Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket - Page 4
LinkBack (35) Thread Tools
Old July 25th, 2011, 09:06 PM   #61
gdl
99 Cobra, 03 Mach1, 07 CS
gdl has a spectacular aura aboutgdl has a spectacular aura about
Originally Posted by moosenuk17 View Post
good write up! do i nee to drain the fuel?
It's easiest to drop the tank with as little fuel in it as possible. When I did mine, I just drove it until it was below 1/4 tank. Even then it wanted to tip off the jack, not a big deal if you have two people but could be a problem if you're trying to do the job by yourself.
2007 Redfire California Special
http://i183.photobucket.com/albums/x...n/2007GTCS.jpg
2003 Dark Shadow Grey Mach 1
http://i183.photobucket.com/albums/x...born/Mach1.jpg
1999 Black Cobra Vert
Old July 25th, 2011, 09:07 PM   #62
99 GT
87dtna is on a distinguished road
I'm waiting until I'm just real low on gas to do it. Probably until the fuel light is on even. A full or mostly full tank will just mean it's heavier and harder to handle. Gas is around 6-7 pounds per gallon, so just figure even with 3/4 tank you got an extra ~70 pounds in there to hold up when you lower the tank.
Plus if you're gonna be fishing out that plastic clip or 1/2 of the gasket like the OP mentioned he had to do, you don't really want to stick your hand right into a pool of gas to do it.
Old July 25th, 2011, 10:20 PM   #63
naza's Avatar
00 gt
naza will become famous soon enough
Mine is leaking too, but I don't feel like dropping the tank :/
Red Pony Crew Member Mods in garage. Waiting on dyno numbers
Old July 25th, 2011, 10:31 PM   #64
Pittbull's Avatar
2001 Mustang GT
If you're not first you're last
Pittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to behold
iTrader: 6 reviews
Send a message via AIM to Pittbull
me neither but gas is to expensive to be leaking out
Stock Rear Springs FOR SALE! PM Me
Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me
Old July 25th, 2011, 11:19 PM   #65
moosenuk17's Avatar
2000 ford mustang GT
moosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the roughmoosenuk17 is a jewel in the rough
Send a message via AIM to moosenuk17 Send a message via MSN to moosenuk17 Send a message via Yahoo to moosenuk17
thats why i got the wife or if someone is in san diego that wants to help lol
2000 kenne bell GT (440HP-432TQ)
Tuned by Joe at http://www.tricktuners.com
dyno vid:http://youtu.be/lr3xpxw2_v8
2011 escape
MUSTANG TAT CREW
Old May 15th, 2012, 09:39 AM   #66
3ntr0py is on a distinguished road
Resurrecting this old but very helpful thread
I have a 99' and have a p0455 "large EVAP leak" code that never goes off. Its not my fuel cap and I often smell gas after filling up so I'm going to try this to see if my gasket or filler neck is damage. THanks OP for this great write up. Also, on hot days can I be losing gas through evaporation? I've notice I've been making more trips to gas stations lately.
