Water Methanol vs Intercooler
Old September 8th, 2008, 06:56 PM   #1
03SuperchargedGT's Avatar
2008 Cadillac CTS4
03SuperchargedGT will become famous soon enough
Hey guys i just need some opinions on what would be a better set up for me. Im currently running a vortech v2 at 8 psi, with a bbk 78 mm throttle body/plenum combo, as well as a bbk x-pipe and flowmasters. I will be adding some mac long tubes with a bbk cated x-pipe and a Anderson power pipe. Im looking to get the most and and safest horsepower out of my car. Please keep in mind my car is an automatic. What set-up do you think will be better the intercooler or the water methanol injection?
Old September 8th, 2008, 08:35 PM   #2
cliffyk's Avatar
cliffyk is just really nicecliffyk is just really nicecliffyk is just really nicecliffyk is just really nice
This was a popular mod in the supercharged Miata world (which I left when I had a windfall profit from and unexpected job in late 2006).
I did it on my '92 Miata running 12 psi with an M45 Eaton and found it to be a real hassle. Here in Florida where the road temperature in the morning is often 70° and then 120°+ in the afternoon it was a PITA to dial in. After trying a number of schemes to have morning and afternoon injection rates I finally gave up and settled on 6-8 psi, "sub-intercooled" boosts during the summer...
-cliff knight-
My Mustang
2003 GT, UPR X, FRPP 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, Delta Force Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch
3.73s, 262 rwHP/305 ft.lb.
Flex-fuel: burns gas and rubber...
Old September 8th, 2008, 09:04 PM   #3
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
you always add an intercooler to a non intercooled blower set up.. makes it more efficant(however you spell that word)
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old September 8th, 2008, 09:14 PM   #4
cliffyk's Avatar
Actually you can run quite nicely at 6-8 psi without an intercooler, even without a significant efficiency loss, by adding a bit more fuel. At 8-10 you need to be much richer than you'd think or like, and maybe pull some timing.
At 12+ it's intercooler time...
BTW, I won't argue this--I've done it for the last 40 years...
-cliff knight-
My Mustang
Old September 8th, 2008, 10:43 PM   #5
supercharged03gt's Avatar
2003, Mustang, GT
supercharged03gt is on a distinguished road
Id agree. Im non IC and am at 10 psi. runs just fine
Mods: Vortech V-1 supercharger, BBK LT headers, BBK o/r X pipe, Flomaster cat back, 4:10 gears, Centerforce clutch, Fidneza aluminum flywheel, K-member, Eibach pro kit, MM caster camber plates, Eagle F1 tires 275 & 315.
Old September 9th, 2008, 02:24 AM   #6
2008 Cadillac CTS4
so do you think it is safe then to run all that and push for 350-370rwhp without a intercooler or injection
Old September 9th, 2008, 09:47 AM   #7
cliffyk's Avatar
I have no direct experience with supercharging the 4.6 L 2V, however my gut tells me that 350-370 rwHP will put you right on, or a bit over, the "I should'a had an intercooler" line.
You will have some damned hot air going into the engine at full boost...
-cliff knight-
My Mustang
Old September 9th, 2008, 02:05 PM   #8
00silvergt's Avatar
2000 Mustang Gt
00silvergt is on a distinguished road
I'm running 10 psi with no intercooler, but I am borderline with intake temps. I say anything over 10 psi and you should be running an intercooler.
I don't have any experience with meth injection. Sorry I can't answer your question.
Tuned by Joe at Tricktuners.com
Old September 9th, 2008, 02:19 PM   #9
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
you guys that aren't running intercoolers say it runs fine and that may be true but it will be a cooler denser charge if you did run one. I wouldn't run a blower with out an intercooler. As for water meth I think is a nice boost but I would be more likely to run a small dry shot to cool the charge. 30-50 shot a boosted car will get you 50-75 at the wheels because of the charge cooling effect.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old September 9th, 2008, 02:53 PM   #10
cliffyk's Avatar
Of course. I don't think anyone here ever said the it would be optimal, just possible..
<snip>As for water meth I think is a nice boost but I would be more likely to run a small dry shot to cool the charge.<snip>
The water/methanol injection is intended only to cool the charge, and not specifically add power as would nitrous. It does work and let me run 12 psi with no intercooler here in Florida with 110° intake air.
-cliff knight-
My Mustang
Old September 9th, 2008, 05:09 PM   #11
Blown 03 GT
03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough03_StangGuy is a jewel in the rough
The intercooler will help with reliablity over the long term. You wont need it with 10 psi but it wont hurt that for sure.
Old September 9th, 2008, 05:10 PM   #12
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Yea I know it works fine, I was just saying thats what I would do. Just because I would want the power.
Military Crew
U.S. Army Aviation
Old September 9th, 2008, 08:11 PM   #13
Achieving more N/A power!
gills99stang's Avatar
When this baby hits
88 miles an hour...
gills99stang will become famous soon enoughgills99stang will become famous soon enough
Send a message via AIM to gills99stang
I was thinking of someday getting the methanol injection installed, but I had no idea you had to dial it in??
Brendan
'99 Mustang GT [ 318 rwhp N/A ] - SOLD ()
'04 F150 XLT SuperCab
Old September 9th, 2008, 09:54 PM   #14
Honeybadger is Crazy
futureMACH1racer's Avatar
2008 F-250 Super Duty
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Water Meth, is more of a supplemental cooler, not something that you would use for everyday driving scenarios. It would be great for track duty, but for traffic? Trust me you want an intercooler.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Threads Similar to: Water Methanol vs Intercooler
nitrous and water/methanol pigmie General Tech 3 June 5th, 2008 01:50 AM
Water Methanol Injection 95StangMX 5.0 Mustangs 8 November 13th, 2007 12:12 PM
water / methanol injection slowmotion00 Modular Mustangs 2 October 30th, 2007 05:14 AM
Water methanol injection? energiesource 99-04 4 August 3rd, 2007 07:54 PM
Intercooler & Methanol Cooling OVERKILL?? NewEdgeGT 99-04 8 November 28th, 2006 10:41 AM
