire on an 8" rim and it looks nice and flush. Same width tire as Rim will look a tad stretched.
More contact patch = more traction and sicker looking stance
Pretty sure I got all that right. its been a while.
Old September 4th, 2008, 11:46 AM   #18
One Man Wolf Pack
06RedfireGT's Avatar
2006 Mustang GT
13ish....maybe
Put a 305/35-18 Nitto DR on there. 265 are too small. If not then a 285/40-18 is a good size.
ΜΟΛΩΝ ΛΑΒΕ
Old September 4th, 2008, 01:38 PM   #19
mustangmanic's Avatar
13.334 @ 106.27 w/2.01 60'
mustangmanic will become famous soon enough
Send a message via AIM to mustangmanic
energy... you can run a 325 on a 18x10 safely... but you'd have to roll the fenders. a 315 would fit perfect
Old September 4th, 2008, 03:55 PM   #20
I am not sure but I would think with a 325 you would rub the quad shock and possibly you exhaust?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/87404-18x9-18x10-bullitts.html
18x9 This thread Refback September 3rd, 2008 03:19 PM
Threads Similar to: 18x9" & 18x10" Bullitts
C&L Trueflow intake system with "No-Tune" Calibration DarkCandy08GT 2005 - 2010 15 June 11th, 2008 01:32 PM
17" X 10" chrome bullitts with correct offset nem 2005 - 2010 1 April 4th, 2007 11:39 PM
New 18 inch rim question...18x9 front & 18x10 rear tinkerbell_too Modular Mustangs 7 February 15th, 2007 09:02 PM