Old May 19th, 2012, 02:49 AM   #67
Just an update for those with this problem. I completed my gas tank gasket replacement and all went pretty smoothly. I basically followed OP's instructions to a T and it was indeed the cause of my CEL code and gas smell. It took me about an hour with one helper, a jack, two stands, and basic tools. I just struggled with getting the fuel lines off the fuel filter (I had disconnect tool) and the tip of the filler neck (plastic part OP talked about) also fell into the gas tank for me. I didn't want to pull the pump off so I lucked out and fished it out through the filler neck hole (where gasket sits) with a wire. Getting the gasket into the hole wasn't too hard for me. I basically bent it to make it fit into the hole then used petroleum jelly to get the last bit in. I then coated the gasket hole with jelly and raised the tank and slid the filler neck into the hole. It honestly kind of had me thinking of porn. BTW, my gasket was only partially torn on one side and I was able to get it out whole. The pics show the filler tip in the gas tank and the gasket before I started.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/88697-gas-tank-leaking-how-drop-your-fuel-tank-replace-filler-neck-gasket.html
gas tank filler neck This thread Refback February 23rd, 2012 11:23 PM
CObra leaking fuel! - SouthFloridaStangs.net This thread Refback February 10th, 2012 05:53 AM
2000 Mustang GT CCRM/Fuel Pump issue | Page 2 | Mustang Forums at StangNet This thread Refback December 31st, 2011 01:23 AM
gas tank filler neck This thread Refback August 15th, 2011 03:15 PM
Petrol smell This thread Refback August 4th, 2011 04:29 AM
CEL Light? - SVTPerformance This thread Pingback July 4th, 2011 08:02 PM
2001 mustang gas tank gasket This thread Refback March 12th, 2011 10:25 PM
How to Replace the Filler Neck on a Ford Truck | eHow.com This thread Refback November 28th, 2010 12:01 AM
HELP ASAP!! car leaking gas - CMC Forums This thread Refback November 10th, 2010 12:11 AM
HELP ASAP!! car leaking gas - CMC Forums This thread Refback November 9th, 2010 11:52 PM
HELP ASAP!! car leaking gas - CMC Forums This thread Refback November 9th, 2010 11:26 PM
in need of 01 gt help, please - MustangForums.com This thread Refback November 8th, 2010 10:06 PM
2000 Mustang GT CCRM/Fuel Pump issue - Page 2 - Mustang Forums at StangNet This thread Pingback October 4th, 2010 09:17 PM
Fuel Leak - MustangForums.com This thread Refback August 15th, 2010 02:31 PM
SMR CHAT FORUMS • View topic - Gas tank and filler tube This thread Refback July 7th, 2010 02:05 PM
gas tank filler neck This thread Refback June 28th, 2010 08:44 PM
Gas smell + Check fuel cap warning - Ford Forums - Mustang Forum, Ford Trucks and Cars This thread Pingback June 8th, 2010 06:08 PM
gas tank filler neck This thread Refback May 25th, 2010 08:10 PM
gas tank filler neck This thread Refback May 9th, 2010 12:33 PM
gas tank seal leaking - SVTPerformance This thread Pingback May 8th, 2010 04:52 PM
gas tank filler neck - ModularFords.com This thread Refback May 2nd, 2010 08:48 PM
gas tank filler neck - ModularFords.com This thread Refback May 2nd, 2010 10:15 AM
modular/new edge tech - United Gear Heads This thread Refback April 3rd, 2010 09:18 PM
modular/new edge tech - United Gear Heads This thread Refback January 28th, 2010 12:47 AM
modular/new edge tech - United Gear Heads This thread Refback January 27th, 2010 09:45 PM
How To Drop A Fuel Tank - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback January 15th, 2010 05:55 PM
1998 Mustang Problems Fuel Pump - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback December 20th, 2009 05:23 PM
the 0 ring for the gas tank - SouthFloridaStangs.net This thread Refback March 3rd, 2009 07:16 PM
CObra leaking fuel! - SouthFloridaStangs.net This thread Refback January 29th, 2009 02:54 PM
CObra leaking fuel! - SouthFloridaStangs.net This thread Refback January 29th, 2009 02:26 PM
CObra leaking fuel! - SouthFloridaStangs.net This thread Refback January 29th, 2009 02:06 PM
99-04 Fuel Filler Neck Gasket Tech Post - palmbeachmustangclub.com This thread Refback January 28th, 2009 02:33 PM
99-04 Fuel Filler Neck Gasket Tech Post - palmbeachmustangclub.com This thread Refback January 28th, 2009 11:28 AM
check fuel cap light - SVTPerformance This thread Pingback December 24th, 2008 01:08 AM
Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket This thread Refback September 17th, 2008 10:04 PM
Threads Similar to: Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket
fuel tank filler hose question obake Classic Mustangs 3 September 2nd, 2008 08:21 AM
Fuel tank filler neck gasket blk01gt 99-04 9 August 21st, 2008 06:17 PM
Fuel tank filler help fox4.6 Modular Mustangs 1 June 27th, 2008 07:33 PM
Gas Tank Filler Gasket MustangMatt96GT The Clubhouse 16 January 18th, 2008 12:31 AM
drop gas tank Invictus 99-04 9 August 15th, 2007 12:09 PM
