zippeewannabee
timing cover
can someone give me a step by step on how to remove the timing cover? or if someone knows a website where there is one.... having some trouble removing it
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
zippeewannabee
anyone?
zippeewannabee
ok lets try this... does the timing cover have to come off to get the heads off?
or can i just undo the cam gears and slide the heads out
Proud American
Its the 4 bolts on bottom i bet you missed.
Proud American
![]() where the box is on the bottom talking about torque
2002 GT
99.99@999.9
yes the timing cover has to come off to take the heads off, make sure you put the motor in safe mode, and retime it right when you put it all back together
zippeewannabee
not worried about the 98 the heads are coming out of... they are going into my 2k
Proud American
did you get it?
zippeewannabee
gonna work on it a little later, when it cools down a bit
Threads Similar to: timing cover
| Help Please Timing Cover!!!! | Stang281GT | 99-04 | 12 | July 9th, 2008 06:53 PM |
| Removal of Timing cover | Haggis13 | 5.0 Mustangs | 2 | June 18th, 2008 04:22 PM |
| timing cover | Black Five 0h | 5.0 Mustangs | 3 | April 17th, 2008 10:52 AM |
| Timing Cover | 68 dlxcoupe | 96-98 | 3 | March 31st, 2008 02:59 AM |
| timing cover gasket | cali 5.0 | 5.0 Mustangs | 5 | August 20th, 2007 09:42 PM |
