2003, Mustang, GT
bleeding brakes question
Is there any order you have to go in when bleeding your brakes. My friend said you had to go in order. The last time I did it I just did it in a random order.
![]() Mods: Vortech V-1 supercharger, BBK LT headers, BBK o/r X pipe, Flomaster cat back, 4:10 gears, Centerforce clutch, Fidneza aluminum flywheel, K-member, Eibach pro kit, MM caster camber plates, Eagle F1 tires 275 & 315. |
1999 Mustang GT Convert
Do the farthest one from the master cylinder first. Front and back are from different parts of the master cylinder you can do either end first, just start at the farthest away.
2003, Mustang, GT
thanks. Also if I am upgrading the front calipers and lines only do i need to bleed the back as well or am i good just bleeding the front
Just the front. It's a safety feature in case your brakes fail with front & back split you will only lose half your brakes.
Threads Similar to: bleeding brakes question
| question about saleen brakes | supercharged03gt | 99-04 | 5 | July 29th, 2008 07:33 PM |
| Bleeding a clutch | zinc02GT | 99-04 | 17 | March 19th, 2008 11:14 PM |
| She's bleeding :( | whtpny | V6 Mustangs | 1 | April 11th, 2007 07:12 AM |
| Brakes question | Bill | 5.0 Mustangs | 10 | August 21st, 2006 11:22 PM |
| General question on brake system issues (bleeding/no pedal) | 95plainjane | General Tech | 3 | July 3rd, 2006 11:22 PM |
