LinkBack (1) | Thread Tools |
2001 Mustang GT
Auto to Manual
Does anyone have a list or a link to a list of whats needed to swap a Auto to Manual. I have a guy with a doner car but I'm not sure what I need and I want to make sure I get as much as possible before he sells the other parts. I have a late 01 and the doner is an 04. Thanks
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the swap is pretty strait forward. me and doc just did one on his mach not too long ago.
list: manual wiring harness starter plate tuned for manual or manual ecu pedal assembly shifter slip yoke for stock driveshaft or a driveshaft from/for a manual flywheel flywheel bolts clutch assembly pressure plate bolts clutch quad, cable, and firewall adjuster shifter bezel trans tunnel will have to be cut a little to make room for shifter that what i can remember right off the top of my head.
2001 Mustang GT
Do you think I could just change the transmission type in my Diablo or are the ECU's different?
mm's nitrous mod
2000 mustang gt
no, you have to send it off and have it programmed for it. doc sent his to houston performance to have done.
damn houston performance did something right thats a first to hear.. lol
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
2001 Mustang GT
So I picked up everything except the ECU and wiring harness for $700 because the guy wanted to sell them with the motor. Anyone know where I can buy the harness other than the dealer? I can get the ECU for 150 locally and I've read that Diablo has a custom tune to disable PATS so I guess all thats left is the harness. Thanks for the help
N/A 4v Guru
2003 Mach 1
I got my diablo tuned for the manual for $60 bucks. that would save you a about $100 over buying a new ECU. Just an FYI
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
2001 Mustang GT
Did you go through diablo or a local tuner? There are no Diablo tuners in my area.
2001 Mustang GT
Yep. Like sweet said. Sorry I didn't realize that you were DOC. So did you send the ECU or just your Diablo?
oh sh*t they did something right again..lmao..
#12 | |
N/A 4v Guru
2003 Mach 1
Just the diablo. Put it in a box with a check for $60, put a list of my mods in there as well and they put me a tune on it.
2001 Mustang GT
Do I need the complete engine harness or just the transmission harness?
mm's nitrous mod
2000 mustang gt
just the trans harness. the auto and manual harness are diffrent. we used the wire harness for the manual to hook up to everything on the trans and the main plug from the auto.
2001 Mustang GT
Great. The trans has the wiring on it. It looks like my only issue is the ECU now. Hey thanks for all the help, you guys have saved me a ton of time and money for sure. I'm looking forward to the MT.
Whatever it originally would be
if i had the money, i would do the same thing your doing. but i dont have all the time, knoweldge or money. Hopefully i can do this tho.
![]() MILITARY CREW ANTI ILLEGALS CREW FOUNDER |
2001 Mustang GT
N/A 4v Guru
2003 Mach 1
You will need to modify the plugs from the manual harness. On mine I had to cut off the plugs from my auto harness and splice them onto the manual harness. Also you will have to modify the hole in the floor for the manual to stick up in the console.
Here a thread from my swap you can look at. to kinda see what all we did. Tranny swap update
#19 | |
2001 Mustang GT
i gotta ask doc, about how much was spent for parts, for everything? Im seriously condsidering the swap. If its a good price range, ill do it this homeport. And i need to find a good 5 speed, and someone to do the install.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/87500-auto-manual.html
| Auto to Manual - Page 2 | This thread | Refback | September 14th, 2008 05:14 PM | |
Threads Similar to: Auto to Manual
| Auto vs. Manual | Blackbeauty v601 | V6 Mustangs | 12 | January 24th, 2008 12:59 AM |
| auto to manual? | solareclpse2000 | 5.0 Mustangs | 10 | August 31st, 2007 12:03 PM |
| auto to manual | chevy_killer | V6 Mustangs | 4 | July 12th, 2007 06:43 PM |
| Auto vs. Manual | hubba076 | 99-04 | 18 | June 19th, 2007 01:04 AM |
