Best way to Launch on drag. - Page 2
Old October 6th, 2008, 06:09 AM   #21
01gtMustang132's Avatar
2001 Mustang GT
13.15@101
01gtMustang132 is on a distinguished road
Originally Posted by jivepepper View Post
You mean the front tires?
No my rear tires...
And I have lots of slips to prove it...
Old October 6th, 2008, 06:39 AM   #22
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
So your running 40lbs in the rear tires at the track? Dam I would lower it then and get even better 60's. It amazes me that you can crush the side wall like in your pic at 40psi.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old October 6th, 2008, 05:35 PM   #23
2001 Mustang GT
13.15@101
I had the slicks on my car in the sig...#34
This is a slip with the DR's...#4
In everyday trim...
Old October 6th, 2008, 09:09 PM   #24
jivepepper's Avatar
Well I'll believe 1.97 of the nittos that's basically 2 seconds you should have lowered the psi. I did a 1.66 on 17" dr's and a stock suspension. But I only ran 17 psi in them.
Old October 6th, 2008, 09:30 PM   #25
2001 Mustang GT
13.15@101
I still have stock suspension And I've herd them hit the ground once...
And I'm not willing to try it again at 20 psi...
Old October 6th, 2008, 09:37 PM   #26
jivepepper's Avatar
Heard what hit the ground? I have ran Nittos, MT's, and BFG's in the 17" and I have never heard anything hitting the ground.
I wouldn't run 40psi on the street. For the rears I run about 27 on the street and 16-17 at the track if I run the 17's . Then I run 32 in the fronts on the street with 44 psi in fronts at the track only.
Old October 6th, 2008, 09:45 PM   #27
2001 Mustang GT
13.15@101
My buddy standing beside my car said it was my wheels...
So I just run my slicks now...
Old October 6th, 2008, 09:55 PM   #28
jivepepper's Avatar
Well I find hard to believe. Most people run what I run. I did it a couple months ago and was leaving at 4700-5000 rpm.
Old October 6th, 2008, 10:01 PM   #29
2001 Mustang GT
13.15@101
I'm not sure what it was but it was a loud clunk and it felt solid when it hit...
Old October 6th, 2008, 10:16 PM   #30
jivepepper's Avatar
Well I assure you it wasn't the side wall caving in, and the rim touching the ground.
I noticed your slips are from April. Nothing like cool air, and low elevation to make a car perform better..
Old October 7th, 2008, 06:27 PM   #31
2001 Mustang GT
13.15@101
Yeah I'm running like 13.50's now My factory clutch Is about to go I think...
I dont know what it is I do not hear it with the slicks (15 psi) and I've left at WOT many times... (The pic in my sig was my 13.15 run)
I believe in driving it like you stole it...And the cool air helps a lot ...
Old October 8th, 2008, 04:36 AM   #32
jivepepper's Avatar
Bring that up to a track that's a 1000 more and warm air. It will make you wanna go back.
I run at two tracks most of the time. I always pick up 2-3 tenths and 2-3 mph, when I go to the track that's at 500' compared to one that's 1300' track I usually go to.
All my freinds want to go to MIR (Maryland Internation Dragway) it's at seal level this November lol. When it's cold at a sea level it is like running at negative elevation. Of course the lower the elevation the more oxygen and more power.
Old October 8th, 2008, 06:07 AM   #33
Drgnracin72's Avatar
on nittos i burn them for a little bit and run 12-14 psi. i rev it to 6200 on the two step and side step the clutch. ive cut high 1.60 and low 1.70s on 17 inch nittos doing this.
heres a couple pictures of me doing just that. the front tires are barely touching the ground. if thoose tires would have held the nitrous off the line a touch better, it would have them hanging a little.
Fords - TimeTrial_Ford_011
Fords - TimeTrial_Ford_132
oh and 12.01@111 n/a with 305 rwhp and nitto drag radials.
RIP
ΜΟΛΩΝ ΛΑΒΕ
One Big Ass Mistake America
SHEEPDOGS
Old November 15th, 2008, 04:19 AM   #34
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
Well sadly with the way work has been i haven't been able to get to the track and they are closed for the winter now. I also need to fix my car because bank 1 and bank 2 are running lean, my idle RPMs are high, and i am changeing out my cat backs. If all goes as planed I should have everying thing fixed, sub-frame in, 4.10 gears in, tuned, and maybe a few other things in.
Old November 15th, 2008, 09:13 AM   #35
UnixHH's Avatar
2003 Saleen S281
UnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of lightUnixHH is a glorious beacon of light
Send a message via Yahoo to UnixHH
hoestly i only read your post and thats is lol im kinda drunk but i have a 35 side wall and i use about a 15psi and dont launch and anything but idle and after i heat them up i feather the cluch during the launch and then second i hammer it and get a lil spin but i hook really nice after that... with nittos you will hook way better than my bfgs
480RWHP 450RWTQ 15psi @ 15* on 91 octane
Old November 15th, 2008, 12:20 PM   #36
JayC's Avatar
2001 Mustang GT
JayC has a spectacular aura aboutJayC has a spectacular aura aboutJayC has a spectacular aura about
You car looks slammed......what springs/struts/shocks are you running?
tuned by SPEEDY DYNO
12.41 @ 109 mph w/ CMS stage II cams
11.13 @ 122 mph NX 150 shot
Launch soft, shift slow, rev low, stay slow
Old November 15th, 2008, 12:25 PM   #37
SteviGX's Avatar
13.538@101.72 before cams&slicks&gears
SteviGX will become famous soon enoughSteviGX will become famous soon enough
Send a message via AIM to SteviGX
I run my nitto's at 18.8psi before the first burnout then make e'm set at 19.5. I launch at 3900 on a prepp'd track, which i haven't since my tune and suspesion work and on poorly prepped track i can laaunch at 3400 and cut 1.9 60'. and i'm not the greatest at launching
I'm gonna try 15 come springtime since all you guys have such great 60' with that low
Mineral Gray Club Member #2
Just your average 22 year old dumbass
If you didn't build your car, and your bragging about it, STFU
Old November 15th, 2008, 09:01 PM   #38
Stock right now. haven't gotton to that yet. it's the rims that make it look lower. and the rims are 17"s '95 cobra R style.
Threads Similar to: Best way to Launch on drag.
Eibach Drag-Launch Springs Cricket 99-04 15 June 23rd, 2008 11:05 AM
Drag Launch Kit 330CubeGt General Tech 10 June 4th, 2008 02:05 AM
Drag launch kit? 06SuperStang 2005 - 2010 10 May 28th, 2008 06:29 PM
how to launch on drag radials? 93hatch 5.0 Mustangs 15 April 3rd, 2008 12:12 AM
What RPM Should I Launch At Drag Strip? gixxer1 5.0 Mustangs 12 September 27th, 2006 08:17 PM
