Discussing harmonic balance puller? in the 99-04 Forum. has anyone used one of these? and if so, is it just me or is ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
has anyone used one of these? and if so, is it just me or is it almost impossible to get the harmonic ballancer off?
![]() Stage II P&P Heads | Custom Grind Comp Cams | BBK O/R X Pipe Mac Catback | JLT CAI | MGW Short Shifter Custom Tune
What kind are you using? If youre using a jaw one then yea youre probably going to have a little trouble. If you have one that bolts to the crank pulley you shouldnt be having that much trouble. The hardest part is turning the wrench on the tight area but it comes off fairly easy.
Once it gets going, its alot easier - make sure you dont screw the bolts through the pulley too far or youll phuck up your timing cover. Oh, and make sure you take out the spacer/washer that goes between the crank bolt and the pulley or else itll never come off!
Accufab 75mm tb & plenum MRT h-pipe Flowmaster catback FRPP king cobra clutch FRPP aluminum driveshaft FRPP 4.10 gear TA Perfromance girdle Steeda tri-ax shifter Moser 31 spline axles FRPP C Springs |
hey that was my problem... lol... i was like wtf is it not coming off..
felt real dumb after that
1999 SVT cobra
ya the harmonic balancer is a pain to get off. It took me a little bit because of the washer when i did my bbk pulleys. My car is now in excessive motorsports getting the engine torn apart because of my crankshaft pulley. somehow the crankshaft pulley turn 180 degrees counterclock wise and threw off the timing chain? or broke the timing cover? and Ideas on what could be messed up?
#6 | |
04 Mustang GT
1999 SVT cobra
reallly? everyone tells me they are really reliable nd everything.. but recently iv been hearing they are under new management. they put my spec 2+ clutch in well. but then again clutch aint to hard to put it. do you have any ideas what could have happened?
It took me all of 25-30 mins to get my harmonic balancer off with the puller i rented from the part store...
![]() The hardest thing for me was working in the limited space of the engine bay... |
1997 Mustang GT
13.5@100mph
Took mine off with a puller that was on sale at Harbor Freight Tools for $6, and three bolts off the timing cover.
Threads Similar to: harmonic balance puller?
| harmonic balance | TKOTLARZ | 94-95 | 5 | July 29th, 2008 03:11 PM |
| Our Account Balance | Trance | The Clubhouse | 16 | April 17th, 2008 06:59 PM |
| 28oz Balance | 95StangMX | 5.0 Mustangs | 19 | January 16th, 2008 10:24 PM |
| pusher or puller | javier351lx | 5.0 Mustangs | 4 | October 24th, 2007 07:52 PM |
| harmonic balance | mustang1072 | V6 Mustangs | 13 | February 17th, 2007 05:09 PM |
