Discussing when bank 2 is running lean... in the 99-04 Forum. if its the same style filter i dont see why not.... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#41 |
2000 gt vert
IT WILL NEVER BE FAST ENOUGH!
Im topless, are you? ![]() ![]() Eibach Sportline Springs, 18x9 cobra r's, cdc side exhaust, cdc light bar, smoked headlights. Topless Mustang Club Founder August Birthday Club Member |
#42 |
01 nitrous injected GT
12s next time out...
#43 |
Slow
Demello LISTEN to me...
I read half of the thread. Im going to tell you everything you need to know and I positive that my info is correct. T45 is gonna need the same as the T3650. 3.5 Quarts. Ford proabably told you in Pints for some reason. Use Mobil 1 Mercon V automatic transmission fluid. Buy 4 quarts. Measure 1 of them out in a measuring cup and get half a quart in to one bottle. Now go under your car and on the bottom part of your tranny you will see a plug that say "DRAIN" your going to need a 3/8 ratchet. Put the ratchet end in there and lossen it. Let it sit there and COMPLETELY drain. PLug it back up and go up top to your shifter. Use a flat tip to get the console off. Use a 10mm and extension to get the gasket bolts off. Now use a 12mm to get the shifter off. You should be looking at a "cup" inside the tailpeice of the tranny. Take a funnel and surround it with a plastic bag. (the bag will help prevent a mess if you so happen to spill some) Pour the 3.5 Quarts into there (around the cup. not in it. itll drain itself into the tranny). Close it back up and before yo ustart the car, push in your clutch and move the shifter around a little bit to get things moving inside with the new fluid. Start the car and go. The fuel filter requires a finesse. You have to push the removal tool inside then as soon as you hear it click push and pull. Youll see what I mean. MAKE SURE YOU DRAIN YOUR LINES!!! To do this unplug your inertia switch whihc is located behind a panl in your trunk in the left corner close to the tail light. its a red button. Unplug it and turn your car on. Let it sit at idle until the shuts it self off... Plug in and play... Your spark plugs are located near your injectors, which may be pink or orange. Mine are pink. RIGHT beside those are your coils... I circled the injectors in green and the coil i could see in yellow ![]() Your gonna need a 7mm, swivel for the 7mm, a 3/8s ratchet with extensions and a swivel, anti seize, and a 5/8s spark plug socket
![]() The only way to learn about a car is to break something and fix it yourself... Last edited by zinc02GT : September 9th, 2008 at 07:54 PM. |
#44 |
13.538@101.72
#45 |
2002 MUSTANG GT
^+1 million. listen to this guy he knows what hes talking about. do exactly what he says and you will have no problems. good luck
______________________________ first time stang owner and loving it!!! SlP lm2's, pypes o/r x pipe, jlt intake, mach grill delete, tinted headlights and tail lights!! I got the modding bug..... |
#46 |
Do you still have your cats? If so that might be the problem. Any difference in how it runs such as loss of power? Clogged cats can produce a lean code.
#47 |
Slow
No he has an offroad X, but he has a tuner that he used to shut off his rear O2s
#48 |
Master of the Force
Millenium Falcon
"Just Living the Dream"
did u load the 97 tune are are u on the 93 still?
MSO smokes pole |
#49 |
13.538@101.72
he said he was on the 87....detonation was the firs thing i thought of too ragtop
#50 |
2001 Sexystang
14.8@94.3MPH
it's when your spark plug ignites before your piston hits top dead center. that shit is so bad for your car it could put a hole threw your piston if it gets bad enough
Dynamax side exhaust,K&N FilterOMG, Eibach Prokit, BBK UDP |
#51 |
02' GT
you said somthing about your exhaust sounding different, you probly have an exhaust leak before the first o2.
p.s. good reply zinc i would just add that you can just give the inertia switch a swift tap with your hand and the button will pop up, then you know its triggered... also a good trick to play on your ford friends, laugh when they cant figure out why theyr car wont start
Nitrous is like a hot girl with an STD... you wanna hit it, but your afraid of the consequences '02 GT~dd '89 LX~still in swap mode FOR SALE: Canfeild cylinder heads 302ci 2.02-1.60 valves 54cc combustion chambers-dual vavle springs $1200 |
#52 |
im goign to spray my maf down rite now and put air filter oil on the filter. then tommrow morning im doing my fuel filter and after school im doing my transmission fluid change.
i know this pic is shitty but this is definitly the gengeral area of where the wierd nosie is coming from... its hard to tell exactly becuase with the lm1s and o/r x the cars loud but when i turn the car on and get next to the circled area i can hear the nosie louder then if im on the other side or not leaning over
#53 |
its at the very back rite of the engine bay
#54 |
2001 Sexystang
14.8@94.3MPH
vacuum hose come lose or something?>
#55 |
nope....
wats that rusty metal thing behind that fluid container? |
#56 |
13.422@103
Your hydrobooster for your brakes
![]() Mineral Gray Club Member #3 Winter Plans= FRPP 31 spline trac lok, Moser 31 spline axles, FRPP 3.73 gears. 256RWHP, 299RWTQ All Mods In My Garage |
#57 |
2000 gt vert
no it dosnt look it up cause i did to make sure. aod tranny takes 5qrts if you drained oil pan and it takes 12-13 if the tranny is completely empty.
#58 |
13.538@101.72
dexron atf brother.
#59 | |
#60 |
2000 gt vert
my bad dude i thought you were talkin about fluid amount. i wasnt paying attention.
Threads Similar to: when bank 2 is running lean...
| running lean | silvergtstang99 | 99-04 | 4 | May 27th, 2008 07:21 PM |
| Running Lean | 1982matthew | 5.0 Mustangs | 2 | April 23rd, 2008 05:01 PM |
| running lean | 91cobra5.0 | 5.0 Mustangs | 26 | January 24th, 2008 10:59 PM |
| Running Lean | ROUSHME661 | V6 Mustangs | 22 | November 30th, 2007 02:47 PM |
| Lean Bank 1 | fastvenom01 | 99-04 | 2 | April 19th, 2007 08:12 PM |
