Burnouts
Old September 5th, 2008, 10:38 AM   #1
adrenaline=lifeline's Avatar
13.86@100.3
adrenaline=lifeline is on a distinguished road
Burnouts
Ok i thot this problem would fix w gears and geting my axle bearing fixed but wen i burnout bout tires spin and most of time both smoke but only 1 leaves marks unless i saty there a long time. Wats up is this normal?
2004 40th Anniversary GT
Pro 5.0 Shifter
Lowered(H&R Springs)
Summit Hpipe w Dynomax weldin mufflers
Minor odds and ends
Old September 5th, 2008, 10:41 AM   #2
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
posi trak out
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old September 5th, 2008, 10:41 AM   #3
dude496's Avatar
04 Mustang GT
dude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the roughdude496 is a jewel in the rough
Drive gears would have nothing to do with that. Sounds to me like your rear diff is starting to go.
Old September 5th, 2008, 10:50 AM   #4
13.86@100.3
I was worried that was it... It always launches straight and high rpm burnouts they both do it. It seems to only do it on low rpms and short time. If i launch it hard and spin it leaves both?
Pro 5.0 Shifter
Minor odds and ends
Old September 5th, 2008, 10:58 AM   #5
01gtMustang132's Avatar
2001 Mustang GT
13.15@101
01gtMustang132 is on a distinguished road
When you are leaving the water box pop the gas to coat the tires all the way around the tires...
Then shock the tires with about a 3000 drop...
If you try to power into a burnout without a spool or very good trac lock ...
One side will break traction the other will hold traction...
I had the same problem learning burnouts...
Old September 5th, 2008, 11:00 AM   #6
02sonicGT's Avatar
02sonicGT will become famous soon enough02sonicGT will become famous soon enough
would it still be the diff if both tires are actually spinning as he indicated? Are both tires the same and have the same tire inflation? which side leaves the marks? perhaps you need to go on a diet
Old September 5th, 2008, 11:19 AM   #7
2001 Mustang GT
13.15@101
I still have the same diff and this is how they look now...
You will see my car on here...this is the Trackday Me and my wife set up for some friends...
Old September 5th, 2008, 03:55 PM   #8
Hunt_chevs's Avatar
2002 Gt
Not Slow
Originally Posted by SteviGX View Post
posi trak out
+1
Old September 5th, 2008, 04:00 PM   #9
MSTRB8N & MDR8N
BWAL's Avatar
2021 Mustang V15
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
wait, you're saying that when you do a burnout, both tires spin, and both tires smoke, but only one tire leaves a mark?
MM 1 am boner crew
Cars and mod list in garage
i like veiny meat sliding between my buttcheeks
Old September 5th, 2008, 04:25 PM   #10
02sonicGT's Avatar
thats the way I read his statment.
Old September 5th, 2008, 04:42 PM   #11
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
zinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud ofzinc02GT has much to be proud of
Jeff, you ever think it could be that your tires are basically bald from all the 360s, whip arounds, burnouts, etc you do?
I see a treaded tire putting down more rubber than a one thats practically bald
Mods in garage. Built suspension and gears since posted times.
Old September 6th, 2008, 01:46 AM   #12
13.86@100.3
ok this makes sense cause if i do a neutral drop i leave marks on both sides
now now lets not forget ur pole indecent. but i just rotated the tires so they arent bald...YET...i may have gotten a handle on my fooling around but sometimes on those dark lonely roads
Pro 5.0 Shifter
Minor odds and ends
Old September 6th, 2008, 01:38 PM   #13
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
HEY HEY
you and marshall are the only ones that know about that...
feaking 360s... 2 inches from a stop sign too. I had it then it still was going sideways...
Old September 6th, 2008, 04:22 PM   #14
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
sounds like a posi on its way out. mine did that for a little bit. then i upgraded to a eaton true trac. no more issues...
MM Cobra Club #25 My Autolog Profile
Old September 6th, 2008, 04:33 PM   #15
zinc02GT's Avatar
2011 Mustang GT
12.1 @ 116
Well I got in his car last night...
He doesnt have TCS... There is no TCS button in his car...
Old September 6th, 2008, 05:25 PM   #16
neverfastenough1's Avatar
TCS only keeps your tires from spinning by cutting fuel, not connected with locking your rear end to get both tires pulling.
Old September 6th, 2008, 06:02 PM   #17
bottlefedbullitt01's Avatar
2001 bullitt #835
not fast enough
bottlefedbullitt01 will become famous soon enough
yeah i think your posi is going out. I have a friend that had the same problem with his. He replaced it and had no problems. Get it fixed.
Bullitt #835 4:10s, bassani O/R X, bassani mufflers, Bassani mid-headers, forged/built 2v, trickflow 44 heads, BIG blower cam, v1 vortech intercooled 11# boost 532rwhp/468tq
Threads Similar to: Burnouts
Burnouts garydahl 2005 - 2010 35 April 4th, 2008 10:31 AM
burnouts don General Tech 2 February 19th, 2008 12:14 AM
burnouts Bhblondguy 2005 - 2010 15 August 24th, 2007 11:17 AM
burnouts brianstang Videos 8 August 2nd, 2007 09:01 PM
UK Burnouts joost Videos 0 December 8th, 2006 04:47 PM
