Valve lash Adjusters
LinkBack (1) Thread Tools
Old September 3rd, 2008, 11:20 PM   1 links from elsewhere to this Post. Click to view. #1
interfac9's Avatar
1999 Mustang GT
interfac9 is on a distinguished road
Send a message via AIM to interfac9
I have a '99. I'm pretty sure it is a Romeo motor. It has the tap, but story has it that I could get a head rebuild or maybe get the lash adjusters replaced. Can anyone give me an idea what this might entail, cost, risks? It runs fine, but the tap is worse. I know it's wear, and I'm 99% positive it isn't the bottom end, but I would like to be sure she's in the best condition she can be on this stock motor.
1999 Mustang GT, 247.7 RWHP @ 4400 RPM - 300 Ft/lbs TQ
Roush CAI, UPR TB Spacer, MAC O/R H-Pipe, Flowmaster Catback,
4.10 Gears, Centerforce Stage II Clutch, Bilstein Shocks & Struts,
H&R Springs, Roush LCAs, Mach 1 Grill Delete
Old September 3rd, 2008, 11:28 PM   #2
ajm
Not sure on labor costs although the ford dealer im at charges $80 something per flat rate hour for service labor. If you go with lash adjusters they run about $10 a piece and you need 16 of them. Pretty simple to change on your own though. For the most part all you need is a $100 tool, 3/8" breaker bar and to remove the valve covers.
Old September 3rd, 2008, 11:32 PM   #3
interfac9's Avatar
1999 Mustang GT
Good place to find it all?
Old September 3rd, 2008, 11:35 PM   #4
ajm
Cheapest place I could find the tool was sears.com it was $90 or so the tool is OTC 7928, weather its from sears or not its the same one youll find else where but a bit cheaper the mac guy wanted $200 something for it. It is used to compress the valve spring so you can take out the rocker. After that you touch the lash adjuster with a magnet and it pulls right out, drop your new one in, recompress spring and put rocker back in place. As for lash adjusters any ford dealer should have them or be able to get them. Considering price its not a bad idea to replace the valve cover gaskets while youre at it. They can be had for $20 from a general parts store.
Old September 4th, 2008, 12:31 AM   #5
interfac9's Avatar
1999 Mustang GT
Bruh, THANKS. And that will take care of that doggone tap? anything else I should do with the covers off?
Old September 4th, 2008, 06:02 AM   #6
jivepepper's Avatar
jivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the roughjivepepper is a jewel in the rough
If you have a 99, and the motor is original, then it's a windsor
2000 GT 665/540rwhp/rwtq On pump gas
Best 1/4 638hp street tune 11.01, best trap 134MPH, 80*+day, 10.5" DD Cobra R's & 315/35/17 DR'S
DYNO VID --->
http://www.youtube.com/watch?v=K9uOS732mdA
Old September 4th, 2008, 01:25 PM   #7
interfac9's Avatar
1999 Mustang GT
I could have sworn it was a Romeo. The Windsor is available in a 2V?
Old September 4th, 2008, 01:32 PM   #8
Resident Bubblehead
00vabchgt's Avatar
00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough00vabchgt is a jewel in the rough
yep. Windsors were put in the '99- mid '01 Mustangs because of a fire at the Romeo plant...
the Windsors were mostly being put in F-150's...
Submariners Do It Deeper
Military Crew
MM1 (SS)
Order of the Bluenose
US Navy Veteran
Originally Posted by MamaStang View Post
"Boy Danny....nice cock ya got there. "
Old September 4th, 2008, 02:05 PM   #9
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
I'd look at your timing chain first...most likely the culprit for your problem
Old September 7th, 2008, 11:13 AM   #10
interfac9's Avatar
1999 Mustang GT
Eeeeew! I haven't heard a lot of good things about having to replace those.
Old September 7th, 2008, 11:29 AM   #11
dude496's Avatar
04 Mustang GT
Not really all that hard....pull the pulleys and valve covers then timing cover and then swap it out.
Old September 7th, 2008, 06:53 PM   #12
mpboy's Avatar
2002 GT
99.99@999.9
mpboy has a spectacular aura aboutmpboy has a spectacular aura aboutmpboy has a spectacular aura about
pull the timing chain cover (all the pullys) pull the valve cover, put the motor in safe mode, and while you have all that stuff off i would replace the whole timing system, the chains can stretch, get new tensiners, and the guides are made of plastic, so those will need to be changed. the cam isnt that hard to take off and you will not need a special tool to get the rest of the valve train stuff replaced. and you might want to look in to replacing the valve stem seals while your in there but to do that with the heads on the car you will need to use air to hold the valve up while you replacing them, iv never done it i always take the heads off and take them to get cleaned before i rebuild them
Old September 7th, 2008, 09:23 PM   #13
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
You can get the tool for removing the rockers and lash adjusters from Steve at Tousley ford pretty cheap. The adjusters aren't very expensive and definatly replace the timing chains if you are gonna go in there.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old September 7th, 2008, 11:09 PM   #14
interfac9's Avatar
1999 Mustang GT
Head... Swimming... Warning, I am an OHV guy traditionally (Camaros) and I have NEVER owned an OHC car before, so all this is a little Greek to me. I don't have the guts to go into the motor balls out, so maybe suggestions on going in easy. It's my daily driver...
Old September 7th, 2008, 11:11 PM   #15
interfac9's Avatar
1999 Mustang GT
Once I get the valve covers off, what would be the next step?
Old September 8th, 2008, 12:02 AM   #16
andres0286's Avatar
andres0286 is an unknown quantity at this point
Send a message via MSN to andres0286
Can you get a video of the tap?
2002 GT SOLD
2003 Mustang GT Cobra Clone SOLD
Procharged @ 8psi
458 rwhp
Mods in Garage
Old September 8th, 2008, 12:04 AM   #17
interfac9's Avatar
1999 Mustang GT
Sure can...
Old September 8th, 2008, 05:56 PM   #18
mpboy's Avatar
2002 GT
99.99@999.9
are you replaceing the timing chain? if you are make sure you put the motor in safe mode, these Mod motors are interfernce.
Old September 14th, 2008, 08:44 AM   #19
interfac9's Avatar
1999 Mustang GT
What is "safe mode"? I am new to these engines, so it is greek to me? I was pondering the timing chains, as the motor has almost 150 grand on it. Noticed that I could smell a hint of coolant when I turned on the A/C. Not much, just for a couple of seconds...
Old September 14th, 2008, 08:45 AM   #20
interfac9's Avatar
1999 Mustang GT
Going to try to get that video today and upload it.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/87495-valve-lash-adjusters.html
Valve lash Adjusters This thread Refback September 16th, 2008 04:30 PM
Threads Similar to: Valve lash Adjusters
Valve Lash Adjustment IcantDo55 5.0 Mustangs 6 April 2nd, 2008 10:50 PM
rocker/valve lash adjustment Hunt_chevs 5.0 Mustangs 5 March 25th, 2008 03:55 AM
Solid lash adjusters zerofx150 99-04 8 March 16th, 2008 10:59 PM
Valve lash adjustment shurb125 5.0 Mustangs 8 March 10th, 2008 10:52 PM
valve lash terribleonexx88 5.0 Mustangs 9 March 8th, 2008 01:40 AM
