idle rpm w/ cams
Old September 11th, 2008, 05:53 PM   #1
ajm
idle rpm w/ cams
I did a bit if looking around and as usual didnt find very much. I was just curious for those of you running cams what do you have your idle rpm set at?
Old September 11th, 2008, 05:54 PM   #2
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
800 on mine
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old September 11th, 2008, 05:54 PM   #3
1999 Mustang GT
cigarmanva is on a distinguished road
you should be able to have it set where ever you want it set with proper tunning....unless you're running some very, very radical cams
Old September 12th, 2008, 02:03 PM   #4
Trick Tuners's Avatar
KB'd GT
even mild cams will require a bump in the idle. 800 will normally work for most cams. Mild cams could probably get by with 750 or 700. Stock idle is ~640. The lower you idle, the cooler they sound, but the closer to stalling you may get.
Old September 12th, 2008, 03:19 PM   #5
2001 Mustang GT
12.4@111 (N/A)
01GT4.6 will become famous soon enough
mine is roughly 800 rpm
12.4 @ 111mph N/A 2V... (first trip out) in desperate need of a driver mod
N2O times coming soon
my junk at the trackhttp://www.moddedmustangs.com/forums/signaturepics/sigpic17788_2.gif
Old September 12th, 2008, 07:13 PM   #6
ajm
Exactly why I asked. I was curious what everyones was but also noticed when I set mine lower I got more lope but noticed a different smell in the exhaust so ive been leaving it at 650-700 range. Definitely doesnt sound as good but atleast the exhaust smells right.
Old September 12th, 2008, 07:27 PM   #7
2000 GT
RyanGT is a jewel in the roughRyanGT is a jewel in the roughRyanGT is a jewel in the rough
Mines at 1000. Stage 2 blower cams though. Ill try to turn it down a little bit when its all said and tuned but for now i like not stalling out at stop lights. It used to be at about 1100 sadly.
2000 Black convertible GT: KB 15psi, and other goodies...
1971 Datsun 240 z: Header and rebuilt motor. (The DD)
Old September 13th, 2008, 03:49 PM   #8
1999 Mustang GT
I don't think i idle that low now...and i'm stock! anyone remember the trick to get the rpm read out on the odometer?
Old September 14th, 2008, 08:38 AM   #9
andres0286's Avatar
andres0286 is an unknown quantity at this point
Send a message via MSN to andres0286
Mustangworld How-To's INDEX
Its I think the 26th article
2002 GT SOLD
2003 Mustang GT Cobra Clone SOLD
Procharged @ 8psi
458 rwhp
Mods in Garage
Old September 14th, 2008, 11:15 AM   #10
StangAddiction is on a distinguished road
Send a message via Yahoo to StangAddiction
Im running XE270 cams with the idle set at 1000 until the engine warms up then the settles at around 800-850...
Threads Similar to: idle rpm w/ cams
RPM fluctuating during idle. Arikara 2005 - 2010 7 February 16th, 2008 11:29 AM
Idle RPM 89StAngerLX 5.0 Mustangs 5 October 3rd, 2007 01:18 PM
idle rpm 40thANVGT 99-04 13 May 2nd, 2007 01:50 AM
Erratic RPM in Idle mechwife General Tech 7 April 9th, 2007 01:10 AM
My idle is at 2000 rpm slingblade05 5.0 Mustangs 6 September 13th, 2006 03:04 PM
