Discussing will i need a tach adapter? in the 99-04 Forum. Demello, since you pointed me over here in a pm, I highly suggest if you ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#21 |
May 08 ROTM
2007 Mustang GT
Demello, since you pointed me over here in a pm, I highly suggest if you want the power of nitrous, you do not cut corners. If you do, the next thread we have to hear is how bad you hurt your motor.
Power costs money, nitrous is the cheapest route, but to do it right takes a few dollars. Absolutely do the fuel pressure switch. Absolutely make sure the fuel system can carry the load. If that means buying a pump then do it, why even try to spray if something has the possibility of coming up short. Your not going to run enough spray to require a 2 stage window switch. Stick with a single stage if your trying to save a few pennies. If you plan to run a second stage of spray at some point in the future, then the 2 stage switch is justified. You also asked about wiring in a tach adapter. If you use the MSD digital window switch you should not need a tach adapter, you can simply splice the odd colored wire on any COP, I prefer passenger side rear most coil. By odd colored wire, I mean each coil has a common red wire and an odd colored with a stripe, use the odd colored with stripe for hook up.
![]() View and purchase my pics: http://erinmayphotography.exposuremanager.com/g/ Eleanor Desktop - http://erinmayphotography.exposurema...ormoonposter13 |
#22 | |
Black Mamba
2003 Cobra
11.14@124.36
Read this thread before you do anything.....
FAQ on nitrous - Modular Depot Forums
![]() Black Cobra Club Member
#23 | |
01 nitrous injected GT
12s next time out...
#24 | |
#25 |
N/A 4v Guru
2003 Mach 1
You still won't need the tach adaptor for the zex window switch. The pump is a good idea but the FPSS is a must.
![]() Gone To Basic Training |
#26 |
2002 mustang gt
i have no idea
the pump is a must to.im doing 150shot so that pump is much needed.... and that traction control switch is pointless if you ask me because if you have it and some bald sorry azz tires your going to spin even in second anyway.. get some good tires and the digital window switch adjusted not to spray till 3500 anyway..
![]() 2002 MUSTANG GT 4:10 GEARS PI3500 STALL BORLA CATBACK O/R H-PIPE JLT COLD AIR HEADS AND CAMS(sold)..JUST A LIL 20SHOT OF JUICE NOW ![]() www.myspace.com/playamade |
#27 |
N/A 4v Guru
2003 Mach 1
he isn't pushing enough to need a fuel pump. I had bolt ons and a 100 shot on stock pump.
#28 |
2002 mustang gt
i have no idea
well thats just to be on the safe side.. you have a mach so the pumps are a lil better arent they?
#29 | |
N/A 4v Guru
2003 Mach 1
No, same pump. just bigger injectors
#30 | |
and i already have DRs btw |
#31 |
#32 |
#33 |
2002 mustang gt
i have no idea
stock injectors on a gt are just fine they are 19...
#34 |
#35 |
2002 mustang gt
i have no idea
and i have a aem wideband and a fuel pressure gauge..
#36 |
2002 mustang gt
i have no idea
dont know what the stock fuel pump is.. i have a gt500 pump.. because it was free..
#37 |
#38 | |
#39 |
N/A 4v Guru
2003 Mach 1
My injectors are 24lb. and you wouldn't need a tach adaptor for anything associated with the nitrous kit
#40 | |
so i have a pretty good understanding of everythitng i need to buy now, what it does and why i need it the olny thing ill be missing besides heaters and a dyno tune will be a way to tell psi and A/F ive seen psi gauges on steeda.com for like 45 and im unsure of where to get the A/F gauge im guessing its not really needed since im not going over 125 but id like to keep it safe and think itd be best to be able to keep an eye on my A/F ratio doc do you know where i can get what i am looking for for a good price? |
Threads Similar to: will i need a tach adapter?
| tach install..... tach adapter | 02S281 | 99-04 | 8 | August 21st, 2008 02:35 PM |
| adapter | kreil45 | 5.0 Mustangs | 2 | June 3rd, 2008 05:02 PM |
| Autometer Tach/Tach Light and Ford racing Tach Driver install help | 94stang | 99-04 | 10 | April 19th, 2008 12:35 AM |
| Tach Adapter... Which Wire? | 2006greyGT | 2005+ | 5 | April 8th, 2008 11:32 AM |
| tach adapter??????? | mustangrebuilder | 2005+ | 6 | January 31st, 2008 02:51 PM |
